Question about Microsoft Windows Server Standard 2003 for PC
How to recover the windows server2003 (missing file c:\ windows\system32\config\system
  • 1 more comment
  • Anonymous Mar 07, 2009
    Deboo,
    Pls post the repair unstall for win2003 server.
    nestor
    deboo,
    pls post the repir install of win2003 server. i need it very badly
    Thanks
    i try to used your procedure but once i copied i will be prompted access is denied after the command copy
    nestor again. pls help me..thnks!
    Scholar:
  • 77 Answers
Two options:
Either reinstall Windows
OR
Follow the procedure below
It will be better if you print these instructions since you will need to type many commands later. I'm typing a detailed procedure to recover your windows.
It's possible that somehow your Windows registry is corrupted. But there is a backup. Only thing is you need to manually restore it.
Boot using your Windows XP cd in the drive and press enter when it asks to boot from CD (if it does not ask, then you will need to go to the CMOS setup by pressing DEL or F2 key and change the boot sequence)
Now, when booting from 2003 CD, it asks if you want to do a recovery, press R and you will get this screen:
Microsoft Windows(R) Recovery Console
The Recovery Console provides system repair and recovery functionality.
Type EXIT to quit the Recovery Console and restart the computer.
1: C:\WINDOWS
Which Windows Installation would you like to log onto
(To cancel, press ENTER)?
Type 1 and press enter.
Now type the commands I am putting below, one by one per line and press enter after every line.
md c:\tmp
cd system32\config
copy system c:\tmp\system.bak
copy software c:\tmp\software.bak
copy sam c:\tmp\sam.bak
copy security c:\tmp\security.bak
copy default c:\tmp\default.bak
del system software sam security default
Now, type these commands: (Take care to type the dot as it is)
copy c:\windows\repair\system .
copy c:\windows\repair\software .
copy c:\windows\repair\sam .
copy c:\windows\repair\security .
copy c:\windows\repair\default .
Now type exit and press enter and the system will reboot.
Remove the CD and boot normally in Windows .
If the PC boots in to windows, then do the following:
Start Windows Explorer.
On the Tools menu, click Folder options.
Click the View tab.
Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the "Hide protected operating system files (Recommended)" check box.
Click Yes when the dialog box is displayed that confirms that you want to display these files.
Double-click the drive where you installed Windows XP to get a list of the folders. It's important to click the correct drive.
Open the System Volume Information folder. This folder appears dimmed because it is set as a super-hidden folder.
This folder contains one or more _restore {GUID} folders such as "_restore{87BD3667-3246-476B-923F-F86E30B3E7F8}".
Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RP x under this folder. These are restore points.
Open one of these folders to locate a Snapshot subfolder; the following path is an example of a folder path to the Snapshot folder:
C:System Volume Information_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}RP1Snapshot
From the Snapshot folder, copy the following files to the C:\tmp folder with the mouse:
_registry_user_.default
_registry_machine_security
_registry_machine_software
_registry_machine_system
_registry_machine_sam
Now, once again put your Windows 2003 CD in to your CD Drive and reboot using the CD. Again press R for the recovery console.
At the console, type these commands one by one per line and press enter after every command:
cd system32\config
del sam security software default system
copy c:\windows\tmp\_registry_machine_software system
copy c:\windows\tmp\_registry_machine_system system
copy c:\windows\tmp\_registry_machine_sam sam
copy c:\windows\tmp\_registry_machine_security security
copy c:\windows\tmp\_registry_user_.default default
Now type exit and remove the CD. Boot normally in Windows and you must be back to normal.
If in case, Windows doesn't boot even following this procedure, then you need to reinstall windows. BUT you can still try a repair install instead of a normal install since that will let your programs and settings remain as they are, intact.
Post back and I will reply with that procedure.
HTH,
Regards,
Deboo
Posted on Feb 17, 2009
I just found out that my windows\system32\config\system is missing I don't have the disks that came with the computer do you know how i could get one?
Hi Brittany,
It may be possible to recover your config.sys file by doing a 'system restore'. Windows makes automatic back-ups to the hard drive of all neccessary files.
Click on the link below for a quick tutorial for performing a system restore:
http://support.microsoft.com/kb/306084
This tutorial is for Windows XP. If you have another operating system such as Windows 7, you will find links on the same page for Windows 7 tutorials.
Feel free to message me if you need more assistance.
Best wishes,
Graemevm
Jan 12, 2012 | Computers & Internet
Tip
How To Fixed Corrupted or Missing \WINDOWS\SYSTEM32\CONFIG
If you get the error:
Windows could not start because the following files is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
  1. Insert and boot from your WindowsXP CD.
  2. At the first R=Repair option, press the R key
  3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
    Typically this will be #1
  4. Enter in the administrator password when requested
  5. cd \windows\system32\config
  6. Depending on which section was corrupted:
    ren software software.bad or ren system system.bad
  7. Depending on which section was corrupted
    copy \windows\repair\system
    copy \windows\repair\software
  8. Take out the CD ROM and type exit
on Sep 20, 2010 | Computers & Internet
Following files missing or corrupt: \windows\system32\config\system
Well this means one of important files needed to start Windows is corrupted (it's a registry file).
I'd recommend repairing Windows installation. If you have Windows XP and also the Original Windows CD follow: this guide.
Dec 31, 2011 | Dell OptiPlex 740 (BPCW6TT) PC Desktop
All I am getting on a aspire one net-book is windows\system32\config\system error please help as I tried the alt F10 couldn't get it to work
The first step in recovering from this problem is to boot into the Recovery Console and replace the missing or damaged system file with a backup copy. To do this, you will need an original Windows XP CD, or a recovery CD from your computer's manufacturer, or a set of 6 Windows XP boot disks. If you do not have any of these, please visit our tutorial on creating Windows XP boot disks at www.schrockinnovations.com/makeboot1.php.
Once you have booted from your Windows XP CD or floppy disks, press the letter "R" at the first screen asking you for input. The computer will now ask you "Which Windows installation would you like to log onto." Each profile is represented with a number. Press the number associated with your profile (usually the number 1) and press enter. Now you will be prompted to 'Type in the Administrator Password." Enter your password and press enter (if you do not have a password to log into Windows, simply press enter).
After you enter your password (or simply press enter) you should be at a prompt that reads "C:/windows". Type the commands below to navigate to your Windows/System32/Config directory and replace the appropriate file:
  1. cd system32
  2. cd config
  3. ren system system.old
  4. cd .. (note the space after cd it is important)
  5. cd .. (note the space after cd it is important)
  6. cd repair
  7. copy system c:\windows\system32\config
If you were not able to log into your Windows profile in the recovery console, or if you were not able to navigate to the windows/system32/config directory, this likely means that the directory is gone. We have seen multiple reports of this occurring, and there is no discernible pattern that would indicate what is causing this problem at this time. This directory contains information required by Windows to boot, as well as information about your installed programs and saved passwords. If you currently are receiving the error "Windows/System32/Config/System file missing or corrupt," there is nothing you can do to remedy this problem.
Dec 10, 2010 | Acer Aspire One PC Notebook
File:\windows\system32\config\system file is missing or corrupt laptop : sony vaio
boot you computer using OS CD and at first screen use recovery console command prompt
at command prompt
wait for 10 second and the enter your administrator password
then go to c:\windows\system32\repair
the type copy system c:\windows\system32\config
press y to overright file
and restart your computer
Nov 23, 2010 | Computers & Internet
When I turn on the 1525 Dell laptop...a screen comes up saying windows could not start because the following file is missing or corrupt.windowssystem32configsystem. The page then suggests attempt to repair...
it is nothing but windows registry error. do one thing in another pc download the Hiren's boot cd from internet, write that file in a cd, try to boot from that cd & repair the registry. otherwise just format the operating system & reload the OS.
Jan 10, 2010 | Dell Inspiron 1525 Notebook
My tecra 8000 fails to boot cannot find config sys
Originally Posted by Don this problem occurs when you try to update drivers in the computer..sometimes windows XP cannot update the driver and that corrupts system.ini file as it has a lot of bad entries..Due to this you will get this error mesage..No its not due to virus.its due to an attempt to change system.ini file
Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
That means the System Registry Hive has become corrupted.
There are two ways to get back up and running. The easy way which doesn't always work, and then there is the hard way.
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console2.gif.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Aug 22, 2009 | Toshiba Computers & Internet
Windows/system32/config/system is corrupt
One of following will work:
http://www.help2go.com/Tutorials/Windows/C:%5Cwindows%5Csystem32%5Cconfig%5Csystem_missing_or_corrupt.html
http://www.techsupportforum.com/microsoft-support/windows-xp-support/312090-windows-system32-config-system-missing-corrupt-files.html
http://en.kioskea.net/forum/affich-22815-windows-system32-config-system-is-corrupt
http://support.microsoft.com/kb/307545
Mar 20, 2009 | Microsoft Windows 2000 Professional for PC
Compaq Presario 1700 PC Notebook Problem gives me a screen windows will not strat because file is corrupted or missing file is \windows\system32\config\system
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair.
missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
Oct 12, 2008 | Compaq Presario 1700 Notebook
Having problems with my compaq Persario 2500
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
md tmp
md tmp
Oct 11, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
Microsoft Windows Server Standard 2003 for PC Logo
364 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
