Question about NAD C521 CD Player
Nad cd player cd541i noise
When i play a cd now and again i seem to get a static noise or a noise like a record player needle skating across surface of the record i have tried cleaning the cd lens but has not solved it
  • 1,175 Answers
That one is going to need Tech service.
I've worked on several of the NAD players.
Sounds like a focus or gain adjust needed.
Posted on Mar 19, 2009
When I press Start the needle moves over, drops down, then comes back up and over and stops. It does this about 95% of the time.
did you try placing the needle on the record manually? Did it work okay then or did it do as you mentioned?
Jun 06, 2015 | Sony PS-LX250H Turntable
When I lower the needle on to the record it simply slides across the record to the centre
Not enough weight on the arm, adjust the weight on the arm end. Can also be a build up of dust on the needle.
May 31, 2015 | Audio Players & Recorders
Jvc service center
If it does this when playing a 12 inch record then it could be that the device has been set to play a 7 inch record. The skating across is either a worn stylus, wrong skate setting (if it has one) or not enough stylus pressure. To correct the pressure one. Make tiny adjustments to the weight on the end of the arm. Each time you need to test by playing a record. If it sits in the groove and doesn't skate, plus doesn't make a rumble sound, you have the pressure right. Too much pressure causes it to rumble, too little and it will leave the groove. If the weight is numbered try it at 3, then take it up to 4 + in small steps, testing it each time you move up. It's a case of trial and error to get it right.
Dec 29, 2017 | Audio Players & Recorders
The arm with the needle slides across the LP record - doesn't pick up sound
This is often a problem when you are using a 78 needle on a 45 or 33 record. Some needles can be flipped, so check to see if yours is able to flip between the 78 and 33 setting. If not, you may simply need a new one.
Jan 03, 2012 | Philco PC-841.651 Turntable
Nad cd541i doesn't always read cd's; it can tell me how many tracks/minutes there are but won't find the beginning of the cd; in this case, sometimes if I skip forward two or three tracks and...
It sounds like a physical problem in the laser seek mechanism. Possibly a sticky area on the guides. Heavy reading for all malfunctions related to optical disc...
May 19, 2011 | NAD C542 CD Player
I have purchased two ARK IV white elliptical Stylus replacement needles for my turntable and I am not getting the life out of these items, despite very limited play time. Seems like they just wear down...
What's the turntable? Skipping across the record would be a (mal)function of tracking and anti-skating. The recommended tracking force for this stylus os 3.0 grams. I've been out of the vinyl groove for some years now but I remember my Shure M95 tracking in the range of 1-1.5 g. Railroad spikes track at 3.0. Is this for 'scratching' or whatever it is they call that noise?
Apr 27, 2011 | Audio Players & Recorders
Needle keeps jumping back 4 bars on records
May 03, 2010 | Technics SL-1200MK2 Turntable
Needle skipping & not pushing down
There should be an "anti-skate" adjustment to control the arm moving across the record. It is possible that lubrication has stiffened up as well. This unit may need a general overhaul/cleaning.
Jul 20, 2009 | Technics SL-1210MK5 Turntable
NAD C541i CD Player plays but the sound cuts out for an instant every 10-20 secs. It eventually goes away, but it is annoying when you first play a disc. Any help appreciated.
hi, i've had a few nad C541i's and not so long since the sound on one of them cut out for milliseconds and on some occasions the sound would make the noise very much like a severely scratched vinyl record, i thought it was a faulty laser so i tried another KSS-213C laser out of a scrap kenwood and the fault persisted. to cut a long story short, i took the main PCB out and there were various dry joints. once these were resoldered i was blessed with a fully functioning player. hope this helps?
Nov 16, 2008 | NAD C541 CD Player
Fisher price 1978 record player
The Fisher Price record player has a device that prevented kids from pressing the needle down and sctratching the record. If you look at the cartridge where the needle is inserted, you will see that it floats up and down. The problem is that this keeps the needle from having enough pressure to play the record. Pennies just make the cartridge recede further into the arm. If you wedge something above the cartridge, the needle won't float and the it will play your records. I've had four of these and none of them worked until I figured this out.
Aug 02, 2008 | Audio Players & Recorders
NAD C521 CD Player Logo
329 people viewed this question
Top NAD Audio Players & Recorders Experts
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
