Question about Dell Dimension 8400 PC Desktop
Dell pc dimensio 5150 wont boot up
Closed it downand now cant get booted up. The start light is flashing yellow. Not very technically minded so any help will do. cheers
    Sergeant:
  • 285 Answers
I think it's stuck in sleep mode. Unplug the computer and turn it back on. I hope this helps!
Posted on Feb 14, 2009
  • Dell Master
  • 2,404 Answers
Try unseating and reseating the connectors from the power supply that are going to the motherboard. If this doesn't work then take out the memory from its slots and turn on the computer to see if it at least beeps without the memory in.
If it does then put the memory back in and turn on the computer then and see if the light is green, if you still only get a yellow light then your power supply is bad and would need to be replaced.
    Problem Solver:
  • 15 Answers
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist.
Ensure that the voltage selection switch is set to match the AC power at your location (where power cord goes into unit).
Also try simply unplugging the unit from the wall outlet for a minute then plug it back in and boot it up.
Hi, I have downloaded from DELL website the Dell Dimension 5150 BIOS to upgrade the BIOS. I followed all the steps successfully and restarted the system but it just showed incompatible BIOS on start-up....
first to get a properly bios you need to get the whole description and download it to an floppy disk if it does if not try to boot from a cd...theres a hirens boot cd tools to fix since you already flashed wrong i assume you have some experience use the key tag of yor dell to get properly drivers...
May 27, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My dell inspiron 5150 couldn't boot on or show power light.the board cant start.
The issue can be due to corrupted display drivers or graphic adapter malfunctioning.
Visit the below link for more information
http://notebook-solutions.blogspot.com/2009/07/my-laptop-computer-will-not-boot.html
Aug 14, 2010 | Dell Inspiron 5150 System Board (...
Dell E510 desktop was fine. Went to start again and yellow light on tower. Keyboard and mouse won't work. Screen is black. Unplugged waited 10 min. And turned on - yellow light still on.have xp.have...
check if your booting device is working fine... and see the booting device in the BIOS.. if it is not found there, try connecting the same in other PC as a slave..if there also it does not work, the device might have gone
Jun 25, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dimension 5150 computer wont boot up -flashing amber light
While the system begins booting --before the xp logo shows, if it gets that far for you, hold down the F8 key. This will bring up a menu. Choose "start windows in safe mode with networking".
The OS will start in safe mode. run a virus scan, defrag and scandisk, then restart the system. If is still wont boot normally, do the same thing then run a registry fixing program such as uniblue registrybooster, then reboot. If it still won't boot you may have to format the drive and reinstall the OS. good luck.
PLEASE RATE THIS ADVICE WITH SOME THUMBS UP!!!
Apr 22, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150. wont start
Most times when you have flashing yellow light there is issue ether with cpu or motherboard. Just to be safe test the power supply and if ok then try to replace cpu and go from there. If power supply issue just replace it. Might be easier to take it to pc repair store. Good Luck
Apr 05, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell inspiron 5150 green light flashing on front won't boot up
I had the same problem, replaced the hard drive and problem went away. The hard drive developed bad boot sectors after downloading XP service pack 3. I found out later it isn't compatable with the dell I have. Hope this helps. Good luck!!
Apr 29, 2009 | Dell Inspiron 5150 Notebook
Flashing Orange light, computer wont boot
Below is the link to the NoPower, No POST, No Video troubleshooting.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=&treeid=011360B8243248349C306481A954B356&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=en&toggle=&dl=falseFollow all the steps without skipping any and if there is no hardware failure,this should definitely resolve your issue.
Hope this helps. Please rateyour feedback!
Thanks,
VJ
Mar 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 will not boot. Flashes amber light
I had the same issue with my Dell Dimension 5150 and I replaced the front I/O USB Audio Panel and it booted right up.
Feb 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Inspiron 5150 won't boot
Take out the battery. that hapened on my inspiron 3800
Nov 11, 2008 | Computers & Internet
Dell Dimension 8400 PC Desktop Logo
163 people viewed this question
Alun Cox
