Question about Sentry Fireproof Safe
Get new combo on senry dial safe
Need to know how  to reset a combo on my safe becasuse i can't remember my old combo cant rember the combination to my safe v330
  • Anonymous Mar 28, 2014
    I lost the combo to my safe and it is a gardell safe
  • 257 Answers
Hi, There is only one way, and that is to send a letter with the serial number to Sentry and if the info matches who is supposed to own it, they will send you the factory default combo to open it. Good Luck!
Posted on Feb 14, 2009
Don't want anybodythat might know my original safe combo to get in it door open cover off know original safe combo have all other info of ownership can I change combo of 1250 sentry safe
If the door is opened..Then you would need to remove the cover to the lock at the back..You will see a screw on the last wheel of the lock..Move that screw into a different hole on the wheel..Then you can dial the wheels to the lever..Each wheel is a number..This will give you a new combination..My advice to you would be to locate a Safe Tech/Locksmith..Have them do it for you..
Apr 18, 2017 | Sentry Home Security
I can't remember my electronic combination.
About 24,300,000 results (0.44 seconds) Search Results
    How To: Open A Locked Sentry Safe If You Forgot ...
    ? 5:21
    https://www.youtube.com/watch?v=Mr8QrvVAtuI
    Jul 15, 2014 - Uploaded by TipsNNTricks
    I forgot my combo to my Sentry Home Safe how do I get into it? I have a .... My batteries died and I can't find the key. Anyway ...New Sentry Electronic Fire Safe Opened in Seconds with No Sign of Entry Video - Duration: 8:22.
    Dial Combination Safe Lock vs Digital Electronic Lock with ...
    ? 4:03
    https://www.youtube.com/watch?v=7Afzh4pgh-c
    Oct 6, 2011 - Uploaded by SafeandVaultStore
    Dial Combination Safe Lock vs Digital Electronic Lock with Dye the Safe Guy ... You save about a minute. ... can't get to it, then they're going to have to drill the safe open and its going to cost you somewhere in the $300-$450 ...
    Crack Almost Any Electronic Safe with the Bounce Technique
    lifehacker.com/.../crack-almost-any-electronic-safe-with-just-a...
    LifehackerIn the event you need to break into your own electronic safe, here's how to do it. ...Can't tell you how many times I hear from friends, when the last parent ... you need to bug out and having that paperwork can save you days of frustrations.
Jan 23, 2016 | Home Security
How do I set up a Master Lock Key Safe with a new code
Open the box, with the existing combo, push the reset lever to the left and down, dial in your new combo, push the reset lever up and right to set.
Oct 04, 2014 | Master LOCK 5401D Combination Key Safe...
Have old 50 yrs weilink safe have comb. not opening
You could have the correct combo... but not be using the correct pattern. Here it is.
Turn dial several times to the right to clear it...stop on 0
Turn dial to left (ccw) 3 times past the first number and then stiop on that number the 4th time around.
Turn dial to right 2 times past the second number stop on that number the 5rd time around
Turn dial to left 1 time past the 3rd number and stop on the 2nd time around.
Turn dial to the right until it latches (could be the last number or the drifted number) until it stops
Twist handle and open door.
NOTE:If this fails to open it then its possible (after years of use and w/o service) that the numbers 'drift' from there original spot. You can try to find this out by applying pressure to the handle (which engages the 'fence' inside and rubs it against the wheel pack). While applying light pressure rotate the combo dial and where it locks up should be one of the numbers... check this against your 'correct combo' and see how they match. If it's off then all of them are off. You'll need to determine the 'new' combo by drawing the dial with the numbers use the fence located number (usually the first or last) and then reverse engineer the combination. You may also want to grab a book on safes/ safe-cracking to understand the mechanics if this doesn't make sense. Good luck!
Jun 03, 2014 | Safe International Digital Electronic Safe...
How to creeate a new combination for a sentry 1310 valueguard saf
Have a 1310 Sentry Valueguard safe and cannot remember the combination nor can i remember where i put the paper that i once wrote the combination down on....need help!
Aug 01, 2010 | Sentry FIRE-SAFE Combination Safe DS3431,...
I forgot the master combo and now i cant get it...can i reset it?
I don't know if Master Lock will supply a combination or not but they can open it for you. There might be ownership issues that need verified. They don't know who's keys are in it and they don't know if the lock has been stolen.
Aug 23, 2009 | Master Lock 5400d: Portable Select Access...
Need to reset combination
A good locksmith would tell you all you have to do is line up the notch in the tumbler wheels with the bolt bar. Turn the dial three times to the left and line up the first notch with the bar and note the number. Then turn the dial 2 times to the right to line up the second notch note the number. Then turn the dial left to the last notch note the number and turn the handle to retract the bolts. This will be your sentry safe combination. To dial the safe open see these opening instructions.
May 18, 2009 | Sentry Fireproof Safe
Can't open combo/key sentry safe.
You need to contact Sentry, they will send you an emergency unlock code.
Number in US is 1-800-828-1438.
See also:
Lost combination or keys
Replacement Keys and Combinations
Sentry Safes Key: 2 Replacement keys for sentry fire safe
Apr 18, 2009 | Sentry Fireproof Safe
Brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Jul 16, 2008 | Computers & Internet
Sentry Fireproof Safe Logo
840 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
