Question about Sony FD Trinitron WEGA KD-34XBR2 34" TV
Sony KV-28DX30U TV - No picture, only sound.
Power light flashes red 5 times then stops for a few seconds then flashes again. Does anyone know what the problem might be and how much it is likely to cost to fix it?
  • 10,594 Answers
5 times flash code shows problem with AKB (white balance of CRT)
Please adjust RGB gain and screen volt of this TV.
Posted on Feb 14, 2009
    Novelist:
  • 184 Answers
I assume that the TV does not power on at all. Most likely, its a problem on the "D" board ( deflection board) Its quite expensive to fix. You'll need a Sony authorized service center to do this for you. Call a couple and ask how much they charge to replace the board. Be aware that these boards are no longer available from Sony so they may have to take the board out of your TV to have it rebuilt.
michtech
I have a sony tv model kv-27v42 i have sound but no pictture and stand by light blinks what is the problem
How many times do this standby light blinks at a time of switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty circuit section inside it. Count it. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 24, 2013 | Televison & Video
I have a Sony kv-27fs12 the picture go out but you still can hear it and the standby light turns on first it flash 5 times then stop and do it again now flash continuously please if you know let me kn
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective. If you want to know more about the blinking codes to Sony Brand TVs, check this link.
Jan 14, 2013 | Sony KV-27FS12 27" TV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
SONY TRINITRON KV-28LS35U
Error 11 means the 8V supply is missing.
Check the power supply.
Jul 25, 2017 | Sony FD Trinitron WEGA KV-30HS510 30" TV
HELP
I do believe your leg is being pulled........
Try hard reset, = unplug AC cord for awhile,then try again....T.
Dec 11, 2007 | Televison & Video
KV-32S45 Disappearing Picture, Good Sound
yes you have a bad vertical ic . i,ve seen bad conections on this ic too, it may not need to be replace its a ic that stands up 6 pins the numbeer on it starts with TDA
Apr 19, 2007 | Sony KV-32S45 32" TV
Please Help
call a tech your tv needs to to be repaired the problem is in the power supply and related circuit.good luck.
Apr 07, 2007 | Sony KV-27FV16 TV
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Sony FD Trinitron WEGA KD-34XBR2 34" TV Logo
362 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
