Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Problem for Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in...
Loud humming noise when dishwasher is filling up with water
By aleisia_rous on Feb 14, 2009
I have a Bosch Model #SHE46C06UC/43 Dishwasher. Dishwasher used to be quiet during the entire wash cycle NOW it makes a loud humming sound when the dishwasher first starts up and then it does cycles of humming between the washing cycles. It is quiet during the actual wash cycle though. The dishwasher cleans the dishes just fine....it's just the noise that is annoying. What could this noise be? I have called the local service center(s) in our area, that will service Bosch appliances. They want $180.00 just to walk into my house. Please advise
Thanks!
Have a GREAT day! :o)
Clarification Request
Posted by MrMark52 on Feb 14, 2009
Could the buzzing be from the water valve?
If so, you can go to the SearsPartsDirect website and locate the valve, and order it, or you can do the same from other repair websites as well.
Reply back what you find or if you have more questions.
Same Problem
Apr 15, 2009
-   I have the same problem--a high-pitched humming noise when the dishwasher is filling. Otherwise normal when cleaning. Did you ever solve your problem? I'd like to know what it was.
Thanks!-   nneeaall
Solution #1
posted on Sep 27, 2009
Not Rated)
abcdesigns
Rank: Apprentice
Rating: 0%, 0 votes
It is probably the seal on your dish washer door-- Bosch is know for being a quiet operating washer- try pushing on the door during the wash cycle and see if the humming quiets- If so- all you need to is replace the seal on your door-
Was this helpful?
Yes
No
Solution #2
posted on Mar 19, 2009
Not Rated)
here2helpBSH
Rank: Master
Rating: 96%, 18 votes
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Was this helpful?
Yes
No
Popular Solutions for Bosch 24 in. SHE44C02UC /
Questions and Unsolved Problems for Bosch 24 in. SHE44C02UC /
Do you recommend Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher?
Answer
Answer
there was a short in the junction box. i fixed that by stripping wires and installing new wire nuts.... (More)
Answer
The dishwasher runs to 1 minute and keeps running. it does not advance to dry cycle.
Answer
How do I remove the soap dispenser from a Bosch dishwasher? It will not lock closed.
Describe your Dishwashers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
