Question about Brother DCP-8065DN Black and White Copier
Worgh toner was put
The mine problem was worgh toner was given to me,after changing it, it was not copering ok, so at last i found that it was worgh toner, then a bought the one for it from ther it was not work that is the problem, so what advice will you give me.
thanks
William Duku
  • Terry Watson
    Terry Watson May 11, 2010
    What is Worgh Toner? Is that the brand name? When you put the toner in, what is it doing. Does it give an error message or is it making a noise? Please let me know and I might be able to assist you futher.
  • 62 Answers
There may a jam in fuser area in rear of machine. Check there by opening rear door and sliding the black paper chute left and downward to look inside fuser area. Look for paper or a worn fuser such as black marks or lines on top or bottom rollers. Make sure machine is off and unplugged. The fuser gets very hot. Let cool down before attempting to view area of fuser. Do not pry out paper or objects from fuser. This may damage fuser more. Use your fingers only if possible. If there is no paper or black lines, your problem may be else where. Let me know and I may be able to help some more. Thanks!
Posted on Feb 16, 2009
CHANGED MY TONER, SKIPPED THE VERY LAST STEP OF INSTRUCTIONS. NOW PRINTER WON'T PRINT
Hello
Get the toner back and complete the last step you skipped and put it back.
Good Luck
Jan 06, 2011 | Brother HL-5240 Laser Printer
I just added toner and now i can not get the coper to print anything on the paper
re engage the developer handle{knob upper right side}.but this could be broken to where you would engage it it will move up and disengage itself
Mar 22, 2010 | Canon ImageRUNNER 330s Copier
I have an HP Laserjet M1319f MFP printer, when I print it uses alot of toner. How can I program it or what can I do on the computer to use less toner?
You can set the density lighter or put the printer in economode. You may not like the print quality as it will be extremely light. But the toner will last longer.
Save toner
1.
On the File menu in the software program, click Print.
2. Select the driver, and then click Properties or Preferences.
3. On the Paper/Quality tab, click EconoMode.
4. Click OK.
Nov 05, 2009 | HP Laserjet M1319F Laser Multifunction...
I cleaned the toner of my coper machine and when i
Might want to get a new image unit. Did you recently replace the image unit. Did you use a vacuum cleaner to clean toner??? . (DO NOT USE A VACUUM CLEANER TO CLEAN TONER STATIC ELECTRICTY CAN DESTROY THE SENSOR UNDER the Image unit.
Try this site and get new image unit if available you have legacy Minolta machine.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Oct 30, 2009 | Minolta DiALTA Di250 All-In-One Laser...
Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Nov 05, 2008 | Sharp AL 1631 Copier
Cannon IR 400S Copier
1-en front door look inside and see if there are black rings around the shiny Drum cylinder, if yes replace drum blade (may have to replace drum also).
2- if lines only come when doing from ADF then lift top and clean the small strip of glass.
Sep 13, 2008 | Canon imageRUNNER 400S Copier
Ricoh Aficio 6513 Black TOner not set
double check the developper, vacuum the top and make sure there is no previous cover from the last toner, it goes in and connects ok, the switch is ok.
you sound like a tech there must be a service mode to check the sensors, look at the sensor for the toner and check if it changes
Aug 25, 2008 | Office Equipment & Supplies
BROTHER Hl 2040 PRINTER WON'T PRING
I got exactly the same problem and the "reset" didn't do anything. I fixed it by putting a piece of duck tape on magic eye on the cartridge.
Fallow those step to do the same thing as me:
  1. Open the front panel.
  2. Remove the toner and the drum
  3. Remove the toner FROM the drum
  4. On each side of the toner, there should be a little glass. Put the piece of duck tape on one of them. I put mine on the right side.
  5. Put everything back in.
  6. Turn on your printer if it's not already.
  7. Now, the low toner light should be gone and the green light should be on.
Now, you can really empty your cartridge.
Apr 06, 2008 | Brother HL-2040 Laser Printer
Brother DCP-8065DN Black and White Copier Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
