Question about Fahrenheat PHH15002 Oil Filled Baseboard Heater
Oil baseboard heat v electric baseboard heat.
Redoing insulated, enclosed basement 25' x 26'. will frame and add insulation. laminate flooring. concerned about fire hazard. live in New York (cold winters). what if the basement floods? two young children (1st graders) will be playing down there. oil baseboard estimate (3 walls) came to $1750. thinking about running the oil baseboard on only one wall to save $. does code require a heating mechanism in basement? do I even need heat or could I use a portable electric oil-filled radiator heater? any thoughts?
    Problem Solver:
  • 10 Answers
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Posted on Mar 16, 2009
I live in Wisconsin (so it gets cold) and I just built a 1,000 sqft detached garage with 9' walls and I looking for the most efficient way to heat it. I will generally only be using it on weekends, but,...
Hi Rob - There are a bunch of variables that come into play. If you're going to use liquid fuels such as K1 kerosene or "home heating oil" (red dyed diesel fuel without the "road use tax"), you have to consider the tank location. Since home heating oil is really dyed diesel fuel, is reacts to cold just like diesel fuel does. It begins to gel - paraffin separates and the fuel gets cloudy around the 20 degree F mark and can clog the supply lines and filter. It gets worse as it gets colder. You can get around this somewhat by installing larger diameter and insulated fuel supply lines and moving the filter bowl assembly inside where it won't be subjected to that much cold. Your dealer may put additives in the fuel to prevent separation or you can add it yourself. K1 can be added to home heating oil tank to reduce clouding and straight K1 can be burned by an oil burner (you can not burn home heating oil in a K1 heater though). K1 on the other hand, flows just fine at these temps and lower. You'll need to supply storage tanks for these fuels.
The amount of heat or BTU's per gallon of these two fuels is significant. Home heating oil checks in with 50% more heat with around 140,000 BTUs per gallon while K1 has just over 90,000 BTUs per gallon. Cost is another factor. Typically, K1 sells for more than home heating oil, but has the benefits above. Prices for home heating oil and K1 are volatile and change daily and from dealer to dealer. Many dealers will lock prices and / or offer purchasing plans.
Next is natural gas (or just plain "gas") and propane (or LP). Gas is usually delivered via underground supply pipes and propane is delivered by truck to your on-site tank in areas that don't have the underground gas pipe infrastructure in place. The LP dealer will usually supply and install an above ground tank. You'll likely have just LP or both LP and gas available in your area. Heating appliances must be set up to burn one fuel or the other - not both. It is often a relatively inexpensive operation to convert from one fuel to the other, meaning separate appliances for either are not required. Gas prices are usually fixed for different times of the year, while LP prices may change daily and based on the volume used. Lower usage customers often pay more than their next door neighbors that use more from propane the same company. Like home heating oil and K1 dealers, many companies offer price locks and purchasing plans.
Gas and LP heating appliances burn "clean" meaning that there is little smoke, soot or tuning needed. Oil and K1 however, require regular tuning and cleaning to achieve maximum efficiency. Oil and K1 will burn but not rapidly combust - as gasoline would. LP and gas however, will explode if allowed to collect in an enclosed area and ignited by spark from a ringing telephone, etc. Prices of the heating appliance itself come into play as well.
You can heat the space by your choice of fuel and method of heat delivery. Forced hot air is probably going to be your best choice, but you could choose a forced hot water system if you add antifreeze to it. You'll also need a source of water to make up any lost due to pressure relief valve discharges, etc. If you chose the forced hot air system, you could probably get away without the expense of duct work - where a forced hot water design will require baseboard radiant heaters or a fan forced hot water coil.
That should be enough to get you thinking.. good luck!
Lastly, electric heat. Electric heat is 100% efficient, but is probably the most costly to operate. It's listed because it is available - not because I recommend it.
The best thing you can do is insulate. Insulation pays you back quicker with each rise in fuel costs. Put money into proper insulation as you can. Low E glass in your windows, weather strip doors, etc.
Nov 12, 2010 | Heating & Cooling
Tip
Underfloor Radiant Heating for Your New Sunroom
You want to add a brand new sunroom onto your existing house. The problem is that you are not sure how to heat it. Electric heating with baseboard heaters will spoil the look that you want from your new room. Hot water baseboard is going to present all types of problems getting hooked in to the existing system and piping it. And, if you have hot air heating system then you will have the problem of getting ductwork to the room. There is another way to heat this room easily and efficiently.
Radiant heating has been one of the most comfortable and efficient ways for heating for many years. The problem has been in the past to find a good heating source for small radiant floors that will be affordable, effective and efficient.
This problem has been solved now, with the availability of small new electric combination heater- circulator units. These units use small electric heating elements together with a small circulator pump to give you a all in one heating source and circulator pump.
Now you just have to lay your tubing in the floor of the room you are adding on to your house. Then you run that tubing into your existing basement or other room in your house. The tubing and the electric are attached to the heating unit. Then, wire a thermostat to the unit, and you are now ready to make heat. This really makes heating a new addition room very inexpensive and easy to do.
The greatest thing about using this type of heating system is that most average do-it-yourself types can do this. All that is needed is a basic knowledge of plumbing and electric.
If you are thinking of building that little add-on and are worried about how you will heat it, think about using radiant floor heat and a small electric heater-circulator to do your project.
on Dec 05, 2009 | Heating & Cooling
I'm replacing a non-hydronic electric baseboard heating unit with a Fahrenheat hydronic one. My old unit was 240v using 2 conductors plus bare ground wire. The fahrenheat (PLF series) unit's instructions...
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Jan 06, 2010 | Fahrenheat Electric Hydronic Baseboard...
Home heating issue! hot air is cold when it reaches top floor!
Just guessing, but I'll bet your 2nd floor duct work is in the attic, and uninsulated, wrapping all attic mounted duct work with R-13 insulation and sealing it with tape will help but there is still going to be a slug of cold air pumped into the upstairs rooms each time the furnace cycles.
Dec 11, 2009 | Better Living SPP High Efficiency...
How do i know what size baseboard heater to use in any given room.
Basically each baseboard should be rated for a particular heat output...Watts...which should have an equivalent to square footage...look in the Specs or askj the Supplier....and that will vary on the Heat loss of each particular room...how big the windows are....how well insulated the room is etc
Oct 16, 2009 | Fahrenheat Electric Convector Baseboard...
I want to install 240v baseboard htrs in a below ground basement.
you must really love your hydro co
those heaters are a huge draw on your bill
why not install radiant heat they are cheep now in compairison
the unit is a central mount run the line in a loop arround basement and conect all the heaters in drop lines off the main line small thermostat valve for each room to control heat
cost is more for unit but savings are greater too they now make a light duty units designed for your porpose
single direct electric heaters are pigs on the hydro bell if you have gas or electric it is cheeper to run a small boiler or heat on demand system
Aug 04, 2009 | Heating & Cooling
Need to calculate heat loss in a building for hydronic heat
In Ontario, we use a sanctioned set of calculations that takes into account the exposed area of each wall, roof and floor, factors in orientation of each surface and makes a parallel set of calculations for the windows and door openings.  In Ontario, the institute managing this process is HRAI and installers/designers should carry an HRAI card showing that they have passed the (non-trivial) exams.  I'm quite sure the HRAI process is based on similar ASHRAE-prescribed processes and other jurisdictions may refer directly back to ASHRAE or to some other local authority which in turn bases its process on ASHRAE, much as HRAI does.
In your case, there are two sets of calculations required.  One is, as you point out, the HL (and HG for summer) calculations (HL = heat loss; HG = heat gain).  The second set is to calculate the layout and BTU-delivery capability of your radiant system and identify those areas (lots of glass, typically) which will need supplementary heat, such as higher-temperature radiators like the models of Runtal.
I'm authorized only to do the first set of calculations in Ontario.  There are usually independent guys who work free-lance for heating contractors and who might be able to help you out.
Mar 18, 2009 | QMark HBB1004 Hydronic Baseboard Heater -...
Electric Hydronic Baseboard Heater Under Electrical Recepticle
I believe you interpretation of the code is a bit skewed in that the fundamental concern is to not route power cords over a heat source which might cause the insulation on that wire to exceed its rated operating temp and fail. The heaters themselves have shrowds over them so there are no exposed surfaces hot enough to melt wire insulation and when you think about it ..2000 watts disipated over a long baseboard section is not that hot. If I were you, I would go ahead and install them and not worry about the warning.. The warning also removes any liability from the heater manufacturer in the event something happens.. Common sense would dictate that you wouldn't intentionally drape power cords all over the heaters... Just use common sense and not worry about it..
Regards,
Rick
Dec 01, 2008 | Marley Electric Hydronic Baseboard Heater,...
Dishwasher insulation for heat
Hi marseibold,
I'm Harvey the Master Plumber.
Your questoin is: You're wondering if you can further insulate your dishwasher for heat. You are redoing your kitchen, new appliances, cabinets, etc. and shortsightedly put the spice sliding pull-out cabinet next to the dishwasher. The spices get warm when you use the dishwasher. There is a bit of room between the cabinet and dishwasher. Any recommendations for further insulation?
Yes. I would get another insulation blanket off a d/w I'm disposing. Anyway, you need to get one and install it over the old one to decrease the heat transfer.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Dishwashers
Fahrenheat PHH15002 Oil Filled Baseboard Heater Logo
2,973 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
