Question about Garden
Need McCulloch Eager ****** 200A Brushcutter piston rings
I've just replaced the drive shaft (AUD$70) of my McCulloch Eager ****** 200A Brushcutter only to now need a new piston ring. Any ideas where I can get one in the Sydney area? Cheers
5 Suggested Answers
boscia
  • 163 Answers
SOURCE: Ryobi TP30 straight shaft line trimmer convertible - drive shaft disconnected from motor
check both ends of shaft, they're usually a hex or torx head. sometimes the can strip or even snap off. if you find noticable damage replace the shaft
Posted on Nov 29, 2008
  • 1341 Answers
SOURCE: Do I need Special grease for Brushcutter/Trimmer shaft
No grease is grease but there is sillicone used nowadays as it just looks clean to use. Now check if it does use some kind of oil in the system.
Posted on Aug 03, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I own a mcculloch mt270x and it will not start.
Hi stevej31...
Screw you idle screw in to about 1/2 to 3/4 turn open from seating to the bottom of the threads...spray a little starting fluid into the carburetor and try to crank it again.
Did you use compressed air to blow out all passages in the carburetor? If not then do it, because dirt and debris will plug your air/fuel passages and cause the weedeater not to crank.
If you have to rebuild your carburetor then I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Sometimes the diaphgram may look good, but be a little too stiff to act properly as the fuel pump.
If the machine is over a couple of years old then...I highly recommend that you rebuild your carburetor completly
Please take time to rate me
Posted on Jun 29, 2011
Testimonial: "The info was helpful.Will try the solution suggested"
  • 2239 Answers
SOURCE: how do I compress piston rings ,when replacing piston in ryobi brushcutter?
Buy a small set od plastic ring compressors, they are readily available from small engine shops.
Posted on Aug 10, 2012
How do I compress piston rings ,when replacing piston in ryobi brushcutter?
Aug 08, 2012 | Ryobi 15" Electric Factory Reconditioned...
How do I replace piston in ryobi brushcutter
they make a tool to compress them then push the piston down and install the pin and clips
Aug 08, 2012 | Ryobi 30cc 17" String Trimmer Zrry30530...
Looking for engine parts for an old mcculloch eager ****** weed eater. where can i find them? need to buy a new fuel tank and fuel lines
I assume you mean edger, not eager.
You must have the model number to find anything. You can go to the Mcculloch web site.
http://www.mcculloch.info/node1092.aspx
Here is an example of a parts list for one of their edgers maybe you're lucky and this is the one you need.
http://weborder.husqvarna.com/order_static/doc/MIPL/MIPL1994/MIPL1994_mtt2380g.pdf
Jul 25, 2010 | Garden
Chain oil pump does not work when pumped. Eager ****** MAC 100 series
Your Eager Beâver model number is 600016. There are many prefixes and suffixes. The one below I used when repairing a similar problem with my Mac 110 (earlier version of your saw). Both the automatic and manual oilers work now.
I get the best results for new McCulloch parts here:
This is a little complicated so I am going in small steps.
M & D Mower
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “18-600016-27”
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
See “General Assembly” print
Item 33; pn 85557; Oiler body; most likely failure, on bottom of Item 31
Item 31; pn 217755; manual oiler piston; It pulls through the top of the tank. I ordered a new one but got Item 36, they were the same pn, I complained, seems they fixed it.
See “Powerhead Assembly” print
Item 07; pn 219989; oil pump assembly
Item 04; pn 217168; pump/bar pad connector (hose)
Item 05; pn 217167; pump/oil tank connector (hose) The new one was to long, I used the old hose. I have an earlier model.
Item 17; pn 110653; O-ring
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 06, 2010 | McCulloch Garden
Where do I find a replacement chain for my McCulloch Eager ****** 2318av chain saw (model # 600038-12)?
Your friendly neighborhood chainsaw shop can fabricate one in about 5 minutes. Take your existing chain for use as pattern.
McCulloch.com
http://www.ordertree.com/modelinfo/MCC/11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318/139.11-600038-12-EAGER-******-2316-SUPER-06%2F93-to-05%2F96-IPL-211318.1.59.1.html
If original 18" bar.
part number(pn) MCC 21927533
Oregon Bar & Chain Selector (again original 18" bar)
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Your saw with 18" bar returns
Oregon pn 91VG060G.
This can be easily crossed to other manufacturers chain. You might consider a more aggressive chain (dependent on your level of expertise). HTH
Lou
Jan 20, 2010 | McCulloch Garden
I want to buy the crankcase assebmble and rings from promac700 chain saw April 1979
Construct an IPL number as follows:
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
I used 11-600061E (may not be your saw) and found
This is a little complicated so I’m going in small steps.
Click “11-600061E”
Click “Powerhead Assembly”
Cylinder-Crank Case Assembly (item 88)
pn-214671 $110.09
Set-Piston Ring (item 99)
pn-89732 $15.50
There is a shipping and handling charge from M & D if all parts in same container only one fee.
I’ve found McCulloch parts here I can get no where else and they are reasonable.
Please ensure these are the parts you need. HTH
Lou
Dec 21, 2009 | McCulloch Garden
Did mcculloch manfacture the same piston rings for all their 38cc saws? I have a broken piston ring and cant seem to find one or the part #. Mcculloch MS1838AV 38cc
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple. On the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I’ve found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Operator’s Manuals: are much more difficult. I’ve dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322 HTH
Lou
Nov 17, 2009 | McCulloch Garden
Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 28, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
