Question about Frigidaire FEF352 Electric Kitchen Range
Gravy spilled between the glass on the oven door
I have a crosley range with the self cleaning oven. I had a gravy over-flow on the top of the range and it dripped into the vents on the oven door and consequently is sandwiched between the outside glass and the inside glass of the oven door. How do I take the glass off the door to clean this. It is such a mess and we are afraid of breaking the door latches. We tried to remove the door but there seems to be some sort of lock that stops us from pulling the door all the way out of the slots. Can you please advise.
Thank you
Donna
How to take off the front door
Posted on Feb 15, 2009
OUR HOME WE BOUGHT CAME WITH A RANGE, BUT NO MANUAL, WHERE CAN I GET A COPY OF THE MANUAL FOR THIS RANGE?
You will need to find the model number to get a manual. http://www.geappliances.com/service_and_support/literature/ provides a search box for looking up the manuals. For GE ranges, the model number could be in several places: on the frame behind the warming or storage drawer or kickplate, on the left leg behind the warming or storage drawer or kickplate, on the frame of the oven behind the door, under the left front surface burner, or under the lift-up cook-top at the center or on the right hand side.
If you clean the oven with non-abrasive products and avoid the spray on oven cleaners, you are unlikely to damage the surfaces/range even without the manual for your range. (Use glass cleaners for glass cook-top.) Warm water mixed with a mild detergent is useful for most spills. Avoid cleaning the seal around the oven door; damaging the seal may cause major problems.
I hope this helps.
Jan 27, 2012 | GE Kitchen Ranges
Food spilled between the two pieces of glass on the door
careful when cooking. u have to take the dor apart to clean this
Feb 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Range Glass
Yes you can. You should be able to remove the screws on the inner lip of the oven door and remove the outer panel/glass so you can clean up the gravy. Be very careful doing this because the panel can be heavy and the glass can break if you drop it.
Jan 16, 2010 | Kitchen Ranges
Spill between glass panes on oven door
The only way to clean this is to dismantle the door. Most brands you can remove the door and set it on a counter to dismantle. This can be very complicated, depending on the brand and model. Leaving the gravy inside the door won't hurt the range, and self cleaning usually will not clean this completely. It usually just bakes it on harder. Good Luck Appliance Specialists
Dec 31, 2009 | Kitchen Ranges
I spilled gravy between the glass door of the oven. Can I clean between the glass
yes but will involve removing the door and taking it apart to gain acess
Oct 08, 2009 | Kitchen Ranges
Frigidaire double oven - stove top oven had a spill. The spill went through the bottom oven's door vents and is now in between the glass and I cannot get to it to clean. How can I get this glass clean?
I had a similar problem with a spill running into the vent and between the glass. I had to take the door apart clean it and then put it back together. It sounds hard, but it was just a few screws and a little time.
Jun 27, 2009 | Kitchen Ranges
Spills in between glasses of the oven door.
The door must be taken apart at least most of the way to clean glass. Just so you know, this is a problem with a LOT of the newer makes and models. If there are 2 screws behind the handle, take them out and some of them come apart enough to get your hand a paper towel in to clean. Otherwise, the door must be removed and completly diss-assembled.
Mar 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Cleaning glass on oven door
The marks may be on the inside part of the glass. If so then the door will need to be taken apart for cleaning. You can use a razor blade scraper and glass cleaner to soften the buildup. Self cleaning won't remove if it is on the inside.
Oct 01, 2007 | Crosley CE35100AA Electric Kitchen Range
How to take apart oven door
you need to remove the door. On your model just grab the door and lift and it should lift right off. Then remove the screws that run along the bottom of the door. Remove the bottom trim and the glass should slide down and off. Reverse to assemble
Jun 18, 2007 | Maytag MER5775Q Electric Kitchen Range
Frigidaire FEF352 Electric Kitchen Range Logo
435 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
