Question about AEG Washing Machines
TUMBLE DRIER-INDESIT IS70C
M tumble drier isn't drying the clothes or heating up although the drum turns alright. Can anyone help?
    Genius:
  • 1,239 Answers
Hi did u check the hoses from the pump and check the pump for any obstructions.
Posted on Feb 14, 2009
How candydo i fix a candy condenser tumble drier
Does it trip if u run empty? Is the heat exchanger blocked (normally found below drum on front and unclips)
Jul 16, 2015 | Candy Dryers
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
Why is my Tumble Drier keeps beeping without stopping a few minutes into the drying program?
It sounds like the carbon brushes are probably worn down - they ride on the drum (in the top ) and determine the amount of moisture left in the clothes for drying - they connect to the drum and the metal bar inside the dryer - A wet clothing item conducts between the two giving the dryer an idea of how much moisture is left in the load - equal to how much time / heat is needed to dry load as required. These brushes wear out and need to be replaced over time
Aug 03, 2014 | Miele Washing Machines
Why does my indesit is70c rattle when spining
the front or back wheel has gone they are plastic
Jun 28, 2012 | Indesit IS70C Electric Dryer
Indesit IS70C tumble dryer not heating
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 10, 2012 | Indesit IS70C Electric Dryer
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
Hi,my indesit IS70C tumble drier works but does not heat up.\possible causes please.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Indesit IS70C Electric Dryer
Drier does not tumble but it still heats.
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 05, 2010 | Asko T701 Electric Dryer
White knight 767 tumble drier
If the rug was very heavy you could have burnt up the motor. If it will restart after it cools off, replace the motor and clean out the vent system.
Good luck.
Dec 08, 2007 | Dryers
Washing Machines Logo
147 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
