Question about Compaq Presario 700 470024-192 Notebook
How to share internet connection on Windows Vista OS. I want to share internet connection between two Laptops using Windows Vista Operating system and the other using Windows XP. The Host computer is Windows Vista while the client is Windows XP. Please how do I setup the connection on the Host computer which is using Windows Vista OS so that the other computer can use the internet connection using Crossed Cable conection (Cat 5 with RJ45 plug).
  • Dave
    Dave May 11, 2010
    You have two nics in the VIsta machine, right?
    Unless there is a reason, you may want to consider a simple broadband router. Usually easier to set up and doesn't require the Vista machine to be on while surfing with the XP box.
    Scholar:
  • 52 Answers
All right let's call your Vista computer A and your Xp computer B. First you have to bring the two computers into LAN. If you already did this, please skip the next eight steps.
Step 1: In Vista, before doing this you should enable Sharing and Discovery. You can do that by going to Control Panel -> Network and Sharing Center. Under the section ‘Sharing and Discovery, enable Network discovery, File Sharing, Public folder sharing and others if you want to. (See picture below)
Step 2: If your LAN card that is connecting to another computer is installed, it will be shown under Control Panel -> Network Connections.
Step 3: Right click that local area connection and click properties.
Step 4: Under the tab ‘Networking’, click the properties Internet Protocol Version 4 (TCP/IPv4).
Step 5: Click the radio button to ‘Use the following IP’ and give an IP address (For example, IP address: 192.168.0.1 and Subnet Mask: 255.255.255.0)
Step 6: Don’t give any other information, Click Ok and close everything.
Step 7: In computer B, which is the XP, make sure you enable the LAN card which is used to connect to computer ‘A’. Here you need not give any IP information as Computer ‘A’ will assign an IP address dynamically. If it’s not working make sure there are no IP assigned and change the properties to ‘Obtain an IP address automatically’.
Step 8: Test the connection by pinging. (You can do this by typing ping 192.168.0.1 or whichever is Compter ‘A’s IP in the comand prompt)
NOW your computers are connected. Now to share the internet:
Right click LAN card which is connected to Internet under Control Panel -> Network Connections and click ‘Sharing’ tab and enable both the options to share Internet. (Note: Unless there is another enabled LAN setting you will not be able to see the shared tab under properties)
Click Ok and close. This option is given by the Windows OS known as ICS (Internet Connection Sharing).
Now you can use Internet from both Computer A and Computer B from a single connection.
So this is the setup you need on the Host computer as you requested, if you turn out to need help witht he XP one too, let me know:)
Posted on Feb 14, 2009
I have one computer which operating system is windows vista home premium. Another PC with operating system Windows 7 Home premium and have set up to share one HP K80 Printer. Now problem I believe is the...
Instal only one printer driver on the PC it is physically connected to. Preferably the Windows 7 PC (Latest OS). Unshare the printer, remove drivers from other PC's., then reboot al PC,s and re-share the printer. The PC's sharing should allow the Windows 7 PC to use it's driver, although they may request a disc for basic information about the printer.
Jan 26, 2010 | HP OfficeJet K80 All-In-One InkJet Printer
What program do i need on start up for my dell inspiron b120
Except for Windows, you don't need any programs on start up.
Nov 01, 2009 | Dell Inspiron B120 Notebook
Configuring clint vista to use shared internet in a LAN
The Internet connection must be shared for you to use it. You probably haven't configured your vista correctly. Try connecting via your internet connection (Networking)
Feb 27, 2009 | Microsoft Windows Vista Home Basic for PC
How to share internet conection between two computers using vista
Hi!
You need a router or an modem with more then one outgoin port to share an internetconnection betwin pc:s
Nic
Feb 13, 2009 | Compaq Presario 700 470024-192 Notebook
Sharing printer
May your printer doesn't fit to your operating system because Windows Vista is one of the complicated OS and hard to find installer or software to fit it in. Try to Replace your operating system that same as your brother have. maybe it can fix your problem!
Feb 27, 2008 | Microsoft Windows Vista Ultimate Edition
Sharing printer between vista and xp os
Hi have a nice day.
I think tranfering your job to desktop first, and then sending to printer, is a solution for now.
Feb 22, 2008 | Microsoft Windows Vista Ultimate Edition
Windows Vista hangs while browsing
An operating system hanging indicates that either the program you are using, or the operating system itself, has crashed. The easiest way to eliminate hangs is to start up the computer from your Windows installation disc, and then either choose to Repair your installation, Restore the installation or install a new Windows OS.
Your computer came with a recovery option that lets you "reset" or recover to a known "good point". Hold down the "Alt" key and then hit the "F10" key (both at once) to activate the feature, and then follow the on-screen directions.
Nov 09, 2007 | Computers & Internet
Windows operating system
you can make a dual book (multi OS) on your laptop so that you can just switch over to XP or vista and vice versa.
try this article on MS on how to install a multi OS. i haven't tested it in vista though...but i think it would work..please let me know.
also..you can use a Virtual PC and install XP there, its much more easier.
Oct 30, 2007 | HP Pavilion dv4000 Notebook
Compaq Presario 700 470024-192 Notebook Logo
208 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
