Question about Yamaha Digital Sound Projector YSP-800S - Five channel speaker - 82 Watt Theater System
Yamaha RX100bike in 4 gear modified it 5 gear
MyRX100yamahabike in 4 gear i modified it in 5 gear what do i
I have universal remote control philips , i need a program code for mini hifi philips
Posted on Feb 15, 2009
2006 yz250 is fine in 1,2, 4 and 5 but over revs in 3rd
Hi, Anonymous and the usual suspects are:
1. Shifter pawl improperly adjusted.
2. Shifter drum improperly adjusted or damaged.
3. Shifter engaging parts/dogs badly worn or rounded.
4. Shifter forks bent.
5. Damaged gears.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
YZ250 slipping out of gear Yamaha 2 Stroke
ProRide com
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jan 20, 2014 | 2006 Yamaha yZ 250
Yamaha 650 vstar 5 gear bogs down
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Damaged or restricted fuel tank venting system.
4. Dirty or damaged air cleaner element.
5. The accelerator pump is inoperative.
6. Vacuum piston assembly malfunction.
7. Enrichner valve is not seated or leaking.
8. Restricted fuel supply tract.
9. Plugged bowl vent.
10. Loose or plugged fuel and air jets or passages.
11. Improper float level.
12. Worn or damaged needle or needle jet.
13. Loose or plugged main jets or passages.
For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
2001 Yamaha star 650 suddenly lost power and bogged 5th gear 120km Fixxit
1999 650 engine bogs in 5th gear Yamaha Star Forum
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Jul 18, 2013 | Yamaha V Star Classic Motorcycles
Can i lower the ride height of my yamaha xjr1300
Hi, Anonymous here are some options for lowering your bike depending on your needs and how much "DRACHMA" you have in your wallet:
1. Rear shock lowering kit.
2. Front fork lowering kit.
3. Shorter rear shocks.
4. Shorter front forks.
5. Thinner padded seat.
6. Lower profile tires.
Please be aware that some of these options or a combination of options will require a shorter kickstand or your stock one modified. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Attention Short Riders How to Lower Any Motorcycle RideApart
Consider These 5 Tips Before You Lower Motorcycle
Yamaha XJR1300 2007 Service Manual
Yamaha XJR1300 Owner Manual
Aug 05, 2012 | 2002 Yamaha XJR 1300
1986 VMax is slipping out of first gear, what do I do ?
5. Damaged gears.
Jumps out of First gear
86 Yamaha VMAX VS 86 Suzuki GXSR 1100
Yamaha Vmax VMX17C 2009 Service Manual
Yamaha VMAX VMX17 Owner Manual
Apr 16, 2012 | Yamaha V-Max Motorcycles
I have a 92 fzr 600 when put in 2nd gear it pops out
Hi, Doug and the usual suspects are:
5. Damaged gears.
1992 Yamaha Fzr 1000 2nd Gear Pop Out
Motorcycle Message Board Motorcycle USA
Yamaha FZR600 service manual Download Manuals Technical $10 OEM parts for Yamaha
Yamaha FZR600L Owner Manual
Feb 29, 2012 | Yamaha Motorcycles
2005 Yamaha YZ85 stuck in fourth gear
Hi, Harjitbasi08 and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Bike won shift stuck in one of the upper gears
How to get YOUR Motorcycle out of Stuck Gear
YAMAHA YZ85 Owner Service Manual
Yamaha YZ85G Owner Manual
Jul 12, 2011 | 2005 Yamaha yZ 85
I'm looking for the fluid capacities for the front and rear drive axles for a 1985 Ford Ranger 4x4
The front differential takes 1.1 pints of hypoid gear oil, and the rear - if you have a 7.5" ring gear, takes 5 pints - if you have a 8.8" ring gear, it takes 5.5 pints of hypoid gear oil. add half an ounce of friction modifier to the front, and 4 ounces friction modifier to the rear regardless of ring gear size.
Hypoid Oil - EOAZ-19580-A
Friction modifier - EST-M2C118-A
Mar 19, 2011 | Ford Ranger Cars & Trucks
1992 Yamaha V-Max jumps out of 2nd gear
Hi, Usjansa and the usual suspects are:
5. Damaged gears.
2nd gear problem plz help VMaxForum net
https://groups.google.com/forum/#!topic/alt.motorcycle.sportbike/zs30fZIf3o4
Yamaha VMX12H Supplementary Service Manual
YAMAHA VMX12 Owner Manual
Jul 22, 2010 | 2007 Yamaha VMax
2002 yamaha vstar 1100 pops out of first gear
Hi, Gilegang and the usual suspects are:
5. Damaged gears.
Popping out of first gear
Yamaha XVS1100 Service Manual
YAMAHA XVS1100 Owner Manual
Feb 28, 2010 | 2002 Yamaha V Star 1100 Silverado
What is weak points with xs750 motor what do i need to look out for Ray.
XS750 early ones had trouble with piston rings and big ends, this was modified petty qiuck. preimary drive is by hy-vo chain, these wore out in a few thousand miles reulting in horrible vibration, chains were replaced under warranty. gear box bolt used to fall out sending you from top back to first, modified tab washer fitted under warranty. to tell if warranty work was done, dealer should have stamped two dots/punch marks in front of engine number. primary chain was modified 4 times, part number has 04 on the end. big problem now is that these were discontinued by Yamaha several years ago.... no chain....no bike! USA models had lower tune cams, UK were higher spec. engine is heavy and not much power, but a triple is the best sounding thing there is.
Aug 09, 2009 | Yamaha XS 650 F Motorcycles
Yamaha Digital Sound Projector YSP-800S - Five channel speaker - 82 Watt Theater System Logo
160 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
