I have a problem with my canon ir 2870 and the problem is this e000001-0002 will you please solve it i need this copier to work i have some work to do
SOURCE: canone ir2016 SST HELP
send your mail to [email protected]
i have all sst verson
i need firmware for cano IR 2016J
SOURCE: we have canon copier ir 2016j, it started giving
Error code E007 on an ir2016 means that the fuser film has a fault. The fuser film is the black sheet that melts the ink into the paper on the final stage of the copy process. It more than likely has ripped apart. You will need to call a service tech for this one.
SOURCE: Canon IR 2270 The copier print
these means that copier cant detect the toner in developing/toner assy.
You should try to reconnect the toner developing assy and try to vacume it.
Also check if the toner bottle is rotating, if yes that means that toner is being dosed and problem is developing assy.
If you do not want to call service write me on [email protected] for service manual.
hope that helps!
Testimonial: "very helpful i just remove check and reconnect the toner cartrige and the issue is solve "
SOURCE: Sir I have Canon IR
Sir I have canon 2870 machine. The machine giving the finisher problems, when starting the finisher going down. The machine showing the problem E540. Please kindly solve
Replace The Main Power Supply PCB Assembly (The part number FM2-0260-000).
NOTE: if the fixing unit circuitry has an open or a short, the code may not reset.
Confirm the fixing unit wiring and try to reset the code first, before you replace the Main Power Supply Assembly
hope it helps
