Question about Refrigerators
Do you have any plans for a fridge made out of a car airconditioner and a big eskey
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
If I understand your objective, that is to DIY (do-it-yourself) a mobile refrigerator, you might be better off considering plans for an aquarium chiller. The idea would be to substitute a 52 Litre Esky for the aquarium, the automotive aircon compressor in lieu of a refrigerator 1/8 HP compressor and the other components as directed in the plans. Examples of DIY aquarium chillers are here, here and/or here.
Good luck and thank you for using FixYa.
Posted on Feb 14, 2009
  • Refrigerators Master
  • 19,396 Answers
It can be built follow general indications on fridges .
It seems the end of the hose I purchased is to big or maybe I didn't insert it right. Is it possible hose connector that screws on is to big?
Not enough information. What does the hose connect to? Is it a vacuum hose, radiator hose, heater hose, airconditioner hose? With such little information to go on, it's difficult to give a proper answer.
Mar 29, 2017 | Cars & Trucks
Tip
Water in Airconditioner
Keep a bowl of water in your Air conditioner room is good for health. Air conditioner will remove all the moisture from the air then it will blow just dry cool air that is not good for health keeping a big mouth bowl of watter will help.
on Apr 08, 2011 | Heating & Cooling
I have a camper trailer with 100amp battery and was wondering up to what size inverter i can run iwill be using 60ltr fridge (not running it overnight) a tv and computor
Before you get too carried away, are you aware that no matter what size inverter you are running, you need enough battery capacity to convert to AC (hydro) . 1 x 100 amp battery will not last very long under that load. Do you have plans, or storage space for a few more batteries? How/what are your plans for charging those batteries after usage, such as plugging the trailer in or an external charger, or perhaps solar panels?All that needs to be considered. Look at appliances you plan on running and get the watts, or amps required reading of tags, then it will be easier to calculate for you, and recommend possible solutions.
Aug 05, 2011 | Electronics - Others
I takes like 2 hours to make ice
??? an airconditioner making ice??? You sure its not a fridge??
Jul 14, 2011 | Midea MPM-08CR-BB4 Portable Air...
When I start airconditioner in my Mitsubishi lancer 1999 model car, it slows the speed and affecting like a catching. What is the reason? How can I clear it?
I would get the engine checked.Not the air/con.The air/con takes about 2 horsepower so if your motor has a big drop in power when you turn it on.Check the motor tune.Hope this helps
Apr 14, 2011 | 2002 Mitsubishi Lancer
Sub-Zero 550 Freezer not cold enough
Start with the simple items first like checking the coils at the back of the freezer for ice. If there is let it melt away by unplugging the unit. Have the unity cleaned at that area whether there is ice or none and the entir fridge including the drains on the freezer. Then start the unit again.
Aug 31, 2009 | Freezers
Can anyone please tell me the location of the airconditioner freon charging port on my 2005 Chevy Silverado 2500HD, Turbo Diesel w/allison trans. There isn't one on the big line from the compressor to the...
The A/C service port is on the accumulator (Filter/Seperator i think is what you called it)on your Silverado. Good luck and keep me posted. Be glad to help.
Jun 26, 2009 | 2005 Chevrolet Equinox
Refrigirator not cooling up
I have had the same problem with my fridge. I have a Whirlpool that is about four years old and it started to make a clonking noise a few weeks prior to it stopping cooling. I spoke with a few people and they said that it is usually the start device relay. I purchased a new one and it took off and worked great for almost two weeks. Well last night we found our food in the freezer thawing again. We had heavy rain storm and the electricity flickered a few times. I was told that it could have damaged the new relay I just put in. I purchased another one today and it is now running fine again. I also had the capacator checked to be sure that it was functioning fine. At $60 dollars a crack I hope that this is not going to happen again any time soon. This relay assembly is located on the compressor (big black roundish tank looking thing). Be sure to unplug your fridge then remove the cardboard cover from the back of the fridge and it should be in plan site. hope this helps.
Chris
Sep 28, 2008 | Kenmore 53642 / 53644 Side by Side...
Fridge temp high
freon and a compressor is about as easy as it gets....Loss of freon will cause erratic cooling...also if you can feel it touch the compressor after it shuts off if if feels like its really hot ....bad compressor that kicks an internal breaker....bad news then time for new one also only a airconditioner man can put freon in no 12 . but freon will stay for 50 to 80 years for i tested some old fridges and still cool fine.
Aug 31, 2007 | Avanti 310SST Compact Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
