Question about Dell Dimension BMX Cassette hub 48h 14mmX180 12/16T 1/8 cog
When i push on the pedals the backwheel doesnt go around
When i push on the pedals of my bmx, the rear wheel cog goes around but does not move the backwheel with it, almost as though it is not connected. why is this? and how do i fix the problem?
  • 74 Answers
You my friend have a stripped free wheel.  The only solution is to get a new free wheel or just go out and get a new rear wheel all together.
Posted on Apr 13, 2009
I cannot get my chain to stop coming off. How do I keep the chain from slipping off?
Loosen the nut that holds the back wheel and pull it back until the chain is tight and then retighten the nut. If when the chain is tight, the wheel is not on the rear frame, you need to take a link out of the chain.
Jun 25, 2014 | Mongoose 20" Mode 90 Boys Freestyle Bike
Huffy boys bike makes clicking noise
does it make the "clicking" noise when coasting, pedaling or both? If it is only when pedaling, check to make sure the cranks are not rubbing on a chain guard or hitting the frame, if not then the chain is probably too tight and it is the gear cog teeth meshing with the tight chain. Loosen the rear axle nuts and slide the rear wheel forward slightly, this should take care of it. If the noise happens while coasting then one of the wheels could be rubbing on the frame intermittently, or the hub bearings could be too tight (also making it difficult for small legs to pedal) and the bearings are crushed and flattening making the "clicking" noise as they are being ground up.
Apr 21, 2014 | Huffy Pro Thunder Boys 16-Inch BMX Bike
Nishiki bravo bicycle will not engage gears when pedalling
has the cog seperated or snapped off the wheel as in can you freeturn the wheel and make the cog go around or does the wheel spin but the cog doesnt move,
if so your up for a new rear wheel/cog
Jan 28, 2013 | Cycling
Took chain off to remove wheel and am unable to get chain back on correctly. 2001 Magna oasis 26" 7 digit shifting speed. Unablew to locate manual...can you help?
Put the chain to the inside of the front cog wheel, beside the pedals, first but not onto it, so you have plenty of room for pulling the chain to the rear. Fit the wheel back into place and before tightening it pull down the spring loaded arm, with the small cog wheel beside the back wheel. This takes the tension off the chain and allows you to put it into place on the back wheel. Tighten up the wheel. When it's tightened fit the chain onto the top of the front cog wheel. Lift the back wheel off the ground and turn the pedals forward. The chain will click onto the front cog wheel when you have turned the pedals one complete turn.
If you need to see a picture of how it should look at the back you can see one at http://orangecounty.craigslist.org/bik/2409696114.html
May 29, 2011 | Cycling
While changing rear tire, my deraileur came off. The chain seems to be snarled up. I don't know how to ge the deraileur back on correctly. Thanks for your help.
With the wheel off remove the two pins which locate the guide wheels on the deraileur. Take off the guide wheels and the guide plate. Now straighten the chain and unwind the snarled area. Locate the chain around the smallest cog wheel on the back wheel and mount the wheel to the bike. The chain will hang slack. Now mount the upper guide wheel and guide plate to the deraileur making sure that the chain feeds off the rear cog and passes around the guide wheel towards the front of the bike. Push the deraileur forwards relative to the chain and slip the lower guide wheel in between the guide plates and pushing the chain back in the guides & fasten with the pin. As you reassemble the plates and wheels on the deraileur be sure to observe carefully which way the chain is running. It is quite logical and this should prevent mistakes being made
Oct 03, 2010 | Mongoose Exile 26 Men's Full-Suspension...
I need to know how to take a chain off without breaking it please
Pull the chain out slightly, away from the bicycle frame, at the bottom just behind the front cog wheel (attached to the pedals). While holding it out turn the pedals backwards and the chain will come off.
Sep 04, 2010 | Huffy BMX 20" Boy's Rock It Bike
THE CHAIN RIDES OVER THE LARGEST REAR COG,AND DOESN'T CHANGE DOWN TO THE SMALLEST,CHANGING UP TO THE LARGEST COG,IT IS ON IT AND STILL ANOTHER GEAR CHANGE TO GO
This one's easy enough.. If you move the derailer through it's full stretch you will see that part of it will be blocked in each direction by a small screw. These screw adjusters are to stop the chain from running over the end gears, and sometimes if they're too tight they can stop the chain from reaching the gears in the first place.
A small screwdriver is all you should need, turn the bike upside down, loosen these screws completely and then change gear to one end first until it runs smoothly on the chain and then do the same with the other.
These are designed to be adjustable so you can add or remove gears/change wheel sizes etc and then readjust to run smoothly..
Hope this helps..
Oct 12, 2009 | Shimano XT M772 Shadow 9-Speed Rear...
My rear chome whheel squeeks when i break
Thats a sign that you need your brakes checked or adjusted.
Jun 09, 2009 | Dell Dimension BMX Cassette hub 48h...
Front cog does not rotate when pedaled
You will have to remove the rear wheel and take it in to a bicycle shop and have the rear cog replaced. The freewheel part inside it has likely broken and will only rotate in both directions. It should rotate to back pedal and then catch as you pedal forward.
Apr 08, 2009 | Freestyle Cycling
Slipping while cranking
The rachets in the rear gear cog have gone bad.  Buy a new gear cluster and have it installed on your rear wheel.  about $30
Mar 26, 2009 | Mountain Bike Bmx Fit Gt Haro Chrome...
Dell Dimension BMX Cassette hub 48h 14mmX180 12/16T 1/8 cog Logo
182 people viewed this question
Top Dell Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Dell Cycling Expert? Answer questions, earn points and help others
