Question about Toshiba Satellite A100-S8111TD Notebook
Want stay charged
When I plug my laptop into the wall jack, it works fine. But, as soon as i unplug it my computer goes dead. Is my plug in adapter bad? Or is somthing in my laptop gone bad?
  • Toshiba Master
  • 2,404 Answers
Sounds like a bad battery cause its not keeping a charge. Try a new or known good battery and see if it will charge and then unplug the ac adaptor to see if the laptop stays on.
If the laptop stays on with a different battery charged then your old battery is bad. If your laptop doesn't stay on with a known good or new charged battery without the ac adaptor hooked up then its a bad motherboard.
Posted on Feb 14, 2009
Acer Aspire 5610 battery won't charge. AC chord is plugged in. Battery reads at 3%.
either dead battery or burned out power supply try buying universal one from radioshack or best buy make sure you can return it if its not solving the problem.
Mar 02, 2011 | Acer Aspire 5520-5908 Notebook
Tip
How to troubleshoot your laptop at start
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead. What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
on Mar 27, 2010 | Computers & Internet
Its that the battery is not charging, and on the power meter icon its blinking four times orange and one time green. If I remove the battery, the laptop works with ac adapter. but if I reinstall the...
Check for a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Feb 06, 2011 | Dell Latitude D610 Notebook
I have ac adapter plugged into the wall, and into the computer, the charge pack light is green, the battery is in the computer and the computer won't turn on at all
You probably have a bad or loose DC jack on the laptop:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
http://www.insidemylaptop.com/laptop-dc-power-jack-repair-techniques/
Nov 30, 2010 | Gateway SL1450-30145063 Notebook
Battery will not charge. Got startup message about not being able to determine wattage. Icon says plugged in not charging. Computer was dropped on power jack. Replaced power jack. Gives computer power...
The power adapter MUST BE a Dell brand power adapter.
If it is, then the socket that was replaced is not the right part.
Of course, the laptop can work just fine with the power adapter, it justwon't charge the battery.
Oct 29, 2009 | Dell Inspiron 1000 Notebook
Laptop wont start without battery. its was working with battery and charger plugged in. then just died. a friend of mine has got the same laptop. if i take his fully charged battery the laptop switches on...
Your AC adapter is dead. Look at the adapter after you plug it in the wall, if it is working, there should be a green LED lit on it. If this is the case and it still isn't working, you need to take a volt meter and read if there is output at the connector that plugs into the computer. Either way it looks like your adapter is defective and needs to be replaced.
Sep 10, 2009 | HP Pavilion DV6500T 15.4" NOTEBOOK LAPTOP...
Whenever i plug my charger in, a message is displayed saying the power type cannot be determined and the computer will not charge.
I had the exact same problem (Vostro 1500), the short story is the computer is dead and I'm looking at replacing the motherboard. Here's the long story: Whenever I got the error message, I'd fiddle with the connection at the back of the computer, and "reset" the power adapter (see below for my reset procedure). That worked for a while until last week--the computer refused to recognize the power adapter, and my little trick wouldn't work. I have no means for charging the battery, so now the whole system is dead in the water. I've determined the problem is not the adapter itself, as it works fine in another similar unit I own. It's definitely the computer's power port or some internal component related to it. Lo and behold, a bit of searching on the internet has revealed that this is a common flaw with Dell Inspiron 1500 series, and Vostro is a close relative of the Inspiron. I'm going out on a limb and assuming it's the "Inspiron Affliction." Anyway, every solution I've found recommends replacing the motherboard, because the power port is integrated with said board. $225-$300 is the going price. I'd just use a dock, but Vostro doesn't accomodate a dock, so that option is out :-/
Dell Power Adapter Reset: If your power adapter has an indicator light, does it refuse to glow when plugged in? To "reset" it, unplug the adapter from the wall and computer, then unplug the cord where it connects to the transformer brick. Plug it back into the brick, then plug it into the wall but not the computer. If the indicator light doesn't glow, then something is wrong with the adapter. But if the light glows, then your adapter is good. The next step is to plug it into the computer, if the indicator light stays on, you should be OK for now (although it will probably fail permanently sometime soon). On the other hand, if the indicator light flashes briefly and goes out, the problem is in the computer -- back up your files while you still have battery power! Either way, if your computer is still in warranty, I recommend extending it another two or three years, if that's an option.
Aug 25, 2009 | Dell Vostro 1500 Notebook
Power cuts out
whenever you plug the adapter to your laptop, there is a small pilot light which lights up. if it doesn't light up that means your adapter is not charging your battery. if it does, then maybe you should change your battery. just a little tip : it would harm your pc if it often goes off unexpectedly or improperly shuts down.
Nov 07, 2008 | HP Pavilion zt1135 Notebook
Dell Latitude C540 screen goes dark when adapter is pluged in
Right click on the battery icon on screen and set the power and screen brightness as you require.
May 02, 2017 | Dell Latitude CP DC Board Graphic Card
My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Thanks!
Ron-
Nov 11, 2007 | Acer Aspire 3680 Laptop
Toshiba Satellite A100-S8111TD Notebook Logo
152 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
