Question about Refrigerators
Can't remove broken refrigerator shelf studs
My mother has a 20 year old Kenmore refrigerator. Several of the shelf studs broke - I was able to find the replacement stud; however, I cannot get the old stud out. I've tried to pry them out, and I've tried using a wrench as well. Any suggestions or tricks of the trade? Thank you in advance to all who respond.
  • henderson526 Feb 15, 2009
    Well, mom is 82 - it's not likely she'll be buying a new frig anytime soon, unless its absolutely necessary. Other than the broken shelf pins, the fridge works just as good now as it did the day she bought it....
  • Anonymous Mar 24, 2009
    kenmore shelfs don't fit the fridge and keep falling off-a big mess
    how can I keep these shelfs tight and secure?
I had the same problem and used a pair of pliers to twist the broken shelf stud 90 degrees and it pulled right out with minimal force.
Can you respond with the link of where you found the relacement studs as I haven't been able to find one yet. Thanks.
Posted on Apr 02, 2009
    Genius:
  • 2,920 Answers
Maybe its time for a newer fridge for ***********?
Posted on Feb 14, 2009
Jbl 75815 stud broke
First, it really depends on your car model. normally its easier to replace broken stud on the rear disk than the front if your car is a rear wheel drive. On the rear, the moment you remove your tires you only need to initiate impacts on the disk to loosen it and after removing the disk you can hammer the broken stud to dislodge it from its fitted hole then pressure fit the new one in place by hammering it in unless you have a machine that can do it. On the other hand, replacing broken stud on the front requires you more efforts as you need to detach other items like the disc plate cover, and if necessary dislodge the spindle assembly from the velocity joint to create space for the broken stud to be removed from its hole.
Aug 02, 2014 | JBL 2447H Driver
My mother in law has a kenmore dryer that is 15 - 20 years old. It will start but the dru will not turn she says it does not have a broken belt
Verification of the belt in place would first need to be done, then check to see if the motor is running.
The belt could have jumped off
if the belt was replaced recently, It might not have been the right belt.
Oct 06, 2010 | Kenmore Dryers
What is the clunking noise made after the refrigerator stops running? Its a Kenmore and is 10 yrs old. We have thoroughly cleaned behind and beneath the refrigerator and now the noise seems louder.
The clunking noise you hear , is probably when the compressor shuts off , due to temp reached or when it goes into defrost . An internal motor mount spring , inside the compressor , is broken ( rusted and broke ) . The refrig can go on working for years , without any problem , except noisey , when it cuts off . To stop the noise , replaceing the compressor is the only option . I have heard of placeing objects under 1 leg of the compressor , to " re-adjust " the ballance , but thru my experience , another spring broke , causing more knocking .
Mar 24, 2010 | Kenmore 64802 Top Freezer Refrigerator
Does the wheel barring have to be replaced when the stud is broke
If you use a hammer to drive the broken stud out you can cause damage to the bearing.
If you use a wheel stud press, the hub bearing will not be affected. The press will remove the old stud and install the new one.
Good luck.
Regards,
Aug 18, 2009 | Honda Civic Cars & Trucks
Broken wheel stud
1. get new studs and nuts
2.remove wheel
3. remove caliper at bracket to spindle connection(2 18mm bolts?)you may need to remove caliper from bracket,but not always nessacery. Or remove drum,then to #5
4.remove rotor,will need a hammer, tap inbetween studs dont wreck good studs and see if new studs can be installed without removing parking brake shoes. If there is no clearance to get new stud in you will need to remove shoes.
5.Pound out old studs place new stud in hole use a washer on outside then put a nut on and tighten to install stud, A air gun or some type of impact tool will be very helpful. Check to see that stud has enough threds to pull stud all the way thru ,add more washers if nessecary dont let the nut run out of threds it will **** to get back off and wreck new stud.
6. if you dont have air gun or feel comfertable removing brakes bring it to a reputable garage, shouldnt cost more than $70+ parts to get all new studs put in on one wheel.
May 17, 2009 | 2002 Nissan Sentra
Jenn-Air Refrigerator JSD2789AES broken shelf support studs
part number is AP4069509 this fridge is such ****! i still need three parts
Dec 24, 2008 | Jenn-Air JCD2389G Side by Side...
Broken refrigerator drawer support pin
I have a Kenmore 2 door,freezer on bottom, mod# 795.77309600,the shelf that holds the crisper draws cracks,front & back corners, also the back,middle. this is the 2nd time for me. Is there a solution??
Nov 24, 2008 | Refrigerators
Kenmore 20 porcelain plus refrigerator
5' 6" Tall
32 1/2" Wide
28" Deep
I bought that old fridge at a garage sale for cheap. It's been enjoyed for me for just over a year. :)
Jul 17, 2008 | Kenmore 64802 Top Freezer Refrigerator
Broken cd player
The motor is last thing to gone before you go to service check the rubber belt which connect the motor to the door gears.Your set is 20 years old and this should be the problem and easy to fix
Feb 07, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
Broken shelf
Lenabs,
I was able to find the shelf I needed by typing the brandname and the fridge model number online and I got the number of the part I needed from a diagram but the bad news is that it was aver $40 per shelf and it was just a piece of plastic. The new one would be just as weak as the old one. I finally decided to add some strength to the existing shelf with some hardware store aluminum and glued it on with some JB Weld. I suggest you take the broken plastic piece in with to an ACE hardware and you will be surprised how many pieces of precut shiny aluminum are there for the having.
You can use that JB Weld to join the parts and make them stronger than new. Let me know if you need some more help.
HarryF
Oct 12, 2007 | Danby (DAR604BLS) Refrigerator
Refrigerators Logo
486 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
