Question about Relic 0504648FA
Relic watchband adjustment for model PR 6057
Can'tfigure out how to do this, and there are no "arrows" on links of this model that I can find to help with orientation
203/#https://home.tomtom.com/shop/latestMapGuarantee: Error from server: Framework Initialization Error /tomtom720 gps
Posted on Feb 14, 2009
I need to adjust my Style&Co SC1325 watchband, what can I do?
Your picture clearly shows the small arrows (on the inside of the band) the way the watch band pins need to be removed. You'll need a very small needle and a small hammer to drive the pins out in the direction of the arrows. Remove links evenly on both sides so the clasp is centered.
Once you fell you have removed enough links to fit your wrist, drive the pins back in reverse direction from the arrows, and set them smooth to the touch. If you can push the pins in to the hole just beneath flush, with your needle and hammer, it'll keep the pin from snagging your sweaters.
If all else fails most jewelry stores charge less than $10 to remove links. Have fun. It's not hard.
Jan 23, 2015 | Watches
How do I add a link to the wristband?
Thank you for contacting FixYa.
  • Turn your watch on its side so the links are vertical. On the inside of the links closest to the clasp you can see arrows, which point in the direction that the pins must be pushed out. Only about four links on either side of the clasp have arrows, because these are the only links with removable pins. On the edge of the links on the opposite end from where the arrow is pointing you will see a small circle where the pin is inserted.
  • 2
    Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • 3
    Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • 4
    Insert the new pin into the watchband. You will need to insert two pins, the pin you moved in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Best regards. Jewel
    Sep 16, 2010 | Nixon District Watch
    How do i install additional links to this model watch? the company mailed me 2 additional links but no installation instructions Fossil model ES1967
  • Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • Insert the new pin into the watchband. You will need to insert two pins, the pin you removed in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Aug 18, 2010 | Watches
    How to remove links from relic chronograph steel watchband
    Click on my profile, then click on TIPS AND TRICKS. There you will find explanation how to add or remove links. Rate me, plz.
    Feb 27, 2010 | Relic Watches
    How to adjust Relic ZR15539 watch band
    Depends on the type of band. Is it a twist-o-flex or solid link? Your best bet is to seek out a local watch repair business and let them adjust it for you! Unless you do these often it can be frustrating and you could lose small parts!
    Jan 09, 2010 | Relic Watches
    How to make a relic watch bracelet a little smaller?
    No but if this is a mens watch there might be a micro adjustment on the clasp. To adjust press the pin in the clasp and move the pin in or out depending on the position of the pin to make loose or tight.
    Sep 18, 2009 | Relic 0504648FA
    Relic watchband that isn't the same as instuction book
    You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
    First you have to find out what sort of pins or even screws are used to keep links together.
    Examine both bracelet sides and find the side where pin ends have a groove.
    Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
    For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
    Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
    NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
    Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
    After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
    After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
    It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
    Make sure that pin ends are flush with bracelet. If needed- hit few more times.
    Job done!
    Don't forget to rate, please.
    Feb 15, 2009 | Relic 0504648FA
    Remove link form Relic Wrist band
    For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
    If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
    Hope this works for you!
    Feb 14, 2008 | Relic 0504648FA
    Adjusting the watch band on a Relic Adjusta Link Watch
    have heard to call relic 1 800 842 8621 and they will send up to two links i think with no charge just shipping
    Jan 27, 2008 | Watches
    Relic 0504648FA Logo
    387 people viewed this question
    Top Relic Watches Experts
    Jim Parker
    Jim Parker
    Andrew Taylor
    Andrew Taylor
    Are you a Relic Watch Expert? Answer questions, earn points and help others
