Question about AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800)
Application Error Seems like every time i put in a desk or computer just seatin around.. 2 differnt boxs pop up, that says. Reader_sl.exe or CDStart.exe bout show The instruction at "0 x 00000000" referenced memory at "0 x 00000000". the memory could not be read. Click ok to terminate program. How can i go about to fix this?
    Genius:
  • 1,066 Answers
You could be having ram errors, which would call for replacing your ram. download and boot to memtest86 to test your ram.
Posted on Mar 11, 2009
Svchost exe error
upgrade to a newer OS helps alot
Jul 18, 2014 | Toshiba Satellite Computers & Internet
Missing a MSVCR100.ddl driver
just reinstall ur adobe reader
Jan 19, 2014 | Computers & Internet
Windows 7 64bit ultimate edition Lots of ''Application Error''
asus M2N68-AM PLUS motherboard is supports all operating system but intel is not support win 7 64bit
May 13, 2010 | ASUS P5QC Motherboard - Intel P45, Socket...
What is an ArcCon ac application error0xc00000006?
What you describe falls under the general category of svchost.exe issues. Svchost.exe is used by your computer to access the registry and check the services to load during system startup.
arccon.ac is an ArcSoft Connect Notifier. There are two possibilities why its happening:
  1. Microsoft releases regular security updates that are installed automatically on your computer by the Automatic Updates feature, which is enabled by default on your computer. The Svchost.exe Application error usually appears due to a problem with a recent update.
Closing the error message might freeze your computer. To fix this error, perform the following tasks.
  1. Open Control Panel, select Performance and Maintenance, and then select Services.
  2. In the System Properties dialog box, open the Automatic Updates tab.
  3. Next, select the Turn Off Automatic Updates option.
  4. Select Apply and then OK to accept your changes and exit the System Properties dialog box.
  5. Restart your PC.
  6. Ensure that you are connected to the Internet and then select the Windows Update command from Start > All Programs to manually update Windows.
  7. After the update is complete, enable the automatic updates again from System Properties > Automatic Updates.
This should rectify your application error. However, if the error keeps reappearing, then you might turn off automatic updates permanently and manually perform Windows updates at regular intervals.
Errors Caused By Virus Infection
Let's hope that this isn't the case. Lengthy procedure but if you are still having trouble, we'll cross that bridge when we get to it.
Dec 09, 2009 | Computers & Internet
Dwwin.exe-application error. The instruction at "0x0013ff7" refrenced memory at "0x00000013". The memory could not be written. The computer will not load any icons on the desk top just frozen their
dwwin.exe is Microsoft Application error Reporting. You may have a problem with a background program starting at Startup. May want to look at items on the Startup tab in msconfig.
Start,
Run, then type msconfig remove any program that you do not need at the start up or the last one you installed
Sep 11, 2009 | Computers & Internet
Problem about "services.exe - Application Error" pop-up menu
Apparently, you computer has some unexpected software running during the startup. In order to get ride of these software, you could check your register table manualy by regedit or download this software, which will help you to find if there are any suspect software running at the startup.
files.filefront.com/sreng2zip/;8049311;/fileinfo.html
May 07, 2009 | Computers & Internet
ZDplus.exe application error
You are either running out of virtual memory or Zeon DocuCom PDF Plus needs to be reinstalled to fix the error.
Feb 05, 2009 | ScanSoft PDF Converter Professional 3 for...
'Fatal Application Error', box pops up
Can you turn off your system and get to safemode? if yes, try to clear out your startup items using the msconfig tool (Start > Run > MSConfig > Startup Tab > Disable All).
Lemme know if this helps!
Jan 12, 2009 | Mitac Mio C220 GPS Receiver
AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800) Logo
48 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
