Question about Integra Dacor Ii Dry Snorkel Lowest Price Dry Snorkel
Dirty snorkel tube
Snorkel accumulates black mold in the tube. How can the tube be cleaned
  • 19,396 Answers
If the mold is much you can leave the snorkel soaked in lemon juice or 50% isopropyl alcohol solution.
See also the suggestions below:
Caring for Your Mask, Snorkel, and Fins
What's the best way to clean new snorkel
Posted on Feb 14, 2009
Where is the MAF on a 2002 Ford Fusion 2?
The MAF sensor by its nature must be between the air cleaner and the throttle body. Look along the snorkel tube for a pigtail from the wire harness. That should be the Mass Air Flow sensor.
FYI: There is a special MAF cleaner spray available at NAPA and other retailers. USE IT. Good luck.
Oct 02, 2016 | Ford Cars & Trucks
How to clean a throttle body on a 2006 gmc envoy
take your air snorkel tube off at throttle body and pull back out of way, then take a rag and soak with throttle body cleaner, carb cleaner, or brake clean...they all work well, then reach inside the housing and open throttle plate and start rubbing the gunk off inside the throat of throttle body and throttle blade till all is clean, will take several times to get all clean. when all done put snorkel back on BEFORE starting vechile or you will have a service eng. soon light.
May 20, 2012 | 2006 GMC Envoy Xl
I run my washer through the clean cycle with bleach every month. However, the fabric softner compartment is very dirty with black mold. How can I clean it?
I run mine with vinegar in the softener compartment when I do the clean cycle. You might want to add bleach into for it to kill the mold. When I had to have service done to mine, I asked the tech. how I could clean them and that is what he told me to do.
May 28, 2011 | Maytag Bravos MTW6600T Top Load Washer
I have 2000 F-Taurus, my problem is that every times I stoped at the stop lioghts, my car didn't idle.
Check for a vacuum leak at all vacuum hoses. Be sure can check the large hose going to the power brake booster on the firewall.
Mar 30, 2011 | 2000 Ford Taurus
How do I clean my hydroair LX snorkel? I'm seeing
I use baking soda, warm water and bottle brushes for pretty much anything that goes near my mouth. My hydration bladder gets that treatment often especially after a long trip, as has my snorkel a couple of times. You could try find a platypus or camelbak cleaning kit at your local outdoors store.
Oct 31, 2009 | U.S. Divers Grande Vista LX Mask with...
Black particles coming out of the room air conditioner
dirt, dust, or mold. could also be the tubing insulation flaking off. either way, open it up and clean it out. the dirt, dust, and flaking insulation can restrict air flow through the coils and cause the ac to not function properly. if it is mold, it's can cause sickness (legionaire's disease). do not use chemicals on the coils. it might be best to replace the ac alltogether. to prevent mold: when installing the ac, make sure the unit is slightly tipped towards the outside. any condensation that collects on the coils will drain out. failure to do so will result in water pooling inside, and this can cause mold.
Jul 30, 2009 | Kenmore 73259 Air Conditioner
I bought this snorkel used and put it in my bathtub last night and it filled with water. The lower chamber is filling to the point I can't even blow it out. Is there something I don't know?
From what you've described, you have a self-draining snorkel (at least it would be if working correctly). There will be a simple diaphragm valve at the lowest point of the snorkel, it's usually made of a silicone rubber disc and in use is held closed by external water pressure. It can also be held open if there is any grit or sand in it, if it is damaged or if it's simply hardened with age.
All you can do is clean it and make sure it seats correctly. If it has failed in any way or if the diaphragm is simply missing then buy a new snorkel as they don't need to be expensive.
There's a good reason that many divers still prefer a simple j-tube snorkel and it's because there is nothing to go wrong. I personally do use a self-draining snorkel but I'm careful to inspect and clean the valve before and after every use and always have a spare snorkel in my dive bag.
On an unrelated matter, if the snorkel has any kind of device on the open end to prevent water from entering then I strongly recommend that you remove it. They're restrictive to airflow and are potentially dangerous. There is no substitute for simplicity and for learning to use a snorkel correctly.
Jul 09, 2009 | Tabata Usa Tusa Snorkeling Two Window...
How exactly do snorkels work when you are under the water???
Or more to the point: Snorkels don't work under water. They work on the surface by allowing the wearer to have his/her face in the water so that one can look at what is going on and the top of the snorkel is several inches above the surface allowing the user to breath through the tube. If, as often happens, the snorkel gets water in it, there is a trap at the bottom that catches it so you don't **** it into your lungs and on the next exhale you do so forcefully and this expels all the water from the tube and allows you to continue breathing.
Dec 01, 2008 | Aeris Snorkeling Bag
Integra Dacor  Ii Dry Snorkel Lowest Price Dry Snorkel Logo
499 people viewed this question
Top Integra Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an Integra Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
