Question about Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive
Hi!! my usb 4gb was corrupted and unreadable. .i need help
It cannot be scanned, can't be open.
  • randao_09 Feb 15, 2009
    i tried it and how to operate???
First of all check whether it is showing in disk management(Right click the "My Computer " and go to Manage )
Posted on Feb 15, 2009
My 64 G PKNY disc is giving me an error of corruptable and cannot be read. Can I retrieve this files I must have them back
You can try using a file recovery software like Sony 4GB Memory Stick PRO Duo. Once files are recovered, please format the drive to fat32 file system. It will then be blank, ready to write files back to it.
Jan 23, 2014 | Electronics - Others
Firmware update 4gb
at the command prompt type chkdsk X: /f /r where X is memory card.If it doesn't work download the recovery tool here http://freeware-fix.blogspot.com/2013/04/usb-drive-is-unreadable.html
Aug 09, 2013 | SanDisk 2GB microSD Memory Card
Hi, My pwndrive has got some problem, It copies the files properly , and if I put the same in other system , I cant copy any files it says that files are corrupted . There is no virus , becoz I scanned...
When you get a message that a file is 'corrupted' it does not necessarily means that there is a virus. The 'corruption' could be that the drive is damaged and the file had bits of it stored in damaged sectors and hence the file is unreadable, incomplete or... corrupted.
Once you store a file, are you able to open it in the same computer you copied the file from? If so, the problem might be in the 'other system' Do you get error message from that 'other system' only? Could be a loose USB port, try another USB port or another computer to narrow down what the problem is. Hope it helps.
Dec 17, 2017 | Computers & Internet
My SanDisk Cruzer Gator 4GB is not working. When
The filesystem appears to be corrupted. Try right-clicking the drive's icon, going to Properties, Tools and Check Disk. If that doesn't help the partition that holds the data may be unreadable, and if that happens try asking a data recovery service if the data is important.
Jul 12, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
The directory is corrupted and unreadable
The most common cause of this is removing the USB drive without clicking "Safely remove hardware" in the task bar. Especially if data is being written to the drive, this can result in corrupt files and may make the drive unusable.
I'm sorry to say the data may be unrecoverable--ALWAYS make backups!
Two things to try before you write-off the data as lost forever.
One: Try booting the computer in SAFE mode and see if you can pull files off the USB Drive--you may have to give the drive administrative privileges.
Two: Download and run the trial version of the BadCopy data recovery program at this link:
http://www.jufsoft.com/badcopy/
To make the drive usable again, find it in My Computer, RIGHT click on it and click "Format." The choose "Quick" format. A quick format should make it usable again.
If the BadCopy program could find no files to recover: After the quick format, you may be able to pull some of the files off simply in windows. If not, run BadCopy again: It just may find some files after the quick format.
A full format erases ALL data which may remain on the drive. Only use quick format if you expect to recover anything.
Good Luck!
Apr 05, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
Sandisk 4gb micro SD with adapter is "unreadable"
Certain cameras will not recognize an SD card because it is SDHC. The format was created after the camera. Camera vendors do issue firmeware updates.
Hope it helps.
Aug 27, 2009 | SanDisk 4GB Secure Digital High Capacity...
About my seagate 160 gb hard drive (external)
i hav usb seagate 160 gb hard disk.nw it is nt getting open message is the file or directory is corrupted or unreadable........CHKDSK is also not working for it.error is "unable to determine volume version and start"....plz help fast
Jul 26, 2008 | Seagate 160GB 3.5" External USB Drive 160...
External hard disk unreadable
Your hard-drive is crashed and unreadable by win32.dll what you can do is try kick starting by using your friend computer it just might do it. I had same problem and I asked my son to using my hard-drive on his PC. It worked and still working. good luck
Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive Logo
1,570 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
