Question about Dell OptiPlex GX270 PC Desktop
Dell GX270 won't boot up with solid amber light on Power button
My Dell GX270 won't boot up and the power button only got solid amber light. Both Cpu fan and PSU fan run ok after turn on the power. I already swapped CPU and PSU with a good GX270, the problem is still the same.
Can anybody give any suggestion? Thanks in advance.
  • JZ Feb 14, 2009
    Yes, I already swapped RAM, and disconnect the data cables connected to HDD and DVD. I also replaced all electrolytic capacitors on the mother board. It is still the same.
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Posted on Feb 20, 2009
    Master:
  • 568 Answers
Have u checked the ram and the mother board, you will also have to take a look at the data cables connected to hdd and the dvd or cd rom
Posted on Feb 14, 2009
Gx270 tower mother board amber LED solid on
If the fan is not spinning this can be the issue ...but it can also be the motherboard itself ..if you have the possibility try to change the fan ..cause if it fails to start the computer will also fail cause the cpu it will shut down the system instantly if it has no cooler working ..(gets to the shut down temperature in one sec or so ) If it seams that it is trying to start ..but , like I said , it shuts down ..just try to change the fan ...but it may be a issue with the power supply or the motherboard as well...
Dec 18, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
I tried to turn my inspiron 530s on and a solid Amber light come on. I tried to search for an answer but i havent found it. I opened the pc side cover to see if evething were connected and all of the wires...
It needs a new power supply unit (PSU). And, it absolutely won't run without that 4 pin connector. Any standard ATX PSU of at least 250 watts will do. But, Dell usually uses a backward configured power supply so you'll have to purchase theirs. If you have a Dremel with a cut-off wheel, or other means of modifying the case, you can use a standard PSU. If it needs the cut-out, you'll see what I mean when you get the new one in hand.
Jun 25, 2011 | Dell Inspiron 530 Desktop Computer
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Solid amber light on front amber on mother board
take the PSU (Power Supply Unit) from a known working computer, preferable to be the same model and test with it. when you do so make sure you disconnect any peripherals e.g ( Printer, CD-ROM, Floppy).
Look closely at the memory bay for any bent pins, and test with one memory at the time.
Let me know if this is still an issue.
Regards
Dec 23, 2008 | Dell OptiPlex GX280 PC Desktop
Dell dimension 4600C Power up issue
Woops -the blinking amber light of doom is a common fault on dells - as you already have replaced the PS that leaves the motherboard.
usually a solid amber is the PSU while a blinking one indicates MoBo problems. If either machine is still under warranty dell will replace it.
If not then it will cost you to have them replaced.
cheers Pete
Dec 07, 2008 | Computers & Internet
Motherboard change
jethro..
http://support.dell.com/support/edocs/systems/dimC521/en/SM_EN/tshoot.htm#wp1064555
check on system lights... what are the diagnostic lights telling you??
if the 4 lights are off you may have a problem with the led itself or the powersupply is just messing with your head.
Dec 02, 2008 | Dell Dimension C521 PC Desktop
Dell GX280 no display
plug in a video card in a pci slot and see if your video comes on and do the same with your agp slot
Jan 25, 2008 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX270 PC Desktop Logo
2,483 people viewed this question
Alun Cox
