Question about Bushnell 10x42 H2O Binocular 132410
Bushnell 10x42 h20 roof prism fov305ft
Hi, I just bought these online and there is no markings on the right eye to set the diopter and it doesnt turn either. It doesn't say anything in item or in packaging about instavision so I am worried there is something wrong with these. Please can you help.
Ta Hazel
3 Suggested Answers
  • 43 Answers
SOURCE: I need rubber eye pieces for our 10x42 bushnell
This depends on where you are geographically located. If you are in Australia there are only one or two people who can help. If you are in the USA the same applies. Try typing in "binocular repairs" into Google and see what pops up. For example in Australia you will find "The Binocular & Telescope Shop" and "York Optical" pop up.
Posted on Mar 02, 2010
SOURCE: The diopter setting eyepiece has come out of the
The entire diopter setting eyepiece was off.I separated the eye cup from the rest of the diopter setting eyepiece, and aligned the channel guides on the lens piece to slide it into place. Then holding it in place, taking care not to gum up the lens, I experimented with how to screw in the retainer ring so that its white dot registered correctly. Finally reattach the eye cup and focus. It's like new!
Posted on Apr 11, 2010
I have a pair of pentax 10x42 DCF HRc binoculars that will not focus properly througn the right eyepiece. Just wondering if this is a common problem and is it worhtwhile getting repaired
The binos will rack focus both at the same distance, you need to rack focus left side to distant image with left eye only, then turn diopter focus to focus right eyepiece. Diopter focus is thinner wheel behind focus wheel
Aug 15, 2015 | Pentax DCF HRc (10x42) Binocular
How to get my single image back?
Although It may not appear to have prisms because of the sleek barrels, they do infact have roof prisms in them. Most likely one of the prisms is out of position. Bushnell typically has a great warranty so contacting them to have them repair it would be my recommendation. Here is there service group link: Bushnell Repair Services. If you need additional guidance do not hesitate to contact the folks at RCS Optics
May 09, 2015 | Bushnell Powerview 13-1632 \ 1633 (16x32)...
I was given a pair of 10X42 powerview FOV293FT the Prisms seem to have shifted can they be repaired and would this be cost efective Ian South Africa
If there has not been a major blow, it is in most cases straightforward to align that double image.
Begin by looking if any of the eyepieces or front tubes are jammed, if so they need to be straightened or replaced.
Another problem is if something rattles, and if you notice that it affects the double image. It could for example be the prism holders, or the front lens of the eyepieces. If you are lucky it is just the adjustment screws not being properly screwed in, see below, otherwise this problem needs to be taken care of firsthand.
For adjustment of the double image binos come with three more common options. There are in some cases concentric adjustment rings around the front lenses. More frequently on porro binos there are adjustment screws on the prism housing. You find them under the front and rear edges of the rubber fascia. Or with roof prism binos you often adjust the angle of the eyepieces with in that case adjustment screws on their periphery
To adjust you first pull the two tubes apart a little, look then at something with horizontal and vertical lines in the distance, for example a building. The image will look like bino views in a movie film, with two different circular fields of views kissing each other in the middle.
It is easy to see malalignment for horizontal lines as they go from left to right. These are also the most important to adjust. For vertical lines you need to scan left and right and see if the image jumps sideways. This direction is actually not totally necessary to get perfect, the eyes can slightly adjust for this, but at the price of fatigue.
Be careful and make small adjustments at a time. You should be done in a few minutes.
Nov 02, 2014 | Bushnell Optics
By adjusting the diopter on your camera effect the image quality? I guess what I'm trying to say is, will the diopter setting effect how your camera adjusts the focus in auto or manual?
Diopter is for your eye only and does not effect the focus of the camera. By using the 1/2 down method, by pressing the photo taking button half way down, you can set the cameras focus. on some cameras this is shown where it will focus by a red square. If you change the diopter this is like adding by focal lenses for reading a book. and setting the distance your particular eye needs for eye relief. On binoculars this is done with screwing the eyepiece closer or farther away from the other lens. check out online this will give you more details of what a diopter is or does. Always know what setting your shooting at as well. for instance if you are on a flower setting or Macro then this is for up close work. But up close doesn't mean too close. Most cameras on Macro need to be 6 inches to 12 inches away. But if you are say 24 inches away it won't focus right so don't try to zoom in, use your optical instead of digital and simply move closer or change the settings on the camera to a different setting or it may be blurry.
Jul 24, 2011 | Cameras
One eye or the other seems slightly out of focus.
Hi, one of your eyepieces has an twisty eye piece, its printed on the outside + & -, probably the right side? If its the right side you close your left eye and focus with your right, then open both & HEY Presto, you've got vision in both! Thanks Mark
May 03, 2010 | Zeiss VICTORY 10X40 BINO
The diopter setting eyepiece has come out of the body of my Bushnell 10X42 ''Waterproof'' binoculars, model 13-2410. I see keyways inside, but cannot screw it back in more than about 1/4 turn, which is...
Apr 10, 2010 | Bushnell Waterproof Binoculars
Double vision
I'm assuming you have set the dioptre correctly for your eyes.
Normally this is caused by a collimation error when one (or both) prisms move. This can be by a small amount.
Your going to have to take them in for service/repair to fix this as is not a DIY problem. (Unless of course you have a collimator lying around)
Mar 24, 2009 | Bushnell H2O 13-2412 (12x42) Binocular
Insta-Focus focusing problem
first open and close the binoculars untill they fit you eye width,now adjust left eye with the flat section located on the center hinge,now turn right eyepiece till clear. note: once you have adjusted right eyepiece you only have to leave it in that position in order to focus from near and far.........good
Nov 24, 2008 | Bushnell "Insta-Focus" Binoculars
Bushnell PowerView 13-1633 Binoculars
Hi - This called the diopter adjustment which compensates for small differences in focus between the left & right eyes.
See the following web page for adjusting :
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Sep 07, 2008 | Bushnell PowerView 13-1633 Binocular
Optics Logo
424 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
