Question about HP Pavilion Ze4805us Notebook
Pavillion ze4805us no start-up
Just got this thing and hasn't started yet. hit power button and the lights will flash, the cd rom will engage and then everything quits and repeats between 2 and 4 times before it stops even trying. The screen never even flickers. No cd in drive, tried with and with-out battery in. Any ideas?
  • 1 more comment
  • jonfry Feb 14, 2009
    this isn't a new machine, sorry should have stated that earlier. I have tried switching the ram from 1 slot to the other and back with the same results. the lights on the front and by the top of the keyboard come on for about 3 seconds, the cd trys to engage, and nothing on the screen, it then stops like someone cut all the power and does it all over again, without me touching anything. It'll do this 2 to 4 times and then nothing at all.
    it doesn't run long enuf to recognise the disk. the cd rom will just start to run when everything shuts off again. let it run for about 30 min with same result.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Try reseating the memory in the laptop
  • 741 Answers
Yes, your best option is to call the manufacturers help and support so you will have documentation that it has not worked since you bought it. If they cannot fix it over the web, then you have a record of that also. Then pack it up and send it back for a replacement or a refund..what is happening should never happen and you'll probably always have problems with it. Do not open it and play with it as you will lose your warranty.
Posted on Feb 14, 2009
  • Randall  Trahan
    Randall Trahan Feb 14, 2009
    Ok I thought it was brand new. In that case, it sounds like your Master Boot Record is corrupt. This is a very small piece of code on the hard drive that directs the computer to the operating system when you boot up...There are several options. Since you cannot get into Windows at all, put your Windows disk in the cd player. Let it run for a few minutes it looks like it is installing but its not. Everntually it will ask you to install or repair. Choose repair. Then let it do its thing. Take the disc out and restart. Let me know how it turns out....
Hi there I have a msi fx603 that won't start when you hit the power button it flashes once then when you let it up it flashes once more but wont start ...the only other thing that happens is the m
Hello here is the msi homepage:
http://www.msi.com/product/nb/FX603.html#/?div=Driver&os=Win7%2064
I think your harddrive is dead, and must be renewed.
The fault could also be the mainboard itselves.
A computer repair shop, can help you with that.
Good luck
Apr 01, 2013 | Computers & Internet
Cd drive wont open
DCD or CD stuck, exploded? In the Start Menu, Computer, right click the DVD/CD rom drive , scroll down, click on Eject. There may be a "pin-hole" on the face by the button, you can use a paperclip to insert and open. If All else fails remove the DVD and remove cover.
Feb 02, 2013 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
HP Pavillion ze5700 laptop wont start up
Hi, seems to be a wellknown problem of Pavillon NB's. Looks like that the northbridge chip on the mainboard ist unsoldered. Even if somebody tells you do fix it by dropping the mainboard into your baking oven for a few minutes, don't try it! There are specialists who have the technical equipment and the knowledge to fix that problem. But in most cases it would not held a long time.
Hans
Sep 09, 2017 | Computers & Internet
My HP pavillion ze4805us system speed keeps changing from 509mhz to 2.12 ghz, why does it do this?
Most laptops vary teh speed of the porcessor as needed, as a power saving measure. Less speed uses less power.
When the laptop is idle it drops the speed and increases as more is needed.
Dec 03, 2010 | HP Pavilion Ze4805us Notebook
When i turned on this hp pavillion dv4 the control center shows up and doesnt let me exit out.how do i fix it ?
Go to the start button and click on the run box, type in msconfig and hit enter. When the windown pops up, click on "selective startup". Click on the startup tab at the top of the windown, this will list all programs and services that automatically start when windows boots. The only things here that you absolutely need to startup with windows is your wireless configuration, virus and malware protection, and touchpad software to enable tapping and scrolling and changing settings....most of the other programs you do not need to aytomatically start, they can be started when you need them and then you just click on their shortcuts. Go through these [rograms and see if there is anything listed as control center....if not look on the control center window and see if the is a small box in the left lower corner that needs to be checked in order for the windown to not sho up on the next boot. Either way, you can get rid of it in msconfig. Hit apply and ok and restart.
Jan 02, 2010 | HP PAVILION DV4000 SERIES 100GB HARD DRIVE...
My hp pavillion ze4805us is giving me a system error. i am trying to do a system restore from the disks can u help?
insert the os disc in some cases systems come with a system recovery disc if this is not the case just insert what you have shutdow your system when your system boots press the del,f2,or whatever hotkey your system uses to enter the bios menu then while in bios go to boot devices or boot options and click start from cd and then press f10 to save and exit your system will ask yes no click yes then it should restart and a white text should appear saying boot from disc ? click any button when os finnally loads it will ask you to install or to repair ?click repair this searches your system finds out what it's lacking and reloads it .this should be it hope this helps good luck
Aug 03, 2009 | HP Pavilion Ze4805us Notebook
Power supply light flashing.
Computer power supplys are modular replacement fixes. Better to replace the whole thing then try to repair.
Sep 24, 2008 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
Orange flashing lights
May be the power supply gor affected by the damage because the cd rom busted so better than trying to use the same power supply better get another new one because it may damage the other parts of the computer.......
Mar 18, 2008 | Gateway Emachine Bestec ATX-250-12E PS...
Power ON/ nothing on screen-
enter the bios setup, if you can boot the computer/laptop. Usually F2 on bootup, it will say entering Setup.
Then scroll through the pages to see if your hard-drive is recognised by the system.
Mike @ Compurepair.
Feb 24, 2008 | Acer Aspire 5100-5022 Notebook
HP Pavilion Ze4805us Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
