when i play call of duty online and i try to run by clicking the left analog stick, all it does is a slash with the knife. does anybody know how i can fix this?
-   i got the same problem, but i know the controller isnt broken because its new, i think i need to change some settings or something-   Guest
In this game you must check your settings, you may be set to right handed in which case movement/advance is on the right side and attack is on the left. You should be able to go to settings and change the settings to make the left analog control your movement. Hope this helped and if it does, don't forget to leave feedback....FIXYA!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Microsoft Xbox 360 Controller
my 360 wireless controllers right trigger button is not working. I took it apart and found out that...
(More)
my 360 wireless controllers right trigger button is not working. I took it apart and found out that if I take a wire and connect it from the middle prong on the motherboard to the small hole right beside it; it make the guns shot but not with the trigger. Why is this happening?
my right joystick on my controller has something wrong with it. this problem is not always...
(More)
my right joystick on my controller has something wrong with it. this problem is not always appearing but it happens about half the time I play with it. Say im playing a FPS and I wish to use that right joystick to turn to the right. Well, the responsiveness at times is close to none. Say I keep holding the joystick in that direction then. The speed of which I am turning is fluctuating as if its having a hard time getting the signal from the joystick. Sometimes it will jolt back to full speed and suddenly move barely at all. I have no clue how to fix this problem or explain it any better.
