Question about Linksys Wireless-G WRT54G Router
Which channel to chose
I have just reset my WRT54G router. how do i know which wireless channel to chose for configuration the router. currently my channel is set to channel6 (2.437GHZ) after resetting. but the internet seem to slower than before.
FYI i am refering to the 192.168.1.1 webpage - wireless tab - basic wireless setting page in the wireless channel selection
  • seminoob Feb 14, 2009
    does it make a difference to the internet speed ? i don't seem to remember the repair man setting my wireless channel to the max (channel 11) when he help me to set up the router
  • Linksys Master
  • 6,487 Answers
Channel 11 is the best channel to use to avoid any interference and have a much faster connection on your wireless network , if in case it wont work fine try using channel 1...
Posted on Feb 14, 2009
I accidentally reset my wireless G WRT54g router, how can restore it?
Not unless you made a backup configuration file. So unfortunately you will need to reconfigure your wireless router. The main points you should configure are...
  • Change the default password to login to your router configuration
  • Change the SSID (optional)
  • Enable wireless security WPA2 / PSK (keep out unauthorized users)
You can configure it manually or download the utility from Linksys / Cisco website which will walk you through the configuration.
Comment back if you need help configuring it.
Nov 07, 2011 | Linksys Wireless-G WRT54G Router
I want to change the channel my Linksys is using. So I went to Internet Browser and typed in my IP address. It said I need a Username and Password. Where would I find that.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . If you are not able to access router with above user and password then yo need to reset it. For that press RESET button for 10 seconds it is in back side of router.Then configure it again with above method.
Let me know if you need further assistance. Thanks for using FixYa.
Dec 05, 2010 | Linksys Wireless-G WRT54G Router
Using linksys wrt54g router i using the wired section with two computers and the signal only dropping
There are many causes for poor wireless connections, and many solutions:
First of all, give your network a unique SSID. Do not use "linksys". If you are using "linksys" you may be trying to connect to your neighbor's router. Also set "SSID Broadcast" to "enabled". This will help your computer find and lock on to your router's signal.
Poor wireless connections are often caused by radio interference from other 2.4 GHz devices. This includes wireless phones, wireless baby monitors, microwave ovens, wireless mice and keyboards, wireless speakers, and your neighbor's wireless network. In rare cases, Bluetooth devices can interfere. Even some 5+ GHz phones also use the 2.4 Ghz band. Unplug these devices, and see if that corrects your problem.
In your router, try a different channel. There are 11 channels in the 2.4 GHz band. Usually channel 1, 6, or 11 works best. Check out your neighbors, and see what channel they are using. Because the channels overlap one another, try to stay at least +5 or -5 channels from your strongest neighbors. For example, if you have a strong neighbor on channel 9, try any channel 1 through 4.
Also, try to locate the router about 4 to 6 feet above the floor, in an open area. Do not locate it behind your monitor or near other computer equipment or speakers. The antenna should be vertical.
Also, in the computer, go to your wireless software, and go to "Preferred Networks" (sometimes called "Profiles" ). There are probably a few networks listed. Delete any network named "linksys". Also delete any network that you do not recognize, or that you no longer use. If your current network is not listed, enter its info (SSID, encryption (if any), and key (if any) ). Then select your current network and make it your default network, and set it to automatic login. You may need to go to "settings" to do this, or you may need to right click on your network and select "Properties" or "settings".
If the above does not fix your problem, download and install the latest driver for your wireless card.
Some users have reported improved wireless performance by switching to WPA encryption.
If you continue to have problems, try the following:
For wireless g routers, try setting the "Transmission Rate" to 54 Mbps.
If you still have trouble, download and install the latest firmware for your router. After a firmware upgrade, you must reset the router to factory defaults, then setup the router again from scratch. If you saved a router configuration file, DO NOT use it.
Aug 24, 2010 | Linksys Wireless-G WRT54G Router
I have a Linksys Router WRT54G. I'm typing
Are you typing that IP address into your web browser? 192.168.1.1 is the default address that the WRT54G uses, so if that's not the right address, then it got changed somewhere along the lines. You can reset your router to set it back to its default settings, which would be 192.168.1.1.
Once you pull up the configuration software in your browser, you may need to log in with the username and password you chose -- otherwise the default username and password are "admin" and "admin".
Aug 08, 2010 | Linksys Wireless-G WRT54G Router...
Just received the WRT54G router and wireless card from a friend...the router works, but I can't get the wireless to work without the original password, however my friend can't remember it. Since i have...
You can reset to default factory settings.
check here for a full list of default password
or follow these instruction:
"f you have forgot the default password of your linksys WRT54G router than remember that the default password for WRT54G is user name = not required /give any
password = admin
and the default access IP of WRT54G is 192.168.1.1"
and here for a configuration tutorial of your device.
Of course resetting values you have to recreate network configuration this tip can help.
Aug 02, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Linksys WRT54G not seeing internet connection
spacer335,
Who is your Internet service provider, and do you have cable or DSL? You said you have your PC, Xbox and DVR all hard-wired and working fine; are they currently able to get online while connected directly to the Linksys WRT54G? What devices are you trying to connect wirelessly to your Linksys WRT54G?
If you are currently getting Internet access let's check the wireless settings in your router.
Here are a few things you can do to verify your wireless settings in the Linksys WRT54G:
1. From your hard-wired PC, log into your Linksys WRT54G via the web-based interface. (Open Internet explorer and type 192.168.1.1) Note: this is the default IP address that comes on most Linksys routers.
If that doesn't work, verify your computers current IP address information by going to Start (or in Vista it's simply a windows icon), and selecting Run. Type CMD and hit Ok. Now type ipconfig and hit enter.
The default gateway information is the address of your router and should read something like 192.168.1.x.
Enter that address in Internet Explorer's address bar and hit Go.
2. If you connected successfully you should receive a username and password prompt, again the default username and password that comes with most Linksys devices is admin/admin, however it could be different if you've specified an alternate username/password. If you cannot remember the username/password, your only recourse is to perform a hard-reset of the device by using a small pin and holding the reset button on the back of the router.
3. Once you're in the router's web-based configuration there will be a section for "Wireless Settings" or "Wireless Configuration", or some derrevation. Depending on the version of firmware you have installed on the unit, it may be under Basic Setup or Advanced Setup.
You'll know you've located it when you have see options for SSID, Channel, Wireless Security/Encryption, WEP, WPA, etc.
This section will tell you the name of the signal your router broadcasts (also known as SSID). You can change this to whatever you like, in fact is reccommended you change to something unique so that you can easily identify your network when trying to connect with a laptop. You can also enable wireless security such as WEP or WPA, however for the purposes of troubleshooting let's leave encryption off for now. Once you've made the neccessary changes, select Save or Apply at the bottom of the page to save your changes.
4. Now, again since I don't know what you're attempting to connect wireless I will assume its a laptop with an intergrated wireless adpater, or possibly a USB or PCMCIA wireless adapter. Either way you should see your network (with the new name you've configured) in the list of avialable networks, do you see any networks listed? If the laptop has built-in wireless, is the WLAN switch enabled on the laptop? (Usually a small switch on the front or the side of the laptop indicating WLAN, or sometimes a function/fn key combination)
Hope this helps somewhat, give me some more information about what you're trying to connect wirelessly with and I'll see if I can help you out.
Jun 09, 2009 | Linksys Wireless-G WRT54G Router
Slow or no wireless speed, connection says excellent
Your router may be toast but here are a couple of things to try:
Please remember, I'm guessing here...
Before restoring to factory defaults, make sure you can get to the config pages using the rj45 (wired) ports. Do a speed test with a wired connection at http://www.speakeasy.net/speedtest/
1. try removing all security. No WEP or WPK. Also, use no mac address filtering. See if it speeds up. Go back to http://www.speakeasy.net/speedtest/ and try speed testing the wireless portion of your router..
2. If it has automatic channel selection, this may be acting up. So manually select channels. Then do speed tests at the web site (or any speed test web site of your chosing). You may find a screaming fast channel.
3. If this fails to help, use the reset to factory default button. Try setting up the router with NO security first and do speed tests. Use automatic channel selection first, do speed tests, and if all else fails, you can try manually selecting channels again. If the router works well, you might want to set up security again and retest.
4. If all this fails, buy yourself a new wireless 802.11N - (N1) router. They are screamin' fast and have better range.
Apr 07, 2009 | Linksys Wireless-G WRT54G Router
Configuring WRT54G
there are many ways to setup/configure a wireless router. the easiest way for me is to plug your modem to the router, (even though unplugged, there should be a wireless network signal on your device that has a wifi but no internet connection) once connected, plug the modem to the wireless router then reset it, wait a few seconds then you'll get an unsecured network with internet access on it. usually, the only use for the cd is to make you configure it easier like putting a password on it etc.
Feb 05, 2009 | Linksys Wireless-G WRT54G Router
Linksys wireless-G router configuration on PPPoE internet connection
Connect modem to the internet port of the wrt54g
Connect pc to port 2 of the wrt54g
Reset the wrt54g, push reset button for 30seconds with the power on, uplug the power for 10 seconds
Open internet explorer, type 192.168.1.1, you will be asked to login, no username, password is admin. This will take you to the router page. On the page you will se AUTOMATIC CONFIGURATION DHCP, change that to PPPOe, enter your broadband username and password. Click save settings at the buttom of the page. YOU WILL ONLY GET CONNECTION IF YOUR USERNAME AND PASSWORD IS CORRECT.
GOOD LUCK
Mar 14, 2008 | Linksys Wireless-G Broadband Router
Setting up a WAP54G as a wireless repeater with a WRT54G
Requirements for WAP54G & WRT54G Repeater Mode function: * WRT54G: Firmware 2.02.2 or higher * WAP54G: Firmware 2.06 or higher Go to http://www.linksys.com/download to download the latest firmware upgrades for both devices. . Accessing the Router?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the Router into the Address Bar (192.168.1.1 is the default IP Address). 2. Click GO or press the [Enter] key. The User Name and Password prompt will appear. 1. Leave the User Name field blank. 2. Type admin in for the Password (the default Password). 3. Click OK or press the Enter key. The Router?s Setup page will open: * Click on the Status Tab. * Click on the Wireless sub tab. Write down the Wireless MAC Address and the Channel number values located on this page. If the Encryption Function is Disabled, go to the WAP54G Repeater Setup section below. If Encryption Function is Enabled: Note: WPA (Wi-Fi Protected Access) is not yet compatible with wireless repeater mode. You must use WEP Encryption if you wish to use security options with this configuration. To gather WEP encryption information, click on the upper Wireless tab, then the Wireless Security sub tab. Write down the Passphrase. WAP54G Repeater Setup Be sure that you have the WAP54G plugged directly into one of the WRT54G?s numbered ports for the duration of the setup. Accessing the WAP54G?s Setup Page: Open a Web Browser (either Internet Explorer or Netscape). 1. Type the IP Address of the WAP54G into the Address Bar (192.168.1.245 is the default IP address). 2. Click GO or press the Enter key. 3. The User Name and Password prompt will appear. 4. Leave the User Name blank. 5. Type in admin for the Password (the default password). 6. Click OK or press the [Enter] key. The WAP54G?s Setup page will open. 1. Set the Channel value to the same channel as the WRT54G router that was obtained from earlier steps. 2. If WEP encryption was enabled on the WRT54G: * Select Enable for the Wireless Security option. * Click on the Edit Security Settings button and enter the same Passphrase as the one of the WRT54G router that you recorded. Click Generate to populate the WEP key fields. * Click Save Settings to save your changes and close the encryption window. Click Save Settings to save your changes on the Setup page. 3. Next, click on the AP Mode tab. * Select the Wireless Repeater option. * Enter the WIRELESS Mac Address from the WRT54G that you recorded. (Disregard the fact that the page asks to ?Enter the LAN MAC ADDRESS?). Click Save Settings to save your changes. Close your web browser. You can now place the WAP54G Access Point in another nearby location (with its power adapter plugged in) so that it can repeat the wireless signal that it receives from the WRT54G. Notes: * The ?SSID? of the WAP54G does not have to be the same as the WRT54G. This can be used for initial configuration; using a different SSID will enable testing of network connectivity, and will show that the WRT54G is associated with the WAP54G. * If MAC Filtering is configured on the WRT54G, no extra configuration is needed. Wireless clients will still need to be added the MAC Filter list of the WRT54G, but the WAP54G does not have to on the list.
Feb 16, 2006 | Linksys (WRT54GC) Router
Linksys Wireless-G WRT54G Router Logo
178 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
