Question about HP Pavilion FX70 Monitor
Hp FX 70 monitor keeps shutting off
My FX 70 monitor shuts off or screan goes balck . I have to keep turning it on and off at the monitor six or so times before it will stay on. it stays on for a few days then acts up again and I have to do the on and off treatment again. what do you think. Works perfect otherwise. also will a 1530 or 1730 monitor work with my HP 720n computer and will i need software to run this or other HP monitors if I need to replace this one? Thanks,John R. Elko
    Problem Solver:
  • 15 Answers
Sounds like the problem is with the switch itself. No real fix for this.
Both these monitors will work with your desktop without any additional software.
Posted on Feb 14, 2009
My Hewitt Packard flat screen monitor keeps shutting off, it will come back on then shut off again.The green light stays on.
my HP w1907 flat screen keeps shutting off after playing a game, but does it frequently when changing browsers also.The blue lite stays on, if I click and return it back on blue the monitor opens for one second.
Also I can't return the screen resolution back to its original setting, which is 1440x900 because any browser home page has a 4"white space on both sides of the monitor. I can't hit my auto selectbutton because that causes the problem. I spent $60.00 for tech support but no help on fixing the problem. One tech directed to buy hardware helper,that was about$30.00! I just keeps directing me to my original chipset setting which I told the tech that's where my problem started! My daily important update keeps popping up with it,so where's the HP support when you paid for it? Problem still not resolved. Joe...aka jljoekool@charter.net,,I bought the HP monitor and tower together,so it's a HP PROBLEM
Dec 12, 2010 | HP Vs17 17" LCD Flat Panel Monitor
I have a hp pavilion dv1000, it keeps shutting down, I had the fan replaced by Hp six months after I bought it. Is there a recall for this lemon?
are you sure that it shutting down because of fan
it may be a virus problem or OS problem too
try to find out main problem
thanks
Nov 12, 2010 | HP Pavilion dv1000 Notebook
My 20 inch Dell Monitor keeps shutting down..
mcdevito75 here, Sounds like the monitor itself, contact Dell for rep[lacement on warrantee if warrantee applies.
Jul 14, 2010 | Dell ST2010 20" Monitor
The power button on my HP monitor keeps getting a message saying "Power button lockout" and the monitor will not turn off whenever i push the power button it just goes to sleep and i have to unplug it and...
Hold down the power button on your monitor, with the power on, for approx. 25-30 seconds and the monitor will shut down for good. When you will start it again, wait at least an hour, the message will be gone and the monitor will work as intended.
Jun 23, 2010 | Computers & Internet
G60-120US high temp problem
Laptop's temp should NEVER be higher than 60-70 C. Otherwise, windows or the CPU will shut it down (my laptop never goes over 75 C, even when running games for a short time)
A few tips:
1) Laptops are a really bad choice for games. They are not designed for that and they will overheat, some of them a lot, depending on the manufacturer.
2) Check if you BIOS has an option to turn "automatic fan control" OFF. This will keep the fan running at HIGH all the time, helping somewhat with the heat (most laptops do not have this control in the BIOS)
3) Clean up the fan. Turn the laptop off, disconenct the AC charger, remove the bottom cover and blow compressed air from a compressed air can. Be sure to remove all the dust and lint. Check that the fan moves easily. Replace the cover, plug the AC charger on and try again.
4) REMOVE SPEED FAN and install CPUID's Hardware Monitor from here:
http://www.cpuid.com/hwmonitor.php
It's much better and it gives you the temps of CPU, HD and video card and also speed of fan(s)
Mar 27, 2010 | HP G60-120US Laptop
HP Monitor w1907 problem
First place to check will be the power supply section, look for bad caps with bulging top or bottom seal, post back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 27, 2010 | HP w1907 LCD Monitor
HPW 2007 goes to sleep
Try going to the control panel after clicking on the start button and it will have an icon that says "power options", there will be options there for the sleep functions for the monitor etc.
Nov 30, 2009 | HP Computers & Internet
My laptop monitor keep shutting down....
Check the display power settings in Control Panel.
Oct 04, 2009 | HP Pavilion dv4000 Notebook
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Starlogic 20 inch widescreen monitor screen keeps going black
This is probably a back light problem. Take a bright flashlight and while the monitor is on, point it at the LCD and try different angles, etc. If you can see an image, it is the back light, probably the back light voltage converter unit in the lcd. It could also be the back light bulbs.
If you don't see an image with the flash light, then it could be the main logic board.
ort11
Mar 08, 2009 | Computers & Internet
HP Pavilion FX70 Monitor Logo
351 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
