Question about Craftsman Air Tools & Compressors
Craftsman compressor won't cycle off
I have a 6hp 25 gallon Craftsman 110v air compressor that worked just fine. Then I started using a smaller compressor in my shop and had not used the 25gallon one for a few weeks. Cranked it up yesterday and it started filling the tank just fine. Seemed like a long time and the pressure was up to about 125psi and still was running. I turned the switch off, motor stopped, turned it back on and the motor stayed off. The next time it cycled on, same thing, really ran too long and never cycled off. Any idea what the problem might be with it?
  • 256 Answers
Hi, First, I think the cutoff pressure is 135psi and there is an overpressure valve so let it run a little longer. I don't know exactly which model you have ( some of these were oil less) but if it is running longer than you remember, be sure to check the oil if necessary, make sure you are not using a long extension as this will cause the motor to slow down and definitely check to make sure the water is drained and the drain petcock is closed all the way. Also check it without an air hose attached. Good Luck!
Posted on Feb 14, 2009
I have a 6hp 33 gal aircomp i builds up to 100 should go to 250 wont shut off because not up to press can you help
Sounds to me likt you have a bad motor, or compressor. The compressor rings might be leaking by only holding 100 psi.
Aug 10, 2012 | Craftsman 33 Gallon Vertical Portable Air...
I have a Craftsman 3.5 hp, 25 gallon compressor. The compressor runs fine, but will not build pressure. Tank has pressure from the last cycle so I know it is not leaking. The compressor runs but no...
Hi Jim,
Disconnect your main air supply from the comp head to the receiver/tank and see if their is a reasonable air supply to atmosphere.
If not check that air is being taken in by the head intake filter
John
Aug 05, 2011 | Craftsman Air Tools & Compressors
6hp craftsman air compressor runs to 3 or 4
make sure it is plugged into a 20amp outlet. and do not use an extention cord
Jan 16, 2010 | Craftsman Air Tools & Compressors
Motor runs pressure stays around 25psi
if they are oilless compressors then the rings are worn
Jan 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
6hp, 25 gallon compressor, never cycled back on, blew the breaker. reset the breaker and soon as i flip the compressor it trys to start then blows the breaker right away.
sounds like its the motor drawing too much current,has it got plenty or oil cause they run low and seize up,not the most reliable can be fine but equally can be dramas especially if its from China
Oct 26, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
We have a 30 gallon; 6HP Craftsman Compressor; Single cylinder/oil free; 120 volt, 15 amp compressor. Mod. #: 919. 167311; Serial #: 2216185983. It has quit working, do you know what may be the issue and...
DOES IT RUN AND NOT MAKE AIR? BUZZ OR MAKE ANY NOISES AT ALL? DO YOU HAVE POWER TO IT? HAS IT BEEN IN THIS LOCATION AND WORKING FINE TILL NOW? NEED MORE INFO. JODY
Jun 29, 2009 | Craftsman Air Tools & Compressors
Builds pressure, will not cycle back on and leaks fluid
Your compressor is most likely made by Campbell Hausfeld. The oily substance could be leaking from the capacitor on the motor. Remove the cover and examine the capacitor for failure. There is a value printed on the cap. (uf) The cap must measure to within 95% of printed value. A failing capacitor will cause the hum that you are experiencing.
Dec 27, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
189 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
