Question about HP PSC 2110 All-In-One InkJet Printer
Print colors replaced color cart. twice but it is not printing green or violet and everything comes out the wrong color especially pics which are a reddish hue am using brand new hp cart from manufact......
    Problem Solver:
  • 19 Answers
You might want to run a cleaning page through it. This uses up more ink that a typical print job, but it will allow you to clean the heads and force ink through them.
Posted on Mar 15, 2009
Have put new cartridges in and only prints yellow lines
Remove all cartridges, make sure any tape has been removed from over the nozzle. Ensure that everything has been installed properly, then use your printer (prompts on device, or in printer>control panel) to print some test pages, realign heads, etc.
May 05, 2011 | Canon Computers & Internet
I have new photo (58) and color (57) carts and when I print wallet size (9 pics per 8.5x11 photo paper) the first 3 print true color and the last 6 are blue. I have cleaned the rollers and still do not...
hello, you are using the photo color ink cart, have you tried running a cleaning cycle or test print, the reason why i ask, is that maybe 1 of the colors is not printing, the test pages would prove what color is missing, if black not printing, it would print possible blue, or no black at all. i know you have put in new inks, but since the volume of ink in these cartridges run out according to usage, one color might run out before the others, and since black and yellow are the most used colors, without them your prints will show color faults.
Oct 07, 2010 | HP PSC 1350v All-In-One InkJet Printer
It prints blue instead of green when i print. anything that should be green turns out totally blue. any help? i've reset and calibrated twice.
have you tried replacing the color cartrige if so then the printer may be broken and uses the wrong colors its uncommon but does happen
Dec 19, 2009 | HP LaserJet 3600n Printer
The colors are coming out incorrectly.
You need to do a nozzle check print first to see that all the colors are coming out ok. If you hold the resume button until the green light flashes twice, it will print the test pattern. If colors are missing you may need a new printhead. Generic inks are sometimes the wrong color, and in this printer you shouldn't have any photo inks, as they are not the right color for your printer.
Dec 13, 2009 | Canon BubbleJet i560 InkJet Printer
All prints come out with a green cast- all the color cartridges are full and installed properly and I downloaded an updated driver from your website-please advise.
a green cast usually means the red color is failing to print. In that case replace the color cart or take that cart to be cleaned, refilled, and tested.
Oct 01, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Printing wrong colors
you might be running out of the red ink.
Whenever a printer prints the whole image but with different colors it means that the printer uses the available color with enough amount.
Try replacing it with new ink cartridge.
Jul 28, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Canon i860 won't print deep colors
I had similar problem: everything muted and with brownish tint. Tried everything, finally discovered that I installed wrong cartridge: 6PC instead of 6C. The "photo" cartridges are pretty much the same, make sure you have the right ones: 6C, 6M, and 6Y.
Nov 17, 2008 | Canon i860 InkJet Photo Printer
2600n prints greenish little reds
i have priner hp laser jet 2600n but it is printing very low any pic if i print it is come very low color i changed toner cart but still same problem.
Sep 03, 2008 | HP Color LaserJet 2600n Printer
Colors
Did you run a quality test print by pressing ink etc...?
It might be that you have no magenta anymore.
If you can see all the 4 colored blocks on the test sheet, firstly try to copy(!) a picture with pink colors and secondly run a pc print. If there is still no pink and you have it blue or green on the COPY one the scanner needs readjustment (from service personell). If you have trouble with the pc printing, too there might be
a defective ink cart holder which leaks and mingles the ink (you need a new ink cart holder then)
Jan 08, 2008 | Brother MFC 210C All-In-One InkJet Printer
Color not print
Did you run a quality test print? Are all 4 color blocks in a pretty good condition or do you have other colors than the separat 4 ones?
If the colors are mingled you need a new cart holder because the bottom which consists of a foil is leaking and mingles the ink. The cart holder cant be fixed.
Dec 20, 2007 | Brother MFC 210C All-In-One InkJet Printer
HP PSC 2110 All-In-One InkJet Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
