Question about LG 32LG30 32 in. LCD HDTV
32lg30 doesnt support hdmi connection
I connected the hdmi to cable box receiver to my lg and it says that to disconnect hdmi because it doesnt support it and to connect analog cables. how do i fix this
    President:
  • LG Master
  • 1,779 Answers
Do you have a menu within the cable box? Just curious if they have a switch option from analog to digital? Take a look first then let me know the cable co. and the box make?
Posted on Feb 14, 2009
The av2 input doesnt work
Look for any loose contacts in RC jacks/sockets/Cable. Connect another input on that input of the TV and check. Connect your ps3 to some other TV and check.
Aug 05, 2012 | LG 32LG30 32 in. LCD HDTV
LG 42' will no longer receive HDMI
ADVICE: HDMI does not like on some sets being connected/disconnected with the unit/s powered up.
The set (this is possible) may in this situation see nothing connected and disable that input.
Look in the owner manual to see if there is a reset or contact the not so helpful people at LG as a last resort.
Apr 25, 2012 | LG 42LC2D 42 in. LCD HDTV
I just wanted to know how to hook up my lg 3d blue ray player. i'm not home so i can look at anything. I need to know how many HDMI cords I may need to plug in my tv, digital cable box, the a/v...
You can do this two ways.
Way #1 connect your cable box to your a/v receiver with one hdmi cable. Connect your blu ray player to your a/v receiver with a second hdmi cable. Lastly, connect a third hdmi cable from the a/v receiver to the television. (3 hdmi cables needed this way)
Way #2 connect your cable box to your television with one hdmi cable. Connect your blu ray player to your television with a second hdmi cable. Connect your a/v receiver to your television with a RCA/composite a/v cable or with a fiber optic cable. Connect your cable box to your a/v receiver with a fiber optic cable or RCA/composite a/v cable. Lastly connect your blu ray player to your a/v receiver with a fiber optic or RCA/composite a/v cable. This method takes 2 hdmi cables and three sets of fiber optic and or RCA/composite a/v cables.
Can't get more specific than that without having the a/v receiver's model number, type of cable box, and television model number. Hope this helps.
Jul 22, 2011 | Audio Players & Recorders
I have directv hd service, I recently bought a surround system, can you help me with the connection? My sat. reciever has an hdmi out as do my surround receiver and my tv
It is always helpful if you give model and make of the equipment involved. We can be more specific and accurate that way.
It si a very straight forward connection and you need two HDMI cables.
1) Connect the Satellite Box's HDMI out to the Receivers HDMI In ( any one of the sockets labeled TV/SAT or Video AUX etc ).
2) Connect the Receiver's HDMI out to the TV's HDMI In.
Every thing will work fine except if you switch off the power of some receivers the TV will stop getting HDMI signals ( ie no sound or video if Receiver is Off )
The other way of connecting is to connect the SAT BOX's HDMI cable directly to the TV's HDMI In and if your SAT BOX has a digital Audio out ( Optical or Coaxial ) connect that to the Receivers Digital In. This way you will need only one HDMI cable and one Optic fiber or Coaxial cable. And the advantage is even if the Receiver is Off you can watch video and hear its sound through the TV.
Apr 03, 2011 | LG 42LH40 LCD TV
I have a 55" LG
Easy solution; this is a very common problem. Connect Cable or satellite box / DVR directly to one of the TV HDMI inputs. Connect an optical audio cable from that box to receiver so sound is surround through your speakers. You cannot connect DVR directly to receiver because the anti pirating chip will shut off the picture and produce a green or no screen at all.
You can, however, connect a BD (Blu-Ray) player via HDMI cable directly to your receiver without that problem. Connect HDMI output from receiver to a second HDMI input on the LG.
Contact me if you need more help! All the best, John
Nov 14, 2010 | LG INFINIA 55LE8500 LED HDTV
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
LG HDMI problem
have you found the solution for this problem because i have the some problem with my tv??
Oct 07, 2009 | LG 32LG30 32 in. LCD HDTV
TV shows "No Signal" when hooked to cable. Cable has been tested with another TV and that TV works fine.
hi if you are connecting the cable box through HDMI then you may need to get the lg tech guy's to come out and reprograme the edid data in the HDMI sockets it's a common problem
Feb 25, 2009 | LG 32LG30 32 in. LCD HDTV
LG 32LG30 32 in. LCD HDTV Logo
153 people viewed this question
Computer Repairing
Computer Repairing
