Question about Hyundai Electronics E425D 42 in. LCD TV
Remote controls work intermitantly
Have renewed batteries but the remote will only work now and then If i can get it to switch on the tv all functions will work then it will not switch the set off and the i have trouble switching on with remote manual functions work ok Nothing has been spilt on remote
    Problem Solver:
  • 9 Answers
You must clean your remote inside & out
Posted on Feb 14, 2009
Code required to programe sky remote control for murphy 42884t2lcd
Hello
Three digit remote code with Sky with Murphy TV are:
132 244 191 502 100
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note:
In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press TV followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Sep 21, 2011 | Televison & Video
Need code for sky remote control for samsung model ps51d450 51inch plasma tv
Hello
Sky remote codes for Samsung TV are:
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 30, 2011 | Samsung Televison & Video
I have a Humax LU23 TD2 television and have now got Sky tv. I would like to know how to use the Sky remote to control all the functions such as power on, volume etc. for the tv. Can you help...
Hello
These are the setup processes for Sky TV.
OK.
Aug 28, 2011 | Televison & Video
Can't find sky remote code for grundig gu37fhd1080
Hello
Sky remote codes for Grundig are:
563 582 515 098 584 219 104 233 223 065 471
Aug 20, 2011 | Televison & Video
LG Television 32lh5000 I have started getting a problem with this TV. When I try to change the volume I press up or down on the remote control and the volume just continues to change without stopping...
Change the batteries in your remote, this is a common issue with batteries that are low on charge.
Also if you find that your TV intermitently changes channels and no one is even touching the remotethis is the same problem.
Aug 13, 2011 | Televison & Video
My Logik L22LID628 tv has an intermitant fault & will sometimes not respond to the remote control, I have tried new batteries, and checked the remote control by tuning an infra red light switch to the...
We have had two of these tvs break within 2 days of purchase, in our case both times it seems to be a backlight failure. Did you wall mount your tv? If so when you take the base off it leaves a hole in the casing leaving circuitry visible. I think it's very easy to damage the ciruitry.
Nov 01, 2008 | Televison & Video
Dvdnot recognising remote control
First check the remote's functionality. The easiest way to do this (if you're a little bit handy with electronics) is to get a small battery-powered amp and a small solar cell from somewhere like Radio Shack. Solder the solar cell to an 1/8" plug and plug it into the amp's input. Turn the amp on and point the remote at the solar cell. If the remote is working, the solar cell will pick up the infrared signals emitted by the remote's IR LED and you will hear a series of clicks and pops from the amp when you press a key on the remote. This is a very handy cheap test device. I always have one around the house.
Sep 03, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
Hyundai Electronics E425D 42 in. LCD TV Logo
65 people viewed this question
Top Hyundai Electronics Televison & Video Experts
Tom Chichester
Are you a Hyundai Electronics Televison and Video Expert? Answer questions, earn points and help others
