Question about Metra 1986 93 Ford/Mercury/Mazda Vehicle Wiring Harness
New alternator not charging battery
Wiring diagrams or information on charging system on my 86 ford ranger pick up, 2 wd. 2.9 v6.
  • syph Apr 17, 2009
    im having the same problem any answers out there. i have a 99 f-250 super duty 2 wheel drive with the 5.4 in it.tried everything i can think of besides tracing wires.too dark for that now
Where is the in line fuseable link located on a 94 ford ranger 2.3 motor
    Alternator fuse link repaired my way. - YouTube
    ? 2:10
    https://www.youtube.com/watch?v=xgJQXKESDcI
    Dec 24, 2013 - Uploaded by Potskie
    I had the exact same situation with my ranger. ... I found thefuse links for the charge or alt output but not the one I ..... In line fuse, battery, or alternator? ... Of Key-Off Battery Drain (Parasitic Draw) - Duration: 18:14. by Motor Age.Missing: 2.3
    Fusible links and inline fuses? - Ford Truck Enthusiasts Forums
    www.ford-trucks.com/forums/885708-fusible-links-and-inline-fuses.html
    Sep 17, 2009 - Location: Kuna ID ... The PO had replaced one of the fusible links with an inline 30amp fuse. .... 81-F-150-Explorer is a splendid one to behold .... to charge the battery goes through that link when needed, and/or the battery to the other components when the engine is off. ... 91 ford ranger 2.3 daily driver 1994 Ford Ranger XLT 2.3L man. trans. - Ford Truck ...
    Jul 6, 2014
    86' Ranger cutting out!!! Fuel ? - Ford Truck Enthusiasts Forums
    May 10, 2012
    90' 302 fusible link for fuel? - Ford Truck Enthusiasts Forums
    Nov 2, 2010
    1988 ranger headlights won't work??? help - Ford Truck ...
    May 17, 2009
    More results from www.ford-trucks.com
    Missing: 94 images for Where is the in line fusible link located on a ...
Dec 30, 2015 | Ford Cars & Trucks
Need diagram of charging system for 86 buick electra 3.8 v6
Running should be around 14 something volts. Sounds like your charging system is not working. 1986 MAY have a separate voltage regulator.
Feb 12, 2015 | Buick Cars & Trucks
New starter and battery and alternator 2002 ford Taurus, car will not take a charge. Took the battery post off car cuts off. Tried 2 junk yard alternators and bought a one from Auto zone for 200 same...
Taking the battery off a running engine will cause voltage spikes that can easily damage electronic parts, computers and such. Should never do that on modern cars, Ashley.
There must be a maxi fuse or a fusible link or even an in line fuse between the alternator and battery, if it's not charging. To fix it yourself, you may have to get hold of a wiring diagram for the charging system.
You can register for free at autozone.com, giving your make, model, year, and engine size. Quite a lot of repair information that is specific to your Taurus, including wiring diagrams. Look under the repair guides section, I believe wiring diagrams may be listed under "Chassis Electrical". Good luck.
Sep 08, 2013 | Cars & Trucks
How do i wire an alternator on my ford sierra 3.0l v6 from ignition to bat i need a diagram
We ca't supply a diagram. You might check with a local library for an auto repair manual with wiring diagrams
Apr 21, 2013 | Cars & Trucks
My 93 ranger is not holding a charge i replaced the battery the alternator the plug that goes into the alternator but still just drains the battery my ignition where the key goes is loose but i wouldnt...
If the ignition switch is effected by the loose
key cylinder ,it may play a role
You need to check out the switch
and look at a wiring diagram to see
what role the ign sw plays, with grounding
the alternator regulator,if it does
Put an AMP Meter in either battery cable
to check for excessive drain
Apr 22, 2011 | 1993 Ford Ranger SuperCab
1996 Ford Ranger/Alternator shuts off and runs only on a battery
Fusible link blown ? With a voltmeter check for B+ voltage at the heavy gage wire on the back of the alternator .Is the charge indicator light lit on the instrument cluster . Do you know what a wiring diagram is ? Free wiring diagram here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine size. Under system click engine ,then under subsystem click charging . Click the search button then the blue link . Watch video on youtube checking alternator electrical .Power & ground !
Functions of an Alternator in vehicle
How to Test an Alternator
Oct 10, 2017 | 1996 Ford Ranger SuperCab
Ignition wiring
firingorder6a.gif firingorder6.gif 1991-1994 2.9L and 3.0L Engines Firing Order 1-4-2-5-3-6 1995 And Later 3.0L V-6 With DIS Ignition System Firing Order 1-4-2-5-3-6
4.0L Engines Firing Order: 1-4-2-5-3-6 DIS Ignition System
Nov 22, 2008 | 1995 Ford Ranger Supercab
Generic Electronic module.
The gem is behind the dash in the center, behind the radio. It controls whipers, anti theft, 4x4, cargo lamp, insterment cluster, plus a few other things. Hope this helps.
Oct 07, 2008 | 2002 Mazda Truck
Charging system
change your battery cables and check all wires on the alternator for loose connections, expecially the grounds.
Oct 02, 2008 | 2000 Ford Explorer
Charging alternater wire gets hot and archs
yep the regulator is stuck open replace it
Aug 26, 2008 | 1985 Ford Ranger
Metra 1986 93 Ford/Mercury/Mazda Vehicle Wiring Harness Logo
441 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
