Question about Panasonic DMR-EZ47V DVD Recorder/VCR
No picture when connecting CRT TV to Panasonic DVD/VHS Combo
I am trying to connect a 12 year old Teac )CT-M6620S) CRT TV to a Panasonic DMR-EZ48V DVD/VHS Combo.
The Teac only has a scart output and I have connected the Red, White, Yellow points to the DVD/VHS Common Out. I've also tried to the Component Video Out and the AV1 In.
I cannot get any sound or picture on the video channel but get the sound of any video or DVD that I play when I go to the preset channels on the TV.
I think I have a problem with the Scart carble/Red whit, Yello ports but do not know what.
Can anyone think what setting should change?
  • webscore Feb 14, 2009
    Forgot to mention - I also can't set-up the DVD/VCR combo. The automatic setup does not starts, the manual setup instructions (press Function Menu) has no effect. Is this TV incompatible?
  • webscore Feb 15, 2009
    Any idea how to do that? I can't get into the set-up function to set anything
    Genius:
  • Panasonic Master
  • 1,550 Answers
If you combo get activated the progresive scan function you never see the videio only sound you need to deactivate
Posted on Feb 14, 2009
No read on my 2008 panasonic dvd recorder DMR-EZ485V
Insert a lens cleaning disc into it and let it play. If this do not help you, the optical pickup unit to your playder is faulty, and should be replaced.
Apr 30, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
I HAVE A PANASONIC DVD,VHS RECORDER MODEL #DMR-EZ48V.WHEN TRANSFER A VHS CASSETTE TO A DVD THE THUMNAILS ON THE DVD HAVE THE DATE OF 1/1/2000. HOW CAN I PUT THE ACTUAL DATE OF THE RECORDINGS ON EACH OF THE...
Try setting the clock on the remote press [FUNCTIONS] go to SETUP menu - locate the CLOCK option (it should be under 'OTHERS' in the setup) and set the current time, press [ENTER/OK] to store if necessary, then press [RETURN] to exit the setup. Once clock is set correctly, future DVD thumbnails will show the actual date/time of recording in this (and similar) model combo units. If auto clock setting is not possible, set it manually as above.
I assume in spite of the wrong date/time, your DVD recordings have been successful. Incorrect clock and date setting usually only affects timer recording for VHS.
If you have lost or misplaced your original owner's manual, you can download a free pdf version (for Region 1 model) from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ48VK
or, if you live outside USA, download the 'Australia/NZ' pdf version of the manual (for Region 4 model) from:
http://www.panasonic.com.au/Products/DVD+and+Blu-ray/DVD+-+Players+and+Recorders/DMR-EZ48V/Downloads
either one of these will provide you a full copy of the original user guide/setup including clock.
All free. Hope these suggestions help.
May 02, 2011 | Panasonic Televison & Video
Getting an U99 error with a panasonic DMR-ez48v vhs/dvd combo unit. Any idea what this indicates
The U99 error is a "general communications problem". Were you trying to switch sources when you were recording? You shouldn't to avoid this error. That's what we did with my Uncles unit.
Mar 01, 2011 | Panasonic Televison & Video
Panasonic DVD VHS combo DMR-EZ48V will not play region 1 dvd
This is happening because your DVD is NOT all region, you need to change the Code.
en.wikipedia.org/wiki/DVD_region_code -
www.dvdexploder.com/ -
www.dvdexploder.com/multihacks.htm
www.allformp3.com/dvd-copy.../dvd-region-code- free.htm -
www.dvd.reviewer.co.uk/info/multiregion/ -
Ok check those links out they will help you sort it.
Apr 01, 2010 | Panasonic DMR-ES40VS DVD Recorder/VCR
Unable to view/record cable channels with Panasonic DMR EZ48V
Here is what you will need. This is assuming you do not have a HD cable box.
1) A two port cable splitter available at your local hardware or electronics store. VERY IMPORTANT- this splitter needs to pass up to 1000 mghz so you do not interfere with the functions of the cable box. Also, when purchasing this don't be fooled gold does not always equal good (a common mistake made by folks).
2) 1 small coax cable.
3) 3 Additional coax cables. (1 long enough to reach from the wall to the cable box. 1 long enough to reach from cable box to the TV. 1 long enough to reach from wall to the VCR. These cables should be RG6 coax cable (about the width of a standard wooden pencil)
4) 2 RCA cables (Yellow/Red/White)
Here is how you need to connect the cables....
1) Use the small coax cable and connect it from the WALL to the INPUT of the two way SPLITTER.
2) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the CABLE BOX.
3) Use one of the coax cables and connect it to the OUTPUT of the CABLE BOX to the INPUT of the TV.
4) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the VCR.
5) Use one of the RCA cables and connect to the DVD/VHS COMMON OUT on the VCR. Connect the other end of this cable to the VIDEO IN on the back of the TV.
6) Use the other RCA cable and connect it to the VIDEO OUT on the back of the CABLE BOX. Connect the other end to the IN 1 on the back of the VCR.
Here is how to set up the VCR-
1) Tune the TV to the video input that you connected the VCR to.
2) Go to the auto program in the menus for the VCR and select "CABLE" as the source and you should now be able to get all the channels you would normally get without the cable box.
3) This will give you the option to record shows from basic cable on the VCR. While copying these channels you will still be able to tune the TV to CH 3 for the cable box and watch TV normally through the cable box.
4) If you want to copy one of the channels that is only available with the cable box you will still be limited to only being able to watch that channel while it is recording but here is how you will do it.
  • Tune the CABLE BOX to the channel you want to record.
  • Tune the TV to the VIDEO INPUT you have the VCR connected to.
  • Select either VCR or DVR on the VCR.
  • Select recording mode.
  • Press the INPUT SELECT button.
  • Select IN 1.
  • Press RECORD.
Hope this has been helpful....
Good Luck....
Jan 19, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR EZ48V will not go into Functions
HI I WILL LIKE TO DO A FACTORY RESET ON MY panasonic dmr-ez48v, WHAT DO I HAVE TO DO?
May 03, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
How can i connect the dmres15 to my cable box, dvd/vhs player
Yea I have the same set up and did the same thing as that your trying to do and what you have to do is run both the cable box and the VCR through your TV using the inputs. As well as a PS2 running through imput 3.
Hope I helped
Jan 30, 2009 | Panasonic DMRES15 DVD Recorder
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
422 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
