I have a Sony STR-DA5300ES Receiver with a Panasonic Blu Ray pluued into one of the HDMI ports. From the receiver, there is HDMI to the TV. Wen I plug the HDMI cable from the receiver into the HDMI switch and then from the Swtich to the TV, there is no signal, no audio, no video. Not sure what I am doing wrong. Any help is appreciate.
  • 3 more comments
  • sgoodrich720 Feb 14, 2009
    I have a Sony STR-DA5300ES Receiver with a Panasonic Blu Ray pluued into one of the HDMI ports. From the receiver, there is HDMI to the TV. Wen I plug the HDMI cable from the receiver into the HDMI switch and then from the Swtich to the TV, there is no signal, no audio, no video. Not sure what I am doing wrong. The other inputs work fineAny help is appreciate.
    The HDMI switch has only one output to connect to the TV.
    The TV has only one HDMI port, so anythin connected there is "DVD" port on the TV.
    I have a Sony STR-DA5300ES Receiver with a Panasonic Blu Ray pluued into one of the HDMI ports. From the receiver, there is HDMI to the TV. When I plug the HDMI cable from the receiver into the HDMI switch and then from the Swtich to the TV, there is no signal, no audio, no video. There is only one place on the switch to connect the TV. The TV has only one HDMI port so anything connected to is on the "DVD" port on the TV display.Not sure what I am doing wrong. Any help is appreciate.
    The TV is a Sony KLV-32M1 32 inc LCD
    Everything else works fine with it except this switch when connected to the receiver. How do I find the firmware verison?
    I am also connecting a Media Center PC to another input
    I have the panasonic to the Sony Receiver on 1 input
    Then the Media center PC on another input
    When I watch DVDs I use the receiver for the surround sound
    When I use the media center to downstream video, I use another input
    the output should go to the TV at least that is my understaning.
    Master:
  • 848 Answers
Hi
check the audio settings and DVD settings on the tv and ensure the amp is set up correctly.....
Posted on Feb 14, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
May I ask why an HDMI switch has to be used? To my understanding, the basic system works, that is Panasonic to Sony to NexxTech.
If you would have other HDMI sources, then the arrangement should be Panasonic to switch, all other HDMI sources to switch, output of switch to the Sony, output of Sony to NexxTech.
Pls post back for any updates/developments. Good luck and thank you for using FixYa.
    Brigadier General:
  • 8,619 Answers
Hi!
Please check the input connections of the HDMI cable and also try to tune the TV on a diffrent AV channel.
  • Rylee Smith
    Rylee Smith Feb 14, 2009
    Please tell me the model no. of your TV as it may not support the latest version of HDMI(1.3b). Please check for the compatiblity of the version with the TV(Does your tv support HDMI ver 1.3b)
  • 19,396 Answers
Check HDMI settings on TV and try using a different HDDMI port on TV.
  • Ginko
    Ginko Feb 14, 2009
    Check the HDMI settings on your TV, on some model you need to add a new HDMI device.
    Try also a different HDMI port at the back of TV, some model does not work the same way on all ports.
  • Ginko
    Ginko Feb 14, 2009
    Also ensure that you plug in and out the HDMI cables for your devices when both TV and connected devices are off , or you risk to damage TV or receiver.
    Try unplugging everything from power, waiting ten minutes, and connecting everything back.
    This is called hard reset and ofte can solve similar problem on HDMI connections.
  • 679 Answers
Change the wires input, and check again.
  • rockfixya
    rockfixya Feb 14, 2009
    check this.
  • rockfixya
    Go here for more information>>
    http://support.sony-europe.com/tv/tutori...
    Thanks
No sound through yamaha htr-5750 receiver and samsung blu-ray
That's because tha hdmi is desing to play sound to the reciver you may have to use out put sound from the unit.
Dec 06, 2013 | Sony STR-DG510 Receiver
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
Hd picture
Your TV does not support 1080p thats why, just adjust blu-ray and PS3 resolution down and it will work
Jun 01, 2010 | Sony STR-DG820 Receiver
Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Jan 17, 2010 | Sony STR-DG510 Receiver
Video but no audio
This receiver does not support audio via HDMI. You need to connect BD player via spdif cable. Use optical or coax depending on what does the BD player support - receiver supports both.
Dec 24, 2009 | Sony STR-DG520 Receiver
No sound from Sony STR-DH500 when playing dvds with HDMI
no sound via hdmi cables, you must use optical or coaxial
Dec 10, 2009 | Sony STR-DH500 A/V Receiver
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Sony STR-DA5300ES Audio Problem
I am posting this to try and get everyones audio problem for this receiver fixed. If you only connected the HDMI cable to the 510, you will not get sound. This receiver passes through HDMI only, no processing of audio. You must either connect a fiber optic or digital coax to the 510 for that respective HDMI input from the BD player, the DVD HDMI only accepts digital coax, and the Video2 HDMI only accepts fiber optic. If you BD player does not have digital coax out for audio, you must move the connection to Video2 HDMI and connect fiber optic to the Video2 fiber input. Sony butchered the whole purpose of HDMI with this receiver. Hope this heps you. By the way, it is hardware, no firmware update will correct this.
Jan 02, 2008 | Sony STR-DG510 Receiver
NO SURROUND SOUND WHEN PLAYING BLU-RAY
Your amplifier should "downgrade" the signal to 5.1, even if the disc isn't using it. It is most likely a setting on your amp that may need adjusting for "types" of digital to accept on its input. If you can, set your optical input on your amp to "auto". This way it will automatically detect and switch for the proper incoming audio feed
Jan 01, 2008 | Sony Playstation 3 (PS3) Console
No Audio
What port do you have the HDMI from you BD player into on the 510. If you have it on the DVD port then fiber optic will do you no good, the DVD HDMI only supports digital coax, the Video2 HDMI only accepts fiber optic, and there is an extra fiber optic for the Sat input. If your BD player does not have digital coax out, or if you dont want to buy another cable, just move the HDMI from DVD to Video2 on the 510. I am willing to bet you have the BD player plugged into the DVD HDMI port and the fiber optic cable from you BD player to the Video2 fiber input.
Dec 18, 2007 | Sony STR-DG510 Receiver
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Electro Med Services...
