Question about Pitco Frialator Kitchen Appliances - Others
Model 14RSUFM w/purple computer won't come out of the boil out
Fryer he4ats grease to 215 degrees, won't continue to heat
  • 979 Answers
You could have a bad t'stat. If you turn your t'stat to say 400 degrees does it get hotter ? If so, then all it may need is calibrating.
Posted on Feb 15, 2009
Can I boil in the fryer
A fryer is meant for grease and quick cfrying, why dont you just boil water in microwave, or on the stove.
Mar 02, 2017 | The Kitchen Appliances - Others
How to remove and clean burners of soot
You can purchase deep fat fryer cleaning solutions in a powder form or liquid....we sell them and other companies do too. The key is to boil your product, along with water in the fryer, using a L shaped brush to add in the cleaning process. You may need to do this a couple of times, if your fryer is really bad. If you boil it out, drain it and it's still really cruddy, then use a green pad and scrub what you can manually, then fill it back up, use whatever product you desire, boil it out again, using your L brush too. That will help clean out the drain hole where you drain the grease out, as well as the burners too. This is not an easy job, so if you think 15 or 20 minutes will do it, it won't... It's tough to clean restaurant equipment, as it's used normally 24/7 and not taken care of very well normally. Spills are burnt on, nothing is ever wiped up, grease spills over the sides of the fryer, and the crumbs in the bottom are burnt over and over, as some people don't strain their grease, just using it until it becomes unuseable... It's a tough job, but one we do quite often, and you just have to put in some elbow grease, use your cleaners, along w/the boil out method, a green pad or 2 or 3, and when you are satisfied and done.... Be super sure to rinse all the chemicals out of the frypot before you add any oil to it. Leaving ANY soap in the bottom of the frypot will help to break down your oil and spoil it way before it should, and that's expensive to replace over and over. Keep your temperature down to 325 degrees and that will help you save your oil as well. If you want to really extend your oil, buy and use a additive like Miroil. This is a oil additive that is used to extend the life of your oil, on a daily basis, sometimes twice a day, depending on your hours of operation/business. This additive , along with keeping your temp at 325, straining your oil, and rinsing your pot out well before adding oil will extend your oil so well, that you will never dump a whole vat of grease again....You will get a formula that will tell you how much grease to pull each day and you will replace that amount with new oil....If you have 2 fryers or 3, you would pull oil from your appetizer fryer and put it in the fish fryer, dumping that oil, whatever the measure is, like 3 cups or whatever. The idea is that your appetizer fryer has the lighter cooking foods in it and the fresher oil. The fish fryer can handle the older oil a bit better. All fryer foods will look/taste/ much better all week long, without your foods getting darker as the week goes on... Your foods will also absorb less oil, if you keep that temperature down to 325 instead of 350 or higher. That higher temp also helps to burn your oil up quicker, so keep it down....
I've seen this product work, and every customer I ever sold it to, never stopped using it once they started, and the cost is under a dollar a day.... Your savings are huge, as oil is one of your most expensive costs in the food industry. If you need a place to buy the additive or the fryer clean out products or the L brush, we sell all of it and can ship directly to you. Restaurant Equipment Outlet, Cincinnati, OH 888-542-5959.
Happy Frying...
Nov 26, 2011 | Vulcan EF3 Deep Fryer
I just need to know how to completly clean the bottom of my imperial fryer
Are you talking about the actual burners? They make a L shaped brush that you can use to get around the burners themselves, and a quick tip is to clean the fryer warm.... Once you heat up a griddle or fryer, the cleaning gets substantially easier. They also make either liquid or dry powder cleaning additives, which also help with the cleaning... Once cleaned, make sure you rinse all the soap residue out of the frypot, as that will help to quickly break down your oil, once that new oil is heated up. Another tip is to ony turn the temperature up to 325, not 350, as that also helps to break down your oil. Keep in mind, no matter what yu do, your fryer will never look clean again.... Even the clean, used ones look alittle used after some use and never look shiny new again. If you need any of the cleaning solutions, I do sell them and would be happy to ship some to you... Our individual packets of liquid Mr. Muscle cleaning solutions run $1.95 each and for a 30-40 lb fryer, you need two per cleaning. The directions says to drain oil out and rinse to clean out loose soils, fill w/'water to oil fill line, and get water boiling. You add the Mr. Muscle while filling w/water.... Boil at about 225 temperature for 10-30 minutes. (225 degrees keeps it from boiling over). While it's boiling, gently use a fryer brush or scraper to remove baked on soils. You can also buy the powder version, which is $11.95 for a 9lb jug... Fryer brushes are $24.95 and can withstand alittle of the high heat.... I stock all of these items and can ship to you, if desired. Try this anyway, whereever you end up buying your products and this should work for you...This is how we clean the dirty deep fryers we get in and we've never had any trouble. Our phone number is 888-542-5959, and we are Restaurant Equipment Outlet, Cincinnati, Ohio. We sell new/used equipment, furniture, smallwares, just about anything you need for a food service business.
Thanks, Susan
Jul 18, 2011 | Imperial IFS40 Deep Fryer
My flame keeps on going out on my turkey fryer it has a heat sensor on it how do i position the sensor so the flame doesnt go out
The heat sensor for your turkey fryer is preset to 375 degrees F. Once the oil reaches that temperature, the sensor turns the flame OFF, so that the oil will not boil over and ignite. Once the oil cools to 325 degrees F, the burner can be relighted . Use extreme caution when relighting the burner. Altering or repositioning the heat sensor would make the fryer unsafe to operate.
I'm sorry. I which I had better news for you. Always, err on the side of caution & safety when dealing with open gas flames.
Jul 06, 2011 | Brinkmann 815-3530-2 Turkey Fryer
My fryer heat up to 285 then quit then try to light but want,
sounds like the high limit is doing what it is suppose to do. Check the actual temperature of grease with a perometer and see if it matches temp on computer if it is more than 10 degrees off or fluxuates irraticly change the temp probe. If it is dead on change the high limit.
Jun 25, 2011 | Frymaster Dean 2424G Deep Fryer
What is the best way to get fryolators clean
Boiling out the fryer tank with the use of grease cutter will get rid of the soil that have build up on it. Make sure to refer with the boil out chemical guide for the right amount of solution and the right boil out temperature.
Feb 17, 2011 | Pitco Frialator SG18S Deep Fryer
The stack in the rear has carcoal build up, also the lower components are covered with caked on grease
You really need to clean this up before using it... Built up grease will catch fire, and it's fairly easy to clean this. You can buy some deep fryer cleaner at a restaurant equipment type store near you or I can ship some to you, but it's easier to use a product intended for that use... They have liquids or a powder available and you will want to turn your fryer on to boil it out, with your cleaner in it. Any restaurant equipment will clean up alot easier if you have it on low or 200 degrees...including the outside of the unit. For super built on crud, they have sprays also you could spray up inside the flue area, that will eat away that grease build up. You will have to clean that out however, and they also carry brushes if you need one of those to reach it... It will take some elbow grease, and some patience, but we clean up equipment all the time that normal people would look at and throw away. When we're done with it, it looks brand new again... Good luck.. Susan 888-542-5959.
Dec 25, 2010 | Pitco Frialator SG18S Deep Fryer
How do i stop the grease from boiling over
Make sure there is no water in whatever you are placing in the grease....grease and water together equals bad boil over.... the water turns to steam rapidly and very bad things happen...
heatman101
Oct 11, 2010 | Rival CF105 Deep Fryer
Boiling grease
When the issue starts have you actually checked the grease temperature? You can also checkto see if there is excessive grease build up on the themostat.Sometimes uncooked food particles can cause a boiling type motion in the fryer while they cook. be sure to do regular filterings of the grease,this will cut down on the suspended particles.If the grease temp is above 350, shut power off and check continuity on the thermostat,it could be sticking closed,in which case it will need to be replaced
Mar 05, 2009 | Garland ED-30SFT Deep Fryer
Wells 35lbs fryer double vat
Hello
This sounds to me as if your thermostat is not cycling the unit off. But I can see a second problem as well there should be a high limit cutoff to prevent it from running on and boiling over. I would check both. The thermostat is the dial or knob to regulate temperature and the high limit is the safty to prevent boil over or run on.
Thanks
Mar 29, 2008 | Wells F-686 Deep Fryer
Kitchen Appliances - Others Logo
97 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
