Question about Electrolux EOB5610 Ultrafan Electric Single Oven
Replace the grill element in electrolux EOB847 fan oven
Bought new element but screws that fix element to rear do not have any slots for screwdriver?
How on earth do I get the old one off and new one affixed?
Why is nothing simple? :-)
  • 1 more comment
  • davidjn Feb 14, 2009
    They are definately screws as they are threaded. Bizarre. Perhaps I have to take the oven out and to access rear nuts?
    I'll try that - thank you very much for your help.
  • Mark Egan May 11, 2010
    Are they rivets? If so, you will need to drill them out, and replace with screws.
    I would also check with the supplier of the element to see if this is the recommended replacement procedure.
    Reply back what you see and we will attempt to help you further.
  • 1,214 Answers
Yes, you do have to access from the back side.
Posted on Feb 14, 2009
My cooker won't heat up
remove the rear panel covering the fan (4 screws) from inside oven. The element is round the fan. you may see where the element has burnt through or split or distorted the element.
Jul 23, 2010 | Electrolux Ovens
Oven is not heating. Fan is working and grill wor...
This would appear to be the ring element around the fan that has failed and will need to be replaced.You will need to power off unit,then remove the back panel inside oven 4 screws in corners,Be careful with Thermostat held in place by clips above or on back panel.You may find 3 or 4 screws holding ring element.Gently pull towards you,being careful that the cables come with it.Check element with multimeter to see if open circuit if its ok then it may be a thermostat fault.If it is a faulty element,
get your replacement element,remove the cables off old one and put onto new one.Then push back into place and refix all.
Hope this helps.
May 21, 2010 | Electrolux EOB6630 Ultrafan Electric...
Zanussi built in oven and grill the element has gone but dont know how to get element out to replace any ideas thanks
If you mean the fan element then take all the racks out of oven and at the back is a panel with 4 screws remove may need a tap with hammer and screwdriver to shock rust etc. then undo screws on element maybe 3 screws pull gently forward(electric off).Try to pull the spade connectors off without losing them into back of oven if you lose them then you will have to take out oven and remove back plate. refit new element.If it was the grill element just follow above and find behind back plate.Hope I helped.
Apr 11, 2010 | Zanussi ZBF360X Electric Single Oven
My omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Mar 18, 2010 | Ovens
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
We have a hotpoint cooker UY46, our electric tripped the cooker off and , now the nob and grill works but the bottem/main oven is turning on and the fan is circulating but not getting hot ? please help ;(
You need to replace the element. Very easy job remove the back plate from inside the oven (4 screws) and you will see a circular element held in place by one screw in the centre of the fixing plate. Remove the fixing screw then remove two wires and refit new element job done.
Regards Neville
Jul 16, 2009 | Neff U1721 Double circotherm Electric Oven
Aeg competence b2190-1m oven not heating
If the fan is working o/k, then you need replace the oven element.
To access this, remove inner rear cover of oven, there you will see the circular element.
Unscrew the screws securing it ,and remove element.
Detach wires and transfer to new element, be careful not to lose the wires behind the oven rear, refit element and rear cover.
please rate my solution.
Jan 27, 2009 | AEG B2100-4 Electric Single Oven
Fan and grill works but not heating up
If the fan is working o/k, then you need a new fan oven element fitting.
Remove panel at rear of oven compartment, there you will see the element, undo any screws you can see to remove rear cover.
disconnect element taking care not to loose wires, and fit new element. test before you refit rear cover.
Plz rate this solution.Thanks
Dec 24, 2008 | Belling XOU252 Electric Single Oven
Replacing electrolux eob944 fan oven grill element
...If you can help me to remove the grill element from my EOB944, I will be able to tell you the wirings.
Nov 17, 2008 | Electrolux EOB5610 Ultrafan Electric...
Main bottom oven not working
i solved the problem by replacing element . new one cost 23 euro from electrolux spare parts dealer .1 undo 4 screws of plate inside the bottom oven . [ plate has holes in a circle patern in the middle of it ] . 2 gentle remove plate and expose the element .3 element has 3 srews .undo these and gentle take away from ovens backwall wall this will expose 2 wires that are connected to the element .3 very gentle unclip the wires from element . {grip the clips not the wires } connect new element and replace all screws and outer plate . this worked for me ....... remember to turn off the power to the oven before you go at it .
Sep 20, 2007 | Electrolux EOU6330 Electric Double Oven
Electrolux EOB5610 Ultrafan Electric Single Oven Logo
522 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
