Question about Teac P-988 Turntable
Problems with weights on turntable arm
Ive just bought a vintage teac px-500 and am having trouble setting up the arm, it has 2 adjustments and i cant seem to get them right. help!
  • Anonymous Mar 31, 2009
    The arm slides across the record and I think it might be the weights. How do I fix this?
  • 104 Answers
Http://www.turntableneedles.com/FAQs_ep_33.html
found instructions above.
scroll down to
"How do I adjust tracking pressure and anti skate?" under the section of "OTHER"
Posted on Feb 16, 2009
My Aiwa px e860 record player arm is too heavy how do I adjust it?
If you put the maker and model number into Google you will find a service manual free for the make. That should help you sort out the problem. It's just a question of getting the weight at the other end of the arm adjusted right.
Dec 11, 2016 | Aiwa PX-E860 Turntable
My tone arm has suddenly started skidding across the record surfaces. Its a brand new turntable and was fine till yesterday !!!
Generally the cause is one of 3 things. 1 Damage to the stylus or dirt. 2 Lack of pressure to the stylus. 3 Anti-skate control set to low.
First check the stylus you should feel it sticking in you finger a bit. 2 Has the weight on the end of the arm become lose? Adjust for the correct tracking weight of the cartridge. 3 Check the manual for what the anti-skate control should be set to.
Feb 23, 2011 | Technics SL-1200 Turntable
Arm and needle skate across the record and no sound comes out. looked at another question regarding this same problem and the response was a possible problem with the stylus or the weight setting. but how...
The stylus should either just clip out or slide out depending on the type of cartridge fitted. On the weight thing look at the other end of the arm. It should have either somekind of screw or a weight with numbers on it. Slacken the weight and move it so the head where the cartridge is gets heavy. If it has numbers turn it to around 2 or 3 or higher and test/adjust using a record till it plays and doesn't make too much rumble sound when playing (in the gaps with no music) with both types of weight.
Aug 10, 2010 | Teac SL-A100 Turntable
The arm and needle just skate across the record?
Either a bad stylus or the weight on the tone arm needs setting for the cartridge used.
May 28, 2010 | Teac SL-A100 Turntable
Tone arm skipping records.
The anti skate adjustment. And if you scratch @ all....move the weight all the way in and take off the little extra one that screws in on the back. Also a great tracking needle is a M44G.
Mar 03, 2010 | Technics SL-1200 Turntable
When I put an album on it skips for the first few songs then plays fine. The records are not warped. could something be wrong with the turntable. It happened with 5 or 6 albums I tried.
HELLO
Make sure you have the deck set up correctly! Check the headshell - is the cartridge out of alignment or is the stylus worn?
Also, it may be that the counterweight is set too lightly for the cartridge and check the anti-skate control as well (example if the arm is tracking at 2 grams, anti-skate must be set at 2).
Follow these instructions for setting the counter balance:
Turn the weight so that the arm is just floating then set the balance ring (with the numbers on) you will see there is a line. Turn the ring not the weight to the ZERO mark where the line is on the top of the arm. Now turn the weight and ring together where it moves forward down the arm and set it at about 2 grams.
Now set the arm using the height adjustment that is the ring fitted to armboard and make sure the arm is straight (if not, the stylus will mistrack). Now try the deck again. You might have to make adjustments to the tracking weight again so whatever you have it set to, set the anti-skate to the same!
Good luck with it (:-)
Nov 14, 2009 | Gemini SA-600 II Turntable
This is a question for my daughter who lives in Japan. She has a Crosley turntable she bought from Urban Outfitters. The stylus arm has suddenly started skating over the record, ie won't play anything. ...
I have no experience of Crosley turntables, however, stylus arm skating across the record surface on any turntable is normally due to the counter balance weight being incorrectly adjusted. In order to track across a record properly, the stylus must press down on to the record very lightly. If there is too little pressure, skating is what tends to happen. Too much pressure can cause distortion of the sound and excessive wear of the record.
At the pivoting end of the stylus arm, there should be a counter balence weight. This is normally adjustable (but not always - depends on quality and features of the particular turntable), and is used to set the pressure the stylus applies to the record surface, measured in grammes. The manual that came with it should tell you how to adjust it, but for most turntables stylus pressure is between 1 to 3 grammes.
If you dont have the manual, have a good look at the pivoting end of the stylus arm to see if soemthing is obviously wrong, or if not whether there is something with numbers on it that can be turned or slid. This is likley to be the counter weight. Try adjusting it.
Within reason, the stylus weight isnt critical so a "trial and error" approach wont do any harm.
Nov 12, 2009 | Crosley CR249TA Turntable
Pdx 2000 stylus calibration
Hi Misskit , i have a Dual turntable straight arm [Dual is the brand ] maybe you could visit their website and see if there is something similar to yours that you could get some specs from , i think they are still in business they are a German turntable manufacturer . happy spinning
May 24, 2009 | Vestax Pdx2000 Direct Drive Turntable...
What is tracking force and arm weight for Dual 505-2 deck?
http://ortofon.de/ should give you the weight. It should also give you the range of tracking force. To get the right weight you can use a stylus balance. The electronic ones are expensive but good. The mechanical ones are not great but better than nothing. I set my turntable up with an Ortofon-branded mechanical balance for weight, and a test record for tracking force.
Apr 09, 2009 | Audio Players & Recorders
Teac P-988 Everything sounds slow/warped
not passing the "wow and flutter" specs, eh?
The most common cause of this is a loose or defective belt. An inferior belt will have varying thicknesses along it's length. When it hits a skinny part, it will slow slightly. When it hits the thick part, it will speed slightly. Overall effect is that the record sounds warped.
needledoctor.com has got some good stuff.
Jun 12, 2008 | Teac P-988 Turntable
Teac P-988 Turntable Logo
254 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
