Question about Samsung LE40R74BDX 40 in. LCD Television
No signal or intermitant signal
Have a large winegard antenna 32 feet high, new rotor, new pre-amp, new coaxial cable, new connections, still 1 station at best. I've tried
Magnavox. Zenith, DTV Pal & RCA Boxes. RCA is the only one I can
get 1 station on. Any words of wisdom? I'm 32 miles from the closest
TV tower. Weather seems to effect the digital signal greatly.
    President:
  • Samsung Master
  • 1,779 Answers
Sounds like cable or satellite are your only options unless after the switch they bump up the power.
Posted on Feb 14, 2009
TV reception breaking up pretty bad because of rainy weather here in Brooklyn New York I live in an apartment and I'm using a Winegard amplified antenna does anyone have any suggestions what improving...
Television signals are at such high frequencoies they will be reflected form buildings and other objects, and attentuated by moisture in the air and through the leqaves of trees, etc. In large cities yourt TV singals can arrive from different paths Digital TV signals bounce as di the old "analog TV" signals but the technology allows the receiver to ignor singals that are out of phase so the picture is "clean" despite multipleversions of the signal arriving at the antenna at slightly different times. That said, if the signal is weak, there is little you can do other than experimanet with positioning the receivng antenna. Typically, building walls attentuate televisoin signals so locating the receving antenna close to a window often provides for stronger signal reception.
Amplified antennas cannot amplify what is not there. Moisture in the form of fog, rain and snow will attenuate television signals and if thre signals are marginal in good weather, they may be virtually not-existent in wet weather. Digital TV signals are threshold dependent. When they are toow eak, you won't see anything. Back in the old analog TV days, you could see a "snowy picture" but digital TV doesn't allow for that. The signal is either strong enough to be viewed or it is not.
You have few real options if you do not subscribe to cable or a satellite tv provider. Amplified antennas can help but if you need them you live in a marginal TV reception area to begin with and more prone to the vagaries of weather and the seasons.
Jan 18, 2015 | Winegard FL5500A FlatWave Amped Indoor...
Not receiving signal from wcyb channel 5 on winegard hd7697 antenna
try installing a tv signal amplifier on the line from the antenna just before the tv. Tv stations put out differing amts of power, one could be stronger than the other.
Mar 21, 2014 | Winegard HD7697 High Definition VHF/UHF...
I have cobra cb that is connect to 2 whip antennas in the box of my pickup, and everytime i talk to someone they say im really fuzzy and cant understand me and i cant figure out the problem
First, determine if the sound is related to audio - or signal.
Have someone listen to your AM radio transmission nearby. With an un-modulated carrier, the signal should sound clear. If there is noise on the signal, try with a different mic. If no mic is available, key up the radio by shorting the PTT pins on the jack on the radio itself (this will remove the mic element from the circuit - effectively disabling any audio noise entering from the mic cable or element. If the noise disappears or is significantly reduced, the problem lies with the mic, cable or connections at the mic plug or the inside the hand help portion.
If there is no problem in the above test - then the trouble can be a result of the signal. Signal issues are more pronounced when there is more space between your transmitter and the other person's receiver. If they are close to each other, it will be difficult to hear problems. Things that can affect signal quality - and noise can be: 1) vehicle electrical systems. See if there is a noticeable difference with your signal compared when transmitting with the engine on and engine off. Fuel pumps can be a source of noise, as can ignition noise, alternator whine, etc. A "choke input" filter or a large value microfarad capacitor rated at more than 15 VDC installed between + and - wires can help mitigate these noise sources - but it is unlikely that either will eliminate it. 2) power wiring. Always get power directly from the battery. This is the cleanest source of power available in the truck. You can interrupt the 12+ line with a relay that is controlled by the accessory terminal if you want the radio to shut off when the ignition key is removed it you wish - but resist the urge to use the accessory terminal to power the radio directly. 3) Antenna issues. Dual antenna installations require 75 ohm coaxial cable (co-phase harness) to perform properly. These can be as simple as pinched coaxial cables to improperly tuned antennas. Damaged cables need to be replaced. High quality, low loss, 75 ohm coaxial cable is required for the demands placed on it in mobile situations. Tuning for the lowest SWR or VSWR is a necessity from effective power transfer from the radio and antenna coax to the radiator or antenna. A detailed description of how to can be found here. Be sure to keep in mind the last sentence in the article regarding co-phased antennas: Adjust BOTH antennas to keep them in balance.
Hopefully, one or more of these suggestions will help solve or reduce the problem you've got. Good luck!
Jun 21, 2011 | Cobra Radio Communications
Poor radio reception.I've tried a new aerial mast,no improvement. CD player sounds fine. Any ideas? (Passat Est.2003)
Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 1 Subject: Model(s): Group: Number: Date: AM Radio, Poor Reception 1999, 2000 91 99--07 New Golf, New Jetta, Aug. 2, 1999 New Beetle, Passat Condition AM reception is poor. May be caused by: ? An incorrect antenna mast installed for the antenna base equipped with the vehicle ? Poor ground at the antenna base or radio ? Poor battery ground to chassis or engine ? Poor antenna cable connection at Radio ? Corrosion at the antenna coaxial connectors at radio or antenna Service Vehicles are equipped with either a Bosch or a Clarion antenna base mounted on the roof and (for shipping purposes) the appropriate matching mast is located in the luggage compartment. If radio antenna masts are removed from vehicles and stored until vehicles are sold, there is a chance that an incorrect mast can be installed at the time of delivery. Note: Mismatched antenna mast and base will cause poor AM radio reception. The antenna base and mast can be identified visually as follows: (Cont. on Page 2)91-A260 requires gloss finish antenna mast 57mm 49mm Bosch 91-A261 requires matte finish antenna mast 61mm 41mm Clarion 91-A262 Technical Bulletin Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 2 Bosch antenna ? Base (although oval) is more circular in shape (approx. 57mm x 49mm). ? Made in Germany stamped on underside of base. ? Two screws on underside of base are unpainted. ? Requires gloss finish antenna mast. Clarion antenna ? Base is more oval in shape than Bosch (approx. 61mm x 41mm). ? Two screws on underside of base are painted. ? Requires matte finish antenna mast. If antenna mast matches the antenna base correctly: -- Check antenna coaxial cable connections --arrows-- for corrosion and clean if necessary (DO NOT apply stabilant). Passat coaxial cable connection for radio is under the carpet on right side of tunnel near shifter. -- Ensure that coaxial cable is firmly seated in radio (Passat cable connection, see previous step). -- Check ground at the antenna below roof Nut --4-- (torque = 7+1 Nm) must firmly secure antenna to roof). (Cont. on Page 3)Technical Bulletin Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 3 -- Check ground for radio behind radio on cross member (On Passat models as of Nov. 1998 beginning VIN: XE285000 ground for radio is on right side of center tunnel). -- Check engine compartment ground, left side, below battery tray; frombattery GND to body. -- Check engine/transmission ground on transmission, near engine block. -- If all grounds and antenna mast are OK. -- Replace antenna and coaxial cable assembly
May 06, 2011 | Car Audio & Video
Sony kdl46w5150 with external antenna dropping signal on some channels
1. Check for any loose connections starting at your TV. (Coaxial cables unscrew themselves with vibration...) Check all outdoor connections for corrosion and cut off and replace any cable ends that show corrosion.
2. Check your alignment - (positioning or pointing)
http://www.wowvision.tv/OTAalignment.htm
3. Replace the balun a.k.a. 75 ohm matching transformer.
If these don't work, a larger antenna is needed...
with one exception:
That exception is if your signal is too high. If this is the case, change alignment to reduce signal a little.
Jun 11, 2010 | Sony Televison & Video
Sharp digital tv cannot receive digital signal
This television would benefit from an hdtv indoor outdoor amplified antenna not obstructed by trees, aluminum, bricks, and etc. Make sure the signal type is air and not cable and complete a channel scan during primetime tv hours after connecting to this antenna. Buy a large one that you can mount to the wall usually in a large flat box on the shelf in the store. Philips has one sold at Walmart.
Jun 07, 2010 | Sharp LC-26SH10U 26 in. LCD Television
How do you hook up a digital antenna to this tv? Protron PLTV3250 32" LCD
Connecting a Digital TV Signal
To connect an digital TV signal source to the
display, connect a coaxial cable between the
ATSC input and the TV signal source. GO to www.retrevo.com and download the manual,it is free.
Jan 10, 2010 | Protron PLTV3250 32 in. LCD Television
Message on screen
OTA stands for "over the air"and for a std TV it is searching for VHF/UHF signals as beamed from satellite. If the antennae is properly mounted and connection don't have any sulpher deposits, then the tuner has to be replaced. As far as the antennae, the basiscs are:
Based on this information, you need an antenna that receives high vhf and uhf. KVIE (ch 9, PBS) and KXTV (ch 10, ABC) are high vhf and not receivable with the CM 4220. I would recommend the Winegard 7694 or HBU-22 antennas. The Winegard has higher gain and is a 5 inches shorter than the HBU-22. Shorter boom length and higher gain will come in handy with an attic install. However, 7694 is more expensive ($60 vs ~$40).........................................sodeep
Sep 30, 2009 | Televison & Video
I have installed a Digitalstream DTX9950 converter box with my TV attached to a rooftop antenna. I can turn the TV off and on with the DTX9950 remote, but I can't bring in any stations, other than the DT...
Are you using the coaxial cable to connect the converter box to the set, or have you hooked it up with rca type video cables? The latter are highly recommended if you want a better connection and have audio/video inputs on the back of your television. But you don't want both A/V & coaxial.
Also be aware that some older antennae will not pick up digital signals well. Try to use a coaxial cable all the way up to the antenna junction. Find out where most signals are broadcast from in your area and aim the antennae appropriately. (Use a compass.) See helpful link here. Your converter remote should have a signal strength button that you can use to check the various channel strengths. If you're using a coaxial link to the tv and have little signal strength, expect a poor picture. You'll also want to select the Mono option for Audio Output in the converter menu.
Finally, depending on the age of your set, if you're using rca video inputs, use the TV/Video button or the AV button on the TV or universal remote to switch the input from the channel on your TV to the video 1 setting (or whatever picks up the digital converter signal) so you'll get that clear signal. Then you can use the converter remote to change channels, adjust volume, etc.
Jun 14, 2009 | Philips Magnavox 20MT133S 20" TV
Samsung LE40R74BDX 40 in. LCD Television Logo
181 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
