Question about Hotpoint RVM1435 Microwave Oven
Black plastic catch on door snapped off, need new part
The black plastic catch on the inside of door has snapped off and the oven or microwave will not work without this. i have tried gluing but with no sucess, can i get a new part?
  • Hotpoint Master
  • 8,968 Answers
Yes. That's the door latch.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Feb 15, 2009
  • William Miller
    William Miller Feb 15, 2009
    model number
    here.
    We're
How to remove and replace microwave door key
You must remove the inside plastic door liner that surrounds the glass. It just snaps into place so usea small flat blade screw driver to pry it out. You can then replace the door key.
If the spring has detached from the door a the outer door must be replaced.
Sep 30, 2014 | Panasonic NN-H965 Microwave Oven
I found the real fix to install a new handle on a KitchenAid Kitchenaid KHMS155LSS Microwave...none have been correct until I seen this posting...it works! Use this link to see the...
Here's my standard post on getting into the doors:
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Jul 07, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I need to change the door catch, so how i take the door apart to replace the catch ??
if you mean the door hook inside the door this is quite easy you need a flat small bladed screwdriver to split apart the plastic inner part of door from the outer keep working around till you have released all the catches there are several, the inner skin will pull away revealing the hook and a spring the hook just slides out refit new hook with spring and reassemble. easy.
Jun 04, 2010 | Neff H5642 Convection / Microwave Oven
Door Handle
If at all possible try getting an exploded image break down to see what needs to happen, basically you have two things in your way one is the "choke"...the large black rectangle on the inside of the door this has to be pryed off carefully all the way around and lifted off, pocket knife works great to get it started. next you will have the front door assembly snapped onto the mesh screen and frame of the door itself. Once you have seperated the front door you will see the screws for the handle, DONT OVERTIGHTEN these screws when you reinstall.
Hopefully this video clip
Aug 26, 2009 | Frigidaire FMV156EM Microwave Oven
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Hi, how do you change the door handle on this microwave? I have a new handle.. but cant see how to open the casing
Inside the microwave door between the glass and the edge is a plastic insert called a choke. This snaps into place and needs to be removed to expose the handle screws. Microwave repairs are not for the do it your self person. They should be made by a qualified service technician so the unit can be leak check after making any repair.
Apr 24, 2009 | Microwave Ovens
Door Key Broke on Microwave Door
To replace the inner part of the latch is actually quite easy. Remove the glass tray from inside, then unplug the unit. Take to a flat surface and stand on edge so that the door will open flat. On the inside is a plastic trim that is just clipped on. Pop this off carefully and you will now see the assembly you need to replace. Note where the spring is anchored to the door before taking it apart. Put a small amount of lubricant on the guide pins of the new catch (petroleum jelly works great).
Dec 17, 2008 | Panasonic NN-T990SA Microwave Oven
NEED TO REPLACE THE WHITE PLASTIC CATCH ON NEXT TO THE CONTROL PANEL AS IT SNAPPED OFF AS MY SON SLAMMED THE DOOR
By the nature of the oven main face plate and the locking latch being attached to the safety system the replacement cost is usually higher than a replacement microwave oven.
In your case replacing the microwave with another one is more sensible. Your oven is an obscure model as it is, I'd suggest a sharp brand.
Regards,
Worldvet
May 15, 2008 | Zanussi ZM24STX 900 Watts Microwave Oven
Removing the microwave door
In many cases, microwave door panels are held together by hidden hooks or catches that ave to be separated by a thin, strong tool such as a putty knife. I've attached a photo that should serve as a good example.
Apr 16, 2007 | Neff H7871A2GB 800 Watts Convection /...
How to remove the outter door frame on the GE Microwave
You need to use the entire correct model number at their site, but you can find a helpful exploded view PDF diagram by searching for "Repair Part" at the GE parts site: http://www.geappliances.com/shop/prts/ Normally you can separate the door panels without removing the door. I've included a diagram from a Sharp model that might help. If you do have to remove the door, you have to be sure you reinstall it exactly where and how it was, or you may get microwave leakage. You should definititely mark the locations of all the hardware before disassembly.
Nov 06, 2006 | GE JVM1650 1000 Watts Microwave Oven
Hotpoint RVM1435 Microwave Oven Logo
70 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Gerry Harvey
Gerry Harvey
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
