Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
500Gb sata hard disk problem
Hai all,
My 500Gb sata hard disk is sensing only as 136 GB in my windows 2000(With SP4) system. In Disk management also it is sensing only as 136GB only. But in my BIOS it is sensing as 500GB. Did anybody is having the same problem or knew the solution for this problem please help me.
Posted on Feb 14, 2009
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I have a seagate freeagent go 500 GB drive. It fallen on ground (from one Ft. height). when i connected it now it's light is flashing continously and it's not recognized by system. upon connecting...
Hi'' so sorry for you , yes hard disk are so delicate when it fall , a fragile hardware even with just a little bang on tables or to a hard things the next is it would be damage , so here is another way to check on how to see back your files on the 500gb HHD you dropped,i hope this can help you, Open and connect to an unplug pc, if your 500gb HDD is a sata connection use the sata wire to connect hard disk directly to a PC mother board , insert the sata wire to a Sata port and put a supply on the disk , but be sure your disk is placed on top of box or books just to make sure it would not make any short circuits and then start power on, this is very risky work ,a professional technician is recommended to work it out .
Jul 16, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
On my GT5220-(Athlon X2 64 3800,4G'S RAM)--I HAVE THE STOCK 250GB HDD/IDE THAT IS RUNNING XP-32 BIT,AND I AM TRYING TO ADD 500GB SATA HDD THAT HAS WINDOWS 7 ULTIMATE 32BIT UPGRADED FROM XP VER. EVRYTIME I...
ok get a windows 7 disk and turn of the computer and ad the hard drive switch on the computer and set it to boot from disk (seems windows is broken on the 500gb hdd) then boot from disk and install windows 7 to the 500 gb hard drive and set in the bios the boot select for the hard drive (if you use win xp more then make that boot primary) then go threw all the rigmarol of installing windows 7 to the 500 gb one and your done it will have bootable hard drives and will offer a choice when first switched on
May 15, 2010 | Gateway GT5220 PC Desktop
Samsung 500gb hdd windows only shows it as a 127gb hdd where is the rest of it
the rest of the memory might be remain unpartitioned...right click my computer->manage->disk management.There you will see the details about the partitioned and unpartitioned disks...check it out...
Jul 05, 2009 | Samsung 500GB, 7200RPM, Internal, 16MB,...
My system is not stable
Can be virus...hardware..or o/s issue
  1. Try taking unwanted files or prrgrams
  2. empty the temp folder
  3. Scan using latest anti virus
  4. Defragment
  5. if still same. Try formatting and re-installing the o/s..
  6. if still the same check replacing HDD ...or M/B
May 22, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Hard disk Recognition problem
U are actually facing the same problem as "jackwilkinso". As my previous post: Windows XP does not come out to support SATA hard drive, because inside do not inclued the SATA driver, that why u cannot see the harddisk during the setup. What u can do is try to install the SATA supported OS like Windows Vista or Windows 7, or maybe can "forcely" put in the SATA driver in ur Windows XP setup CD.
YBC (/\)
Mar 29, 2009 | Western Digital Caviar 500GB Internal SATA...
Disk manager for seagate 160 gb sata barracuda hard disk
windows xp setup not creat the partation.
and not show the tha harddisk,but harddisk are showing the bios setup.
my system is ACER ASPIRE tower Casing.
Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
500 GB SATA HDD Not Showing in Windowss 2000 Server Plat form
Reset your Cmos
And go into bios and search for a hidden partition
Sep 23, 2008 | Microsoft Windows 2000 Professional for PC
USB 2.0 Host Controller on Windows 2000 Server (Emachine 5260)
raycrean, Windows 2000 service pack includes drivers for USB 2.0.
http://support.microsoft.com/kb/819332
How do you know its not operating like 2.0?
Jan 19, 2008 | E-Machines eMachines Desktop PC
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
177 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
