PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Not able to write dvd on my len...
By drvikasgoswa on Feb 14, 2009
i used both the cybrlink power2go 6 and nero 7 but not able to write a dvd... though can write cd.. the drive in my system is MATSHITA DVD-RAM UJ 85JS.. with power2go it shows unspecified error and with nero shows power calibration error
Same Problem
Feb 27, 2009
-   aloha to de all the geeks hu are present over here.. please help me out to solve this prob man.. cuz m not able to write a dvd on ma laptop.. though i can write a cd but not DVD... so pls help me out n if u ve ne solution than please send me on below email address...
pmpatel129@gmail.com...-   pmpatel129
Solution #1
posted on Feb 14, 2009
Not Rated)
Wodan
Rank: Guru
Rating: 92%, 30 votes
A power calibration error is caused by the inability of a DVD-RW drive to use a DVD-R or DVD-RW disk, it first writes a bit of a data on the DVD then uses it to calibrate itself for the position of the lines. This however can be caused by a number of reasons, so try the following options one after the other, If option 1 does not work, go to option 2, etc.
1:) Matshita has problems with some cheaper brands, get yourself a very known brand DVD as a test like pioneer or tdk
2:) Using a higher speed than the media is meant for, try lowering your burning speed in nero, try the lowest even, let's see if helps
3:) You have a Lenovo as you say. If it comes with Sonic, please uninstall Sonic first, then uninstall nero, then install nero again. Sonic and nero tend to conflict. But even if you do not have Sonic, reinstall nero and apply all new patches.
4:) If option 3 did not help, update the firmware, that helps in a lot of cases.
5:) If even option 4 did not help, disable IMAPI Service (Work's in most cases):
- Launch Control Panel -> Administrative Tools -> Services .
- Browse for "IMAPI CD-Burning COM Service", Right-click on it - and select properties.
- Change Startup Type to Disabled.
- Click Apply and Reboot.
6:) The burner lense needs cleaning, please don't attempt this at home if you are not a mechanic, take it to service they will clean it.
7:) Drive failure, or drive burning out -- then it needs to be replaced, if none of the above helped that is.
If you overlock your computer that can also cause this problem but since you use a laptop I assume you did not overclock it. Let me know if any of the above helped and what the results were.:)
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
How to choose a ebook reader.Comparison of performances between different models
Answer
error code 39 showing, driver does not show on computer
Answer
every time i start it up it goes to a blue screen then just keeps resatating
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
