Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
First two lights of four are flashing
Water still in the bottom that has not pumped out.
  • Anonymous Apr 14, 2009
    I have the first two lights flashing on my idl40 can someone please help
When my ones lights flashed (lights 2 and 4) I thought it was def broken, i then discovered it was a knife in the top tray stopping the shower from spinning. worth a try- make sure its empty when you test it.
Posted on Feb 14, 2009
Start light flashing,rince light on.machine will not start cycle
Hello. I really need the make/model number to help you accurately. However, from the symptoms you're describing, it sounds like the drain pump is jammed. A lot of dishwashers turn on the drain pump first to remove any stagnant water sitting in the bottom of the pump. Then, fresh water is let into the tub, fills to the proper amount, then the main pump starts. The lights flashing are an error code--different combinations of buttons flashing mean different things. On some models, a button light will flash a certain number of times, pause, then flash another number of times. This is a binary code telling the user what is malfunctioning. That's why I need the model number and any other info to help diagnose the issue. Thanks!
Sep 18, 2015 | Dishwashers
I hear the pump, but no water is coming out
I recently purchased a refurbished EM-200 and it did not work and leaked water all over the place right out of the box. Without doing anything water leaked out of the bottom of the machine. When I tried to run the machine you can hear the pump but no water ever came out and after a few seconds it quite and the lights would start flashing and beeping.
The mechanical engineer in me just had to solve the problem. I unscrewed and removed the bottom plastic cover (3 screws) where the power card goes into the machine and found the problem. The water from the reservoir feeds into a white plastic priming pump. This priming pump is assembled in two halves and one half has four plastic clips that hold the pump together. In between the two halves is a rubber o-ring. Well, one of the clips was not secured and I could see part of the o-ring protruding. This is an obvious source of leakage. Either the pump was not properly assembled or it snapped out of place during shipping.
I unscrew the two screws that hold the priming pump in place, leaving the hoses attached, and carefully pulled the two pieces apart. Note how the magnetic impeller is installed and reassemble the same way. Use a small amount of vegetable oil to lubricate the o-ring and reinstall in the same place. Reassemble the to two halves, making sure the o-ring doesn't protrude, then snap the two halve together tightly. Screw the primer pump back into place then screw the bottom plastic cover back into place.
After this fix the machine no longer leaked and it brewed a nice espresso. Everyhing seams to work find now.
Dec 28, 2012 | Cuisinart EM-200 Espresso Machine
Code 991 continues to show.. will not clear... how do we clear that code???
to clear the 991 Takagi code, simultaneously press the bottom 2 grey buttons of the four just to the left of the flashing LED light. When the LED stops flashing, release and then press the reset button on the black panel about 8 inches above that
Jan 17, 2011 | RTO Takagi T-M1 Mobius Gas Tankless Water...
Washer is Kenmore He2 model # 110.46462501
It sounds like you have something stuck in the pump.
To repair
Unplug machine.
Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be carful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris. Once everything is cleaned out reverse removal procedures put back together.
Mar 22, 2010 | Kenmore 43142 Front Load Washer
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
Aug 13, 2009 | Danby DPAC8020 Air Conditioner
Amana Touchmatic Heavy Duty Washer Filter Light Flashing
I have the same washer unit and I purchased my washer new in 1989. The flashing filter light is normal. If the light doesn't flash, than the water filter is plugged up. The water filter is self cleaning each time the water empties. You can take off the front panel(two screws at the bottom and the top disengages with metal clips. The water filter in at the bottom on the right, white plastic housing. There is a drive belt from the motor that powers the pump. When the washer goes into the spin cycle, the motor changes rotation direction and the pump works in reverse, thus flushing out the lint that may have been captured during the agitation cycle. I hope this helps.
Mar 14, 2009 | Amana Washing Machines
All four light flashing
I had this same problem, and tried all the solutions offered with no success.  I ended up taking the water filter out of the water container.  When I did the water would come out of the bottom like it was suppose to.  I haven't tried a new filter yet, but it is working without one in right now.  Hope this helps.
Sep 27, 2008 | Braun Tassimo Espresso Machine/Coffee...
Error code. F14.
Check the motor circulation impeller, if you not maintain the unit is gonna be clog by impeller. it need to be clean.
Jan 11, 2008 | Miele Premier-Plus Built-in Dishwasher
IDL705 dishwasher showing error code
Indesit IDL700 first two green lights flashing and cycle stops with dirty water left in the machine. CAUSE - blocked or jammed drain pump. SOLUTION - First remove all the filters inside the machine, syphon or sponge up all the water in the sump and check for any obstruction over the fine grill at the very bottom. (we had a pistachio shell covering the hole!). If this doesn't cue it you will need to gain access to the pump. First, turn off the power. Gently lift the machine onto it's side (be ready for some water to spill out!). Remove the bottom plate (6 screws) and disconnect the sump float switch. Remove the single screw retaining the pump to the bottom of the machine and rotate to remove. You should be able to see the rotor blades. With your finger check to see if the pump rotates freely. To dismantle the pump, remove the 3 screws and separate the two halves. Our pump was jammed with an apple stalk!. Reassemble and connect any cables. Apparently this is a known problem with these machines and can be prevented by assembling the filter system correctly and pre-rinsing plates etc. before placing in the dishwasher.
Sep 19, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
245 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
