Question about Braun M880 Multimix Hand White Mixer
How to open it to change the electric cable ?
How can I open a Braun multimix 350 Watt ? I have to rshorten the elec cable (damaged), but can't see any screw. Where are they ?
Kr,
  • 1 more comment
  • Anonymous Mar 15, 2009
    same problem for me, same mixer
  • Anonymous May 25, 2009
    There must be a way to open the Braun multimix 350 watt mixer without breaking it. What's the trick?
  • anewone May 25, 2009
    How can I open the Braun multimix 350 watt without breaking it? I need to replace the switch.
I'm looking myself for a guide to open it fully, but I can at least answer your question partly. Maybe you can get on from there.
When you look at the front side of the mixer(the side opposite to the cable), there's a slim oval lid with rounded ends. Push a small flat sdcrewdriver under that lid until it pops out, revealing a screw. Remove the screw.
The rest of the enclosure seems to be held together by several hidden plastic clips. Use a pocket knife with a thin blade and push it carefully between the halves of the case. Work your way from the screw to the top and bottom side, levering the halves apart step by step. Do not use too much force!
I'm stuck at the back of the case where the rubber ring is. I can't get this part open., but it's a start
Posted on Aug 15, 2009
I have problem with the switch - intermittent. I can open the front but the back where the cable comes out has a faceplate. It seems you cannot separate the halves until you remove this faceplate. How do you remove this faceplate? I have tried levering but cannot see any clips and fear breaking it.
Posted on Mar 22, 2010
Ou trouver un cable elec comme celui du mixer?
Posted on Feb 10, 2010
Braun 4642 Mixers user guide
http://www.user-manual-pdf.com/appliance/handmixer/braun/instruction/braun-multimix-4642-handmixer.html
Nov 12, 2012 | Braun M880 MultiMix Hand Mixer
Hello, I have a Braun multimix 220 watt, and just recently it has stopped working. The blades turn but when I try to use them to chop (eg onions, mango) they get stuck and the motor just makes a whirring...
It sounds like to scnearios are likely; First, the gears inside the mixer can brake if overloaded, and secondly the motor may be damaged. If the motor is damaged, it usually makes extra noise when running, sparks may fly, and overheating and burnt smell can be observed. If not it is probably a broken gear or two. The gears for this mixer can be obtained as a kit containing all the nylon gears and they are quite reasonably priced. You will need to open up the mixer by splitting the two halves. Spare parts can be found either from your local supplier, from braun.com online or any other online supplier of parts. Please see this link for information on how to open it up to access the gears.
http://www.fixya.com/support/t3875766-braun_multimix_280_will_only_operate
Apr 30, 2011 | Braun M880 Multimix Hand White Mixer
Braun multimix won't run on 1st and 2nd speeds--only 3rd speed.
Hi.
This problem has been covered already on this link. Please leave a comment if further assistance is required and I will do my best.
Dec 10, 2010 | Braun M880 MultiMix Hand Mixer
Braun multimixer m880 the motor has finally died,
See
http://www.smallappliance.com/product.asp?pid=5623&cur=USD&sid=18956&mid=5&gid=18978&prdCls=P&PartsPaNu=1&shopBy=Brand
(2 pages)
And you will find spare parts online for your braun which i believe is model nr 4642 (se baseplate).
You may also use braun's own spare parts finder at:
http://www.service.braun.com/product/product.asp?rg=NA&c=US&l=GB&typ=pf&frmTyp=s&grp=0&s=4642&subgrp=&des=&sgrp=s&sString=4642'HH'HH06'H'MultiMix&seite=2
But you will have to contact one of the authorised service partners to buy.
Oct 14, 2010 | Braun M880 MultiMix Hand Mixer
How does one open the case of a braun multimix 220w - i removed the screw in the front, but something else is holding it together
You need to remove the base plate by carefully prying it open at the opposite end of where the electric cord is fitted. Then release the two halves working along the edges with a thin blunt object. Also carefully remove the sliding cover for the center power mixer outlet before separating the halves.
Jan 01, 2010 | Braun M880 MultiMix Hand Mixer
Where I can get a replacement backplate for my Braun M880 mixer?
Braun Products & Replacement PartsPayPal Braun Shaver, Appliance & Dental Parts. Parts Ship Free over $60. SmallAppliance.com
Good Luck_Ned_
Nov 05, 2009 | Braun M880 MultiMix Hand Mixer
Braun M880 Multimix Hand White Mixer Logo
879 people viewed this question
Top Braun Food Mixers Experts
ray gallant
Tom Chichester
Cole Hamlin
Cole Hamlin
Level 1 Expert
Are you a Braun Food Mixer Expert? Answer questions, earn points and help others
