My Technics amp SU-Z980 was working fine six months ago.
Now thereĀ“s no sound (very low sound on full volume)
SOURCE: TECHNICS SU-V50
Hi max
I have done a followup with Technics Parts agents in the US, they will get back to me and then me to you shortly :) A vote as FixYa would help improve my ratings. Thanks
Graeme
SOURCE: Technics SU-V460 Amp Problems
Problem with older equipment is that mechanical switches corrode. Try some tuner cleaner on switches. One side cutting out may require the speaker leads (inside the cone of speaker) to be re tinned. Old speakers and lossa mileage cause solder to break up into powder. Re tinning the flexible link (looks much like a wick) allows that electricity to get into the speaker coil. If all else fails those old TV repair shops actually do have real techs that can fix it. Not like the current Geek Squad type of replace replace reboot replace type of tech. Good luck. Ed
SOURCE: Technics SU-G75
I had the same problem. The solution to me was presoldering transistor Q708. http://www.flickr.com/photos/37147023@N03/3511227679/?edited=1
SOURCE: Tecnics SU-G95 stereo overloaded
Power down,disconnect the speakers and power back up. If it still say's overload, it needs to go to service. If not, check your wires, connections, and speakers one by one to hunt down the problem and correct. Hope this helps
Hi....
Is there a tape monitor switch that's ON and not supposed to be....or a Mute switch that's ON?
Do the headphones have the same problem?
Let me know
