Question about Lands Phones
Searching keeps flashing and we have no other functions working on handset
  • gerry_kiely Feb 15, 2009
    Tried this but didn't work thanks anryway.
    Regards: Gerry
    Sniper:
  • 96 Answers
Hello. This might happen if accidentally droped the phone from the high height or on the hard surface or... if you are really out of radio coverage. In first case repairing this might cost much. In second case have you tried to move to different location? Also try to reinsert your SIM card
Posted on Feb 14, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, post back the brand and model.
Initially, remove the battery of the handset and unplug the base from the mains fro an extended period of time. Thereafter, replace the battery into the handset and charge. Soon as the battery has reasonably charged, plug in the main/base unit and follow procedures on 'pairing'. It may be necessary to do the pairing with a full charge battery.
Would appreciate an update on developments. Good luck and thank you for using FixYa.
One of the handsets is flashing "Warning Check Battery" It is a mi6896.  We have lost two of the handsets.  We don't know how to use the "Find Handset" feature on the base unit (the manual...
Find handset works by causing the handset, or handsets to beep when you push the button on the base unit, and until you find the handset and push the off button. If the handsets do not beep the batteries are probably dead.
We have a handset that flashes "Charging", and later, "Connecting", but it never connects. When the handset is removed from the charger the handset shows "Place in charger". By process of elimination I have determined that the handset has a problem. The problem is NOT with the battery OR charger. I hope this info helps you.
-Vector721
Aug 05, 2009 | Vtech mi6896 Trio Cordless Phone
Handset won't work
I went through this exercise with a Siemens Gigaset 8800. The solution is to DE-register the handset first. Then register it with your base. This function can likely be accessed in the handset menu. The phone you purchased is apparently still registered to the previous user's base.
May 23, 2009 | Siemens Gigaset 4200 Cordless Expansion...
How tomake outgoing calls with my american telecom digital cordless phone model#ra23634H
Thuis was hard to find but it worked for my ra2364hh's
note the phone stopped working in "tone dial" after 2 months and now functions with "pulse dial" only.....
Registration The handset and base will be pre-registered with a digital security code identification, which is stored in the phone’s memory, so that your phone will be ready to work right out of the box. However, your phone also has a procedure to allow you to re-register in case the link is lost accidentally. Enter menu, press the key - Select REGISTER and confirm PIN CODE will be displayed, enter the PIN code (the default value is 0000) and confirm. SEARCHING will be displayed while your handset is in registration mode Press and hold the Page key for 3 seconds on the base until the “In use” LED is ON, putting the base in registration mode SUCCESS will be displayed. This means the handset has located the base, and will get a handset number from the base that displays after the handset name for internal calling. If the handset does not locate the base, FAILED will be displayed and it will return to the non-located display mode that displays BS SEARCH with the antenna icon flash. Try again and check that you are not in an environment with interference. Note: Your base can register up to four handsets. If you have more than one handset, repeat the above steps to register each new handset.
TESTED IT 2 minutes ago and it WORKS.....
tony
Feb 23, 2009 | Lands Phones
Philips CD240 2nd phone wont connect - keeps saying searching
Hi, I solved this issue this morning. What you cannot confuse here is that handset and base. To do the registration successfully, the both must be in "Registering" mode. First, to get the base in the registration mode, you have to press <page> (a paging function for handset in case you cannot find where they are - usually button that says <page>or speaker with sound symbol on the base) more than 5 seconds, then the base is in the "Register Mode"(though you will hear no beep). You can then go through the procedure you describe on the handset and the handset should beep with assigned number no more than 10 seconds after it flashed "Waiting". The above, however, works only if the Base is still functioning. In my case, sadly, the base was more likely dead (if I press any button on the base, i.e. answer phone etc., there is no response). Hence I went and bought a new cheap GAP compatible BINATONE 1800 Single at Comet (14.99). I then set up the base, put it in the registration mode as per the BINATONE instruction. Then on the Phillips CD240 handset and gone through the above registration procedure... and Voila! It worked. Now I have a brand new base that came with 1 handset of its own, and 3 additional CD245 handsets which are all registered with this base. So far, the sound quality is good and they retained all the telephone numbers registered with the handset. The BINATONE base came with 12 months manufacturer's guarantee so I am sorted with the base problem for at least a year, which is nice. I hope this is helpful. Best, Ken
Feb 03, 2009 | Philips Lands Phones
Uniden Cordless Phone Model DSS7855. frequently fails to connect to an incoming call, with 'out of range' indication. The phone is less than 1 meter from the base station.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Aug 21, 2008 | Lands Phones
Cd30 handset the word searching keeps flashing unable to use phone
I have a problem with my Siemens Gigaset 4200 Hand held it continuously flashes searching for single and can't seem to find one.
Please Help Me. Beast68
Phone says searching
The battery may be weak. Or it is too far from the base. Try exchanging the two. take the handset near the base and see if it will link.
Jan 28, 2008 | Uniden Cordless Phone
Uniden cordless phone - model DSS7855
Press and hold "end" and "#" for more than 5 seconds this will de-register your handset without the base unit.
Bobby@welleasy.com
see for more info. http://www.uniden.com.au/RESOURCES_MAIN/pdfs/ELITE8805_OM.pdf
Jan 21, 2008 | Uniden Cordless phone EXS9950
Hello, Yes this happens when you add a additional handset to the system when all the intercom numbers are full. When registering a new handset, it "kicks out" on of the other handsets when it registers. The only way to correct that problem is to default your base and register each handset again, one by one. You won't lose your handset settings, but you will lose your messages and greetings, so check them before doing so. To default your unit, get all your handsets and go to your base. Unplug the power from your base. Hold down the page/registration key on the bottom of the base and keep it held down while you apply power to the base. After applying power, keeping the button down, count to 20. Then release the button and get each handset. Register each handset, and they will number themselves 1 through 4. If you need additional assistance, service or need to purchase another handset or base (you can register each handset to up to four bases to increase your range, this is unique feature in the cordless industry), you can go to www.cordlessrepair.com for all your Siemens cordless needs. Good Luck ! Let us know how it goes, we have a testimonial page on the website for people to leave comments on the technical tips or assistance they receive from our technicians.
Sep 20, 2007 | Siemens Gigaset 4000 Phone
Adding new expansion handset
You will need to register it to your base station before it will work. You do so by holding down the registration/page key on the bottom of your base for a couple of seconds, and then grab your SL30 and push Menu, scroll down to the option of Handset settings, press OK, then scroll to "registration" and push OK, select base station 1, press OK, then enter the default pin of 0000 and press ok. Repeat these steps if first not successful. You can download a manual for free on our website at www.cordlessrepair.com
May 21, 2007 | Siemens Gigaset SL30 Cordless Expansion...
Lands Phones Logo
23 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
