Question about Neff 24 in. S5456 Built-in Dishwasher
Neff dishwasher not filling up with water
My S9J1F Neff built in dishwasher is not filling up. Does anyone know how to fix this?
Neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
Posted on Aug 26, 2009
Neff dishwasher - bottom tray not cleaning - rotary arm not turning
If your dishwasher is 10 years old and you are facing a significant repair cost, it may be time to consider replacement.
Jan 01, 2014 | Neff Dishwashers
S5453x1gb/50 s9j1f integrated diswasher door does not close
if the door is not closing do you mean will not stay closed this may be because of the locking hasp or the handle/lock located on the door on the top of the unit if the door is not moving up and down then this would because of the lower pulleys inspect your machine further and message me back with your finds Thanks again Rick
Jan 08, 2011 | Neff 24 in. S5453X1 Built-in Dishwasher
The dishwasher is not filling up
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Dec 13, 2010 | Neff 24 in. S5543X2 Built-in Dishwasher
The dishwasher is not cleaning properly, glasses look like they have a film on them, plates also do not look clean & the dishwasher has a foul smell.. like rotting food in it.. we use the top quality...
Check the main drain system connected to the dish washer hose pipe. Clean the junction if clogged. This smell might orginate from the pipe.
Check incoming water quality. If hard water is noticed, use softener attachments to the inlet.
Fill dish washer salt in the dispenser. Refer user guide. The salt will help softening the water to certain extent. Finally check whether rinse aid dispenser filled with the rinse aid liquid.
Jun 01, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
We have a neff dishwasher and the pump is draining all the time (even when the door is open) but there is no water in the dishwasher. Is there a way to stop the pump and reset the setting for the flood...
The water which has activated the antiflood device is actually underneath the appliance it is held in the sump tray and this has to be drained before the A.F.D.will cancel.You will have to remove the dishwasher to get at the underneath but when you have got rid of the water you will still have to trace what caused it.The seal on the circulation pump could be a suspect or a pin hole in the drain hose.
Hope this helps.
May 09, 2010 | Neff 24 in. S5409X0 Built-in Dishwasher
My neff dishwasher will not fill will water and will not complete program - cleaned and checked filters to the best of my knowledge - can you help?
i if it doesnt fill with water check it is actually draining is there water in the tub etc?if it cant drain it wont fill or complete the cycles,this is usually a blockage in the pump the handbook tells you how to deal with this problem.
Jul 29, 2009 | Neff 24 in. S5555X0GB Built-in Dishwasher
My dishwasher is not filling w water
check filter or drain hose it probably have a dirt,try to fill with water manually and turn on pump to dispossess water,if water not go out and pump work then you have dirt in hose or filter,if pump not work then pump is broken.
Jul 05, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
I have a neff dishwasher that is maybe 5 years old. im pretty sure there is nothing wrong with it as it was working perfectly fine before i had a plumbing problem a few days ago. after the plumbing problem...
Look for the connection from the valve to the inlet of diswasher. Check the hot water valve to be on. It is probably closed when anyone working on the plumping. Good luck.
Neff s5946 slimline built in dishwasher. Fills with water, clonking sound in pipe and does not register on programme, although pump working.
if you only hear the clunking sound while the dishwasher is filling then the inlet valve is bad.. i would replace it because if it fails completely you could possibly have a flood..
Feb 20, 2009 | Neff 18 in. S5943 Slim-Line Built-in...
Neff dishwasher water filling
there is a safety float in there to shut the water off most look like domes under the float is a safety switch take off the bottom kick and see if the float is on the switch if it is check to make sure the switch is good
Feb 18, 2008 | Neff 24 in. S5543X2 Built-in Dishwasher
Neff 24 in. S5456 Built-in Dishwasher Logo
2,078 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
