Water not draining away
Hi I have a candy washer/dryer CIW 100 T. When washing the water would not drain away how do I repair or resolve this I was told it was the filter, but I cannot find it, any ideas
  • jeanniejampo Apr 18, 2009
    The same problem with the same machine but I live in a apt where it is built in so where do I find the hoses and pump?
  • 1,239 Answers
check the hoses from the pump and check the pump for any obstructions.
Posted on Feb 14, 2009
Hello, I have a Candy Alise washer dryer water doesnt' drain anymore. help please
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
May 05, 2015 | Candy Washing Machines
Machine starts to spin out of control
Both problems could be related to a blocked drain, from what I can see in the manual. 3 Things to check -
1. Clean the filter - instructions can be found on age 24 of the manual.
2. Check the drain hose has no kinks/securely fitted.
3. Check the drain trap under the sink for blockages. Make sure waste water can drain away freely.
Keep a couple of old towels handy when checking the drain filter, if water is trapped in the machine, it will flow out of the filter housing when you remove it. Try a drain cycle for a minute or two before you remove the filter, then turn the machine off, and check it. That way you'll have drained as much water as it will allow.
The manual can be found here-
Jan 07, 2014 | Candy CNW136 Front Load Washer/Dryer
Candy Washer/dryer Stalls
Have you checked the drain hose connection? Make sure the bung is clear in the trap
Aug 07, 2012 | Candy CNW136 Front Load Washer/Dryer
Washer fills with water but does not spin or drain.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Apr 03, 2011 | Washing Machines
I have a candy ciw 100t washer dryer and the water never gets hot, is this a cold fill washing machine?
to find if this is a cold fill machine only, just check the back and see how many hoses are fitted to it.I would assume it is cold fill and the problem is within the heater.
Mar 15, 2010 | Candy DQW150 Front Load Washer / Dryer
My candy 514 is not draining properly - even after a spin cycle the clothes are still very wet suggesting that water is not getting out
I have a GE and my friend has the same problem with his whirlpool. Removed the frt cover adn looking at the washer on the left side there is a clean out drain. My kids leave things in pockets and filles this drain up and washer will not drain. it is very easy to do
Oct 26, 2009 | Candy CNW136 Front Load Washer/Dryer
Hi, I have a Candy CIW100T washing machine and its recently stopped draining the water aty the end of the cycle. Can you help please? Thanks
Check filter behind kick plate on bottom front of machine. Drain water out first by lowering drain hose into bowl or bucket.
Plz come back if further help required.
Dec 02, 2008 | Candy DQW150 Front Load Washer / Dryer
Candy CIW100T Washer, dryer
Sep 09, 2008 | Washing Machines
Will not drain
Try cleaning the filter as when this gets all clogged up the water doesnt drain thru the pump
Apr 24, 2008 | Candy AQ130 Front Load Washer
Washing Machines Logo
291 people viewed this question
Top Washing Machines Experts
