Question about Yamaha AX-396 Amplifier
Dia Gram HELLO, Dear Sir. I Have 75+75 DC Supply Plz Give Me Diagram. I Use Transistor D1047 But It Is Damage To 10 Minutes. Plz Help Me.
  • 1,175 Answers
Posted on Feb 17, 2009
IR Compressor sl.No N37 - 75KW NIRVANA -TEO179V05257 (oil free screw compressor). Machine trips with VSD 8 fault. Hall effect sensor is new one and is connected as per the correct sequence. Are there...
Yes, the control board may be bad . Ihave attached a procedure for checking the hall effect sensors, some of which you will not have the special tool needed to preform all the tests. However it will allow you to check the control board which may be bad causing your problem.
10 Revision 001 - March, 2002
Appendix 4 - Hall Effect Sensor Checks (Four Part)
1. Isolate the compressor from the main incoming voltage supply. Lock and tag the
isolation switch in the open position.
2. Allow 15 minutes for the VSD to discharge capacitors.
3. Open enclosure doors to expose the VSD.
4. Check with a suitable meter that all voltages have dissipated before beginning work on
the VSD.
5. Remove rear cover of drive motor to permit rotating by hand.
6. Disconnect Hall Effect Cable from P4 on the Control Board, plug type is DB9 Type.
7. Inspect cable pins and matching receptacle connections for damage or bent pins.
Remove cover of plug and inspect solder connection of the wires for damage.
9. Inspect entire length of the cable for damage. If cable and connections are in good condition,
proceed to Test 2.
9. Confirm supply voltage to the Hall Effect Sensor is present using a digital multi-meter.
10. Disconnect terminal strips P1, P2 & P3 from the bottom of Control Board.
11. Trip and switch off MCB2 and MCB5 to prevent the SGN Intellisys from powering up.
12. Re-connect main incoming supply voltage to the unit. Isolation contactor KM1 should remain
de-energized and the VSD should only receive control power. Caution must be taken as the
panel has voltage present.
13. Set digital multi-meter to DC Volts.
14. Connect Black probe of multi-meter to either of the 2 pins of P16.
Note: P16 is located on the Control Board, slightly less than half way down and towards the left side.
P16 is marked and described as 2 small bare pins. P16 is the ground connection for the Control
15. Locate the small transistor just above Pin 3 on terminal strip P1. The transistor has 3 pins on
the left side. The pins are numbered 1 at the top, 2 in the middle and 3 at the bottom.
16. Connect Red probe of multi-meter to Pin 3. The voltage should be between +11 and +14 Volts
17. If voltage is not present, replace the Control Board.
11 Revision 001 - March, 2002
17. Connect special adapter XXXXXXXX between P4 on the Control Board and the Hall
Effect Sensor Cable.
19. Set digital multi-meter to DC Volts.
20. Connect Black probe of multi-meter to either of the 2 pins on P16.
21. Connect Red probe of multi-meter to Red wire of the adapter. Rotate motor by hand and
observe measurement. The meter should read between +10 and +12 Volts DC.
22. Repeat the test with the Black wire of the adapter. The meter should read between +10 and +12
Volts DC.
23. Repeat the test with the Yellow wire of the adapter. The meter should read between +10 and +12
Volts DC.
24. If voltage does not rise to between +10 and +12 Volts DC for any of the 3 sensors, replace the
Hall Effect Sensor Assembly.
25. Set digital multi-meter to Ohms.
25. Connect multi-meter between Purple and Green wires of special adapter XXXXXXXX. The meter
should show a resistance value of approximately 150 Ohms ± 20% (New Hall Effect Sensors)* at
70° F (20° C) ambient temperature.
27. If correct value is not confirmed, replace the Hall Effect Sensor Assembly.
Note: Two temperature ranges (130° C and 150° C) of Hall Effect Sensor have been used. Typically,
the 50/60hp (37/45kW) units use a 130° C sensor and the 75/100hp (55/75kW) units use a 150°C
sensor. All sensors have a small band near the sensor end of the cable.
The 130° C sensor has four digits such as 6622 on the band. The 150° C sensor could have either a
four digit number with a star on each side (*6752*) or a four digit number followed by a star and the
letter E (6752*E) or a four digit number followed by an E (7652E).
Appendix 5 - Megger Main Motor Windings
Sep 17, 2011 | Ingersoll Rand Air Tools & Compressors
Dear Sir, I have astec model AA23160 power supply input Ac 100-240 5A max output Dc +5v 23A, +12v 22A max it does not give output the LED give yellow when it is ON. the two cooling fans were also not...
Hi! l have have the same problem whit the Asctec model AA23160 power supply.But l need to know how many time your power supply worked: How many time do you use it?
Aug 13, 2010 | Astec 300w AT Power supply 190170-01...
Sounds like a power problem on Power supply board. It could possibly be damage or overheating. It will have to be replaced or fixed by someone good with LCD's
This is something i wouldn't try to repair by myself.
Hope this helps a little bit. Good luck
Jul 28, 2010 | ViewSonic Computers & Internet
Heelooo i have compaq monitor v74 ,624t. when on it give sound tick tick..... smps on and off i need circut dia gram. i am sharma..
circuit diagrams exist at the factory where they were designed. Though I have looked before they cannot be found. I do not believe they exist.
Mar 27, 2010 | Compaq CV 7500 17" CRT Monitor
Circuit diagram
I'm afraid I cannot comply with your wishes, as there are copyright laws governing this, for one. (For existing circuitry)
Two, there is the liability issue. Take for example that I design the requested circuit, give it to you freely, and you or someone in your group is injured using my circuit.
Will state that this is a basic circuit design. I believe that if you 5 put your minds together, you can build this circuit.
Sep 14, 2009 | Powerline 200Watt DC to AC inverter...
Need to replace serpentine belt on my cadillac sedan deville need the diagram.
dia gram should be located on the inside of the hood when open or on the top front of engine look care fully its the not hard to find and make sure you have a gm serpintine belt removal tool
Jul 22, 2009 | 1998 Cadillac DeVille
Looking for diagram of engine and spark wire dia gram
i hope this helps
Apr 06, 2009 | 2001 Toyota Camry
Need a circuit diagram for ups
hello sir, i need a circit of ups and usb and other circuit.i am student of DAE in electroics this diagram need a project of DAE send me plz i shell be very thankful you.
Apr 02, 2008 | Powerware Invensys FERRUPS 1400VA...
Yamaha AX-396 Amplifier Logo
211 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
