Question about Dell A940 All-In-One InkJet Printer
A940 printer stalls and gives a hardware message
My printer stalls partway through the print and gives me a hardware message. when i look there appears to be nothing wrong
This is a usual problem whit this model of printer, i had been thru this three times already.
In my case, the printer stops completely halfway printing and shows "Hardware error 502", i found that is because the optical sensor strip is dirty, first you should try to clean it with out removing it form the printer, to do this you should:
(The optical sensor strip its an nearly transparent plastic strip behind the print head, if you look closely it has very thin lines painted on it, this is used by the printer to measure the movement of the print head)
1- Print something to case the hardware error and shut it down immediately
2- Disconect the printer
3- Lift the scaner part of if, as you do when adding ink.
4- Look where the print head (the ink cartiges) is, this is where the stain is
5- Get the print head out of the way (just slide it left or right)
5- Use a soft cloth with little water to try to clean it, if it doesn't work try isoplopile alcohol because sometimes the stain is ink and is very hard to remove
6- Try print again and repeat as necesary
if you can't clean it this way you must remove the strip and clean it.
(You must have plenty of time and patience to try this, or you can dissasembly the printer entirely if you want to re lubricate or something)
1- Move the printer head all the way left, and with some pointy object pull the metallic wire holding the the strip at the right edge (flashlight very usefull), it's marked with and "D", remember that.
2- Move the printer head to the right and remove the plastic strip (this side is very easy), it's marked with an inverted "F" (it's on the other side) and an arrow indicating the up direction
3- Inspect how dirty is the strip and clean it the way you want (not so aggresively, the strip hasn't the fault)
4- Put again the left side of the strip and make it pass behind the print head
5- Move the print head to the left
6- Put the right side of the strip whatever you can, this is a very tedious process because the reduced space available, remember to keep the left side in place, because it's impossible to put the right side first.
7- Re connect and power on your printer, if it immediately gives hardware error 502, the strip is misplaced, move it a little up, down, backward an forward trying to get in place and try again, or consult the respective solution en this website.
8- If you can turn on the printer it should print now, try it, if it works, Congrats!
Sorry for my bad english
Posted on Feb 15, 2009
My Dell A940 printer has a message "Hardware Error 0502" and when I try to print, I get a message that the printer is busy. What's wrong?
Check the instructions mentioned in the below mentioned link and follow the instructions and surely your problem will get resolved....
http://en.community.dell.com/dell-groups/new-to-community/f/3511/t/19268082.aspx
Waiting for your feedback.......Do reply !!!!
Feb 18, 2011 | Office Equipment & Supplies
Dell AIO A940 is giving me an error code 0502 and won't print. Says it is busy?
Check this out for the error. The trick here is to make sure the bar is cleaned and lubricated with furniture polish or cooking oil.
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
May 24, 2010 | Dell A940 All-In-One InkJet Printer
Cannot uninstall printer a940 driver. when we try message comes up 'printer in use"
easiest way is to stop the print spooler by going to the run command and typing services.msc then locate the print spooler and stop the spooler. you can now delete the printer driver.
Oct 22, 2009 | Dell A940 All-In-One InkJet Printer
Printer problem for a dell 924 printer
I have run across several Dell & Lexmark printers that after a while of working great, decide to have an "issue"... If you are printing more than 1 page, they will print the first page, then stop. The computer says "Cartridge Stall" and the printer says "Hardware Error 0502" or something similar, depending on the printer... Anyway, the message on the computer suggests making sure your cartridges are installed correctly, and nothing is blocking their path... After dealing with this many times, I have finally found a solution that seems to work!
There is usually a metal bar that the cartridges slide back and forth on... over time, this bar can become "gunked up"... Use alcohol pads to clean up the bar, and the surrounding area.... Clean out as much of the track as you can also. Tada... .No more cartridge stall!!
My a940 will not feed the paper. the error message
Here is the Dell support page the gives instructions for this errror, (though not overly helpful, I'm afraid.) See also instructions here, here, here,
If none of those steps correct the problem, reset the printer by following these instructions.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 25, 2009 | Dell A940 All-In-One InkJet Printer
Cartridge stall message, how do i fix?
clean the cartridge there could be too much ink clean with a piece of tape
Jul 19, 2009 | Dell A940 All-In-One InkJet Printer
Changing ink cartridges?
I have a dell printer, scanner, fax ect.
The printer and scanner won't work now. Keep getting message, " hardware errpr 0502, when printer starts up, gives a loud click noise.
How do I fix?
Mike Murphy mmurphy8015@yahoo.com
Jan 04, 2009 | Dell A940 All-In-One InkJet Printer
Cartridge stall
I have a lexmark x5150 printer, scanner, copier, and fax machine. I keep getting the message: hardware error 0502. The cartridges are stalled on the left side and the printer won't do anything. Can someone help me??
Feb 18, 2008 | Lexmark X5150 All-In-One InkJet Printer
Cartridge Stalls
hmmm...not too good on this one. Seems that maybe there's some paper jamming the runners or mechanism under the head carrier. Check that first, but be careful, since it's delicate under there
Feb 06, 2008 | Dell A940 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
71 people viewed this question
Top Dell Office Equipment & Supplies Experts
Prashant  Sharma
Prashant Sharma
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
